Here is another very similar engine that is in the shop at the moment. This is another 1966 427 but the factory engine numbers are still on it so it can be decoded as a 1966 427/425 or a L72. The 427/425 had solid lifters, 780 Holley carb, a bunch of special parts and only came with a manual trans. This one came out of a passenger car but the VIN isn't stamped on it so don't know what. Probably Impala SS. The passenger car 427/425 are much rarer than the Corvette L72 engines since most people buying a big car didn't want a high compression, solid lifter engine with a manual shifter.
I think this one his getting hot rodded too but I don't know the details.
If that block was installed in a car it would have the serial number on the pad. They started on corvettes in 1960
