Re: Extrude Honing [Re: pittsburghracer] #3219631
03/10/24 10:40 PM
03/10/24 10:40 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It doesn't open it up very much. Maybe a 1/6". Mostly it removes casting irregularities than bump up from the surface and smooths it out.
On a Hemi, the manifolds are about as good as you'll find anywhere. Extrude hone might be more effective on worse manifolds.
Re: Extrude Honing [Re: 360view] #3220096
03/13/24 09:34 AM
03/13/24 09:34 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
In the original Magnum V8 press release Chrysler specifically brags about
“new Balanced Flow” Magnum exhaust manifold design.
If the exhaust flow varies between cylinders
the intake charge filling to the cylinder will vary
as will the charge temperature.
It is not just peak exhaust flow, unless it is a one cylinder engine.
Re: Extrude Honing [Re: 360view] #3221616
03/20/24 10:00 AM
03/20/24 10:00 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Waste of money for the most part.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
