Re: 74 duster starter stays engaged [Re: mopars4ever] #3218594
03/06/24 01:48 PM
03/06/24 01:48 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Yes, I had a 74 charger that had a button, but wasn't sure on the a-body.
The charger also had little orange box with no button also
Re: 74 duster starter stays engaged [Re: B1MAXX] #3219216
03/09/24 01:11 AM
03/09/24 01:11 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Guess I don't understand how it can crank with the yellow ignition wire unhooked.
Re: 74 duster starter stays engaged [Re: chargers777] #3219226
03/09/24 03:00 AM
03/09/24 03:00 AM
Something, a circuit, is shorted out work scope wrench twocents
All things broken are fixable up wrench scope
Re: 74 duster starter stays engaged [Re: Cab_Burge] #3219242
03/09/24 08:46 AM
03/09/24 08:46 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think I'd try replacing the relay first and eliminate the easy stuff.....
my 2 cents,
Joe
Re: 74 duster starter stays engaged [Re: chargers777] #3219245
03/09/24 09:42 AM
03/09/24 09:42 AM
IMGTX Offline
IMGTX  Offline
You said you think someone has been into the wiring. Can you show or tell us why you think this?
Can you send a picture of the wires going into the relay?
I am hoping the wiring has been messed with and the colors are off.
I am starting to think, like cab, that you have a wiring short but a picture of the relay and wiring may help.
Did you check to see if the reverse light stays on through all the gears?
Do you have a voltage meter? A regular test light?
Re: 74 duster starter stays engaged [Re: IMGTX] #3219272
03/09/24 12:34 PM
03/09/24 12:34 PM
moparx Offline
moparx  Offline
look closely at the column connection where it plugs into the main harness.
this is a common place for "melty's" to occur.
please let us know what you eventually find.
beer
Re: 74 duster starter stays engaged [Re: moparx] #3220992
03/17/24 11:17 AM
03/17/24 11:17 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Any resolution to this problem??
Joe
Re: 74 duster starter stays engaged [Re: jlatessa] #3221038
03/17/24 02:01 PM
03/17/24 02:01 PM
moparx Offline
moparx  Offline
i'm wondering as well.
beer
Re: 74 duster starter stays engaged [Re: moparx] #3221042
03/17/24 02:13 PM
03/17/24 02:13 PM
Nashport, OH
Nashport, OH
Update. Thanks for all the help. Someone had spliced a wire from the yellow ignition wire down to the solenoid wire by in addition to it going to the relay. Finally found it tucked into the wire harness. Seems fine after unhooking it.
Re: 74 duster starter stays engaged [Re: chargers777] #3221048
03/17/24 02:26 PM
03/17/24 02:26 PM
moparx Offline
moparx  Offline
glad to hear the problem has been solved, and what the cause of it was. up
beer
