Re: What brand of dino oil do you guys prefer? [Re: Lefty] #321843
05/19/09 01:17 PM
05/19/09 01:17 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Seems like a diesel oil would be loaded with extra detergents to keep sludge away.
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321844
05/19/09 02:45 PM
05/19/09 02:45 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
VALVOLINE VR1 10W30 OR 20W50
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: What brand of dino oil do you guys prefer? [Re: Lefty] #321845
05/19/09 03:44 PM
05/19/09 03:44 PM
MNobody Offline
MNobody  Offline
Diesel oil has metallic based detergents which can cause excessive ash deposits (sludge) in your engine.
Completely not true! My 440 is spotless inside the valve covers. It's cleaner than when it was reassembled after a rebuild. Show me some proof that diesel oil causes sludge.
I just adjusted the valve lash on my 318 and everything was spotless, i'm running Rotella 15-40.
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321846
05/19/09 03:50 PM
05/19/09 03:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's some info from Caldwells speed shop website.
Lots of opinion there.
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321847
05/19/09 04:27 PM
05/19/09 04:27 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Bradd Penn when I can find it, otherwise Valvoline.....
Re: What brand of dino oil do you guys prefer? [Re: hemicop] #321848
05/19/09 05:14 PM
05/19/09 05:14 PM
At a gas station near you
badblack68 Offline OP
Is it true that Carquest branded oil is really Valvoline?
Re: What brand of dino oil do you guys prefer? [Re: John_Kunkel] #321849
05/19/09 05:18 PM
05/19/09 05:18 PM
How do you come to the conclusion that what is stated there is opinion? They have charts from the various oil brands and additives that state the facts on those products from test laboratories. I don't believe they're making up those figures just to sell zddp.
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321850
05/19/09 06:34 PM
05/19/09 06:34 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
O/T, I just changed the oil in my truck, $4.00 a qt for valvoline at Oreilys!
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321851
05/19/09 07:16 PM
05/19/09 07:16 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Valvoline 10-40 with a little GM EOS.
I thought about using a synthetic, but it's too expensive for a daily driver + the guy who machined my rotating assembly said it's not worth the extra money and that a good number of racers still use conventional oils. He's done crankshaft work since the early 70's, in addition to drag racing his cars on the side, so he's pretty much seen it all.
Here's what Caldwells says about GM eos:
Q:
What about using GM EOS?
A:
GM EOS contains less than 1/2 the amount of ZDDP as ZDDPLus. The concentration of ZDDP in GM EOS is diluted in a 16 ounce bottle. The proper level of ZDDP for high performance and classic cars is a minimum of 1300 PPM. To do this with GM EOS you would have to use 16-32 ounces of EOS significantly changing the viscosity of your oil and causing possible foaming within the oil.
ZDDPlus is clearly a better choice with one 4 Oz. bottle capable of raising 5 quarts of oil to a level of 1700-1800 PPM.
One 4 ounce bottle of ZDDPlus has the same level of ZDDP as 34.3 ounces of GM EOS.
Yeah but then you gotta watch out for TOO much zinc. The Reps at Royal Purple have advised that anything used regularly that is more than the needed 1100-1300 ppm of zinc/phosp. could cause an ashing or coking effect.
This, again, is why I like just using a good brand of oil such as Royal Purple that has just enough ppm of zinc, and then I don't have to worry about additives, how much zinc they have, etc, etc.....
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321852
05/19/09 09:51 PM
05/19/09 09:51 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Anybody else followup the link to "caldwellsspeedshop" ? What do they sell? I don't see anything except the oil additive. I clicked on the link at their website supposedly to the independent laboratory testing...HaHa: 404 not found.
Re: What brand of dino oil do you guys prefer? [Re: badblack68] #321853
05/19/09 10:50 PM
05/19/09 10:50 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use Mobil Delvac 1300 in all of my engines.It's a 15w40 diesel rated oil,and I've had very good results with it.
Nautilus Racing-
Re: What brand of dino oil do you guys prefer? [Re: Chris2581] #321854
05/20/09 12:11 AM
05/20/09 12:11 AM
hooziewhatsit Offline
I use Delo 400. $12/gallon. Has 1200ppm zinc, 1300ppm Phosphorus.
https://www.cbest.chevron.com/generated/MSDS/PDS29828888.PDF
Re: What brand of dino oil do you guys prefer? [Re: hooziewhatsit] #321855
05/20/09 02:41 PM
05/20/09 02:41 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
That’s great to see that the Delo 400 “Low Emissions” CJ-4 stuff that passes 2007 EPA exhaust particulate emissions standards still has Zinc/Phos. @ 1300ppm/1200ppm as of May 2009.
Also notice the fine print below the specs:
"Typical test data are average values only. Minor variations which do not affect product performance are to be expected in normal manufacturing."
Sure does give them an easy out if they decide to make adjustments to the formula at any time.
CompSyn
Re: What brand of dino oil do you guys prefer? [Re: DennisH ] #321856
05/20/09 03:00 PM
05/20/09 03:00 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
Valvoline 10-40 then Royal Purple after 2500 miles.
another RP fan, right here
thats what I have in my 440
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: What brand of dino oil do you guys prefer? [Re: 7DRRunner] #321857
05/20/09 06:48 PM
05/20/09 06:48 PM
Hartselle AL
67MIke Offline
67MIke  Offline
Hartselle AL
15 40 delvac mobil shell or rotella. Used castrol in my mgb for 10 years. very clean, same in the 440. My friend swears by the diesel oil in his jeep 250 k on his straight 6 jeep
Re: What brand of dino oil do you guys prefer? [Re: 67MIke] #321858
05/21/09 02:16 PM
05/21/09 02:16 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Just picked up 7 qts of Valvoline VR1 Racing Oil 20w-50
Even had a little sticker on the bottle touting "High Zinc --great for pushrod engines & flat tappet cams"
# Valvoline VR1 Racing Oil 20W50 weight
VR1 Racing Motor Oil's exclusive chemistry is designed to reduce friction and enhance power. It is among the most popular engine lubricants in racing, including CART, stock, and drag. It is recommended for engines burning gasoline and full or partial alcohol fuels for track and street service.
Benefits include:
# Ashless additives and ZDDP provide ultimate wear protection
# Enhanced anti-foam system helps protect the engine even during extreme stress
# Other additives protect against high-temperature deposits for a cleaner engine
# Friction modifiers help improve horsepower output
1MYTGTX
