Re: MPG [Re: Kudakidd] #3219089
03/08/24 01:15 PM
03/08/24 01:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by Kudakidd
Originally Posted by lewtot184
8
A man of few words.
my reply wasn't meant to be obnoxious but based on my experience with low gears. i had a 383 4spd car i ran around on for a short while with 4.30's or 4.56, don't remember exactly but pretty sure it was only getting around 6 in town. my stock 440 r/t with 3.23's and a fairly good tune probably gets about 10 in town. these old dinosaurs are just inefficiently thirsty. one thing for sure is if mpg and a clean burn are important it's fairly difficult beat a stock avs carb.
Re: MPG [Re: Kudakidd] #3219260
03/09/24 10:58 AM
03/09/24 10:58 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
The dash does not have a trip odometer.
Try writing down your odometer reading when you fill it up.
Drive until almost empty.
Observe odometer reading when you go to fuel up, write it down.
Write down how many gallons you put in.
Subtract last odometer reading from the first one.
Divide miles to gallons used. This will give you mpg.
Report back with your results.
There are online calculators to assist with the subtracting and dividing if needed, but the pen, paper, and effort required to write 3 numbers down will have to come from you.
Mo' Farts
Moderated by "tbagger".
Re: MPG [Re: Kudakidd] #3219263
03/09/24 11:43 AM
03/09/24 11:43 AM
Missouri
randavis Offline
randavis  Offline
Missouri
I have a 440 based 511 stroker with a solid roller cam in a 74 Challenger. It has 3.23 gears, 245-60-R15 Goodrich T/A tires, automatiac 727 with TF2 shift kit, and Holley Sniper fuel injection. The Sniper controls timing. I check milage at each fill up. I get between 9 and 11 mpg depending on driving conditions.
The basicaly stock 440 with the Purple Stripe cam (..474 lift) and AVS carb that preceeded this engine got 10 to 12 mpg.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: MPG [Re: randavis] #3220012
03/12/24 05:39 PM
03/12/24 05:39 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Between 6 and 10 mpg.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: MPG [Re: Kudakidd] #3220025
03/12/24 07:51 PM
03/12/24 07:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
high single to low teens range.
I get about 10-12 if I keep my foot out of it for a full tank
One really good romp on the loud pedal for a bit , OR long trips at 70 plus,,,,and Im in single digits easily.
But being brutally honest. I dont care,,,,. I didnt buy if for its fuel economy.
Re: MPG [Re: gtx6970] #3220028
03/12/24 08:00 PM
03/12/24 08:00 PM
Missouri
randavis Offline
randavis  Offline
Missouri
Quote
Well said!!!
Re: MPG [Re: randavis] #3220171
03/13/24 12:54 PM
03/13/24 12:54 PM
moparx Offline
moparx  Offline
remember, "smiles per mile" is the target. biggrin
beer
Re: MPG [Re: randavis] #3220235
03/13/24 05:38 PM
03/13/24 05:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Originally Posted by randavis
Quote
Well said!!!
Agree! Always wondered about these MPG threads. I've had my car well over 30 yrs with a couple combos in it. Currently a 470" low deck w/solid roller cam 4 spd 3:73 gears....never once have I thought about MPG...Doesn't matter, I put maybe 1000 mi /yr on it. Plenty of smiles though. I've had people ask about mileage in my pickup as well....I always tell them it weighs 6000 lbs and has the aerodynamics of a brick....I bought it for a purpose,not fuel economy!
