Originally Posted by Jeremiah
Originally Posted by HardcoreB
Originally Posted by gregsdart
Thanks everybody for the input. Just as in the past , all the help i have gotten hear will certainly help me make the best choice! Jeramiah, I will keep those valves in mind. How long are they?
5.54x 2.296 or 2.298 coated with a 45 seat. .250 to top of Square groove...non-steel tip(needs cap)
Thank you sir!
You're welcome sir! Although they measure slightly under "2.3" they've worked to replace a 2.3 valve in a couple of applications I know. I may have a good used set soon because I'm going to a 2.35"
