Re: Pitman arm install
[Re: 6PAX]
#3217655
03/03/24 10:00 AM
03/03/24 10:00 AM
Posts: 10,723 North Dakota
6PakBee
North Dakota
The original arm fit fine but it was the 69 style arm, not the 73-later type I bought to match the 73-later steering linkage I am using. Curiosity question; why did you go to the 1973-later type rather than stay with the stock 1969? I have a 1969 GTS and am wondering what the advantage is of the later setup.
[Re: 6PakBee]
#3217937
03/04/24 09:11 AM
03/04/24 09:11 AM
Posts: 75,028 U.S.S.A.
JohnRR
U.S.S.A.
The original arm fit fine but it was the 69 style arm, not the 73-later type I bought to match the 73-later steering linkage I am using. Curiosity question; why did you go to the 1973-later type rather than stay with the stock 1969? I have a 1969 GTS and am wondering what the advantage is of the later setup. He changed the centerlink to the 73/up unit because I think he was having an issue with the pitman arm being close to header tubes and the centerlink hitting the pan ... the stud points down instead of up so you have to use the 73 up idler also . Here is the thread ... centerlink issue
[Re: JohnRR]
#3217959
03/04/24 10:39 AM
03/04/24 10:39 AM
6PakBee
North Dakota
Thanks, that makes it much clearer.
[Re: JohnRR]
#3217978
03/04/24 11:51 AM
03/04/24 11:51 AM
Posts: 5,625 Detroit area
6PAX
Detroit area
He changed the centerlink to the 73/up unit because I think he was having an issue with the pitman arm being close to header tubes and the centerlink hitting the pan ... the stud points down instead of up so you have to use the 73 up idler also . Yes, that was the reason. I called Mevotech today and they won't do anything about it. All the woman would say is she agreed there is a problem with the arm but she doesn't know what. I said, there is only one thing it can be, obviously the i.d. of the splines is undersized but she made no offer of rectifying the situation. So, I'm going to have to eat the $40 I paid for it and get another arm.
[Re: 6PAX]
#3218000
03/04/24 01:51 PM
03/04/24 01:51 PM
JohnRR
U.S.S.A.
He changed the centerlink to the 73/up unit because I think he was having an issue with the pitman arm being close to header tubes and the centerlink hitting the pan ... the stud points down instead of up so you have to use the 73 up idler also . Yes, that was the reason. I called Mevotech today and they won't do anything about it. All the woman would say is she agreed there is a problem with the arm but she doesn't know what. I said, there is only one thing it can be, obviously the i.d. of the splines is undersized but she made no offer of rectifying the situation. So, I'm going to have to eat the $40 I paid for it and get another arm. Who did you buy it from ? I'm surprised you got that attitude , When I called their customer service line , granted a year and a half ago , the guy I talked to was very helpful.
[Re: 6PAX]
#3218037
03/04/24 03:36 PM
03/04/24 03:36 PM
Posts: 15,386 Omaha Ne
TJP
Omaha Ne
Have you tried the prussian blue of machinist' dye suggested earlier? the taper of the splines may be the issue. if you still have the old one, measure the thickness, and ID of the splines at the large and small ends and compare it to the new one. A local machinst may be able to hel you with the dimensions if needed Might also just try a different brand from a local parts store. take your old one with you for comparison or look for an NOS one
[Re: TJP]
#3218066
03/04/24 05:02 PM
03/04/24 05:02 PM
Posts: 13,600 md
mopars4ever
md
Have you tried the prussian blue of machinist' dye suggested earlier? the taper of the splines may be the issue. if you still have the old one, measure the thickness, and ID of the splines at the large and small ends and compare it to the new one. A local machinst may be able to hel you with the dimensions if needed Might also just try a different brand from a local parts store. take your old one with you for comparison or look for an NOS one kinda what I was thinking but I was wondering if the taper of the shaft is different between the years and not the arm itself? Trying another arm should answer that.
[Re: 6PAX]
#3218243
03/05/24 10:29 AM
03/05/24 10:29 AM
JohnRR
U.S.S.A.
"Who did you buy it from ?"
I bought it on Amazon. The vendor name was USAutopartsCar.
going to guess it's way past returning it ?
[Re: 6PAX]
#3218481
03/05/24 10:15 PM
03/05/24 10:15 PM
6PakBee
North Dakota
I'd do the Prussian blue check and then start some careful filing on the contact area of the pitman arm splines. With that taper, a little bit will gain you a lot.
