Re: Clutch fan recommendation needed
[Re: 6PAX]
#3215868
02/24/24 04:04 PM
02/24/24 04:04 PM
Posts: 5,450 So Cal
Sinitro
So Cal
After taking some time away from it, I'm finally working on finishing up my engine cooling. Turns out with the radiator I ended up using that I am going to need a shorter fan clutch. The clutch I have is about 3 5/8" in depth. With it, the seven blade fan I am going to use sits all the way into the shroud to where the back edge of the blades are flush with the shroud opening. So, it looks like I will need a clutch less than three inches in depth to get the fan blade half in and half out of the shroud. Who sells clutches that are less than three inches in depth? Most clutch fans available today for Mopar are too tall if U have installed bigger radiator... I have a couple of short height(2.75") mopars with the closed WP hub if U require one. Just send me a PM if any further interest... Just my $0.02... I tried messaging you Sinitro but was unable to. Sorry never received any PM. Note I did post an ad in B Body Parts for a short height (2.75") clutch fan... Just my $0.02.. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: Sinitro]
#3215882
02/24/24 05:08 PM
02/24/24 05:08 PM
Posts: 5,665 Detroit area
6PAX
Detroit area
Sorry never received any PM. Note I did post an ad in B Body Parts for a short height (2.75") clutch fan... Just my $0.02.. You didn't receive it because I couldn't send it. When I tried, I got a message saying "This user is not accepting Private Messages".
[Re: Sinitro]
#3215883
02/24/24 05:12 PM
02/24/24 05:12 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
After taking some time away from it, I'm finally working on finishing up my engine cooling. Turns out with the radiator I ended up using that I am going to need a shorter fan clutch. The clutch I have is about 3 5/8" in depth. With it, the seven blade fan I am going to use sits all the way into the shroud to where the back edge of the blades are flush with the shroud opening. So, it looks like I will need a clutch less than three inches in depth to get the fan blade half in and half out of the shroud. Who sells clutches that are less than three inches in depth? Most clutch fans available today for Mopar are too tall if U have installed bigger radiator... I have a couple of short height(2.75") mopars with the closed WP hub if U require one. Just send me a PM if any further interest... Just my $0.02... I tried messaging you Sinitro but was unable to. Sorry never received any PM. Note I did post an ad in B Body Parts for a short height (2.75") clutch fan... Just my $0.02.. As I stated previously, other than the.050” difference, the percentage of lock up is the only difference between the two HD will lock up tighter and cause a slight loss of horsepower. I would suggest the standard duty clutch and a 7 blade fan. More blades, better cooling. Just my 2 cents.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 6PAX]
#3215920
02/24/24 08:58 PM
02/24/24 08:58 PM
Posts: 5,450 So Cal
Sinitro
So Cal
Sorry never received any PM. Note I did post an ad in B Body Parts for a short height (2.75") clutch fan... Just my $0.02.. You didn't receive it because I couldn't send it. When I tried, I got a message saying "This user is not accepting Private Messages". No idea what happened.. Just double-checked and the Accepting Private Messages option is turned on. Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: Sinitro]
#3215931
02/24/24 09:36 PM
02/24/24 09:36 PM
6PAX
Detroit area
Sorry never received any PM. Note I did post an ad in B Body Parts for a short height (2.75") clutch fan... Just my $0.02.. You didn't receive it because I couldn't send it. When I tried, I got a message saying "This user is not accepting Private Messages". No idea what happened.. Just double-checked and the Accepting Private Messages option is turned on. Just my $0.02... Just tried again and now it works. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 68LAR]
#3216292
02/26/24 10:59 AM
02/26/24 10:59 AM
Posts: 75,103 A Banana Republic near you.
JohnRR
I didn't realize that HP loss locked tighter , standard duty it is with a 5 blade fan ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: 6PAX]
#3216557
02/27/24 10:34 AM
02/27/24 10:34 AM
68LAR
South Park, Pa.
So, if I understand this correctly, the 2947 clutch would cool better in city driving due to the higher percentage of engagement? I'm not concerned with hp loss as much as cooling efficiency. Also, I am uncertain about the number of blades on the fan. From what I've read here and elsewhere, some say the 5 blade is best while other say the 7 blade is better. I'm uncertain which combo to go with, 2965 or 2947 clutch with 5 or 7 blade fan. This is correct, the HD clutch will cool better in traffic. The 7 blade will pull more air than the 5 blade. Example, if you look at a helicopter that is made to lift heavy loads, it has more blade than one that is not made to do so. Another example, look at OTR trucks. None that I’ve seen have less than 6 blades. Even newer passenger trucks have more than 5 blades.
[Re: 6PAX]
#3216791
02/28/24 12:00 PM
02/28/24 12:00 PM
JohnRR
So, if I understand this correctly, the 2947 clutch would cool better in city driving due to the higher percentage of engagement? I'm not concerned with hp loss as much as cooling efficiency. Also, I am uncertain about the number of blades on the fan. From what I've read here and elsewhere, some say the 5 blade is best while other say the 7 blade is better. I'm uncertain which combo to go with, 2965 or 2947 clutch with 5 or 7 blade fan. This is a great subject, that came up at a good time, as I have been thinking about fans on my Factory Appearing build. I have a big block A body and standard its equipped with a 7 blade fixed fan with a 5/8" spacer , hoping that one of these short clutches fits and put the fan in a good spot within the shroud, otherwise a fixed 4 blade fan might be finding a home in it for racing.
[Re: JohnRR]
#3216832
02/28/24 02:48 PM
02/28/24 02:48 PM
6PAX
Detroit area
This is a great subject, that came up at a good time, as I have been thinking about fans on my Factory Appearing build. I have a big block A body and standard its equipped with a 7 blade fixed fan with a 5/8" spacer , hoping that one of these short clutches fits and put the fan in a good spot within the shroud, otherwise a fixed 4 blade fan might be finding a home in it for racing. Been doing a lot of reading up on these clutches and the fans as well John. Right now, I'm leaning toward the 2947 clutch with a 7 blade fan unless someone convinces me that a different combo would be better. As I mentioned, I'm more concerned with cooling efficiency rather than hp loss.
[Re: 6PAX]
#3216852
02/28/24 04:44 PM
02/28/24 04:44 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
This is a great subject, that came up at a good time, as I have been thinking about fans on my Factory Appearing build. I have a big block A body and standard its equipped with a 7 blade fixed fan with a 5/8" spacer , hoping that one of these short clutches fits and put the fan in a good spot within the shroud, otherwise a fixed 4 blade fan might be finding a home in it for racing. Been doing a lot of reading up on these clutches and the fans as well John. Right now, I'm leaning toward the 2947 clutch with a 7 blade fan unless someone convinces me that a different combo would be better. As I mentioned, I'm more concerned with cooling efficiency rather than hp loss. I use the Mopar Performance 5 blade works good for me . With an AFCO aluminium cross flow radiator and factory shroud . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3216856
02/28/24 05:02 PM
02/28/24 05:02 PM
68LAR
South Park, Pa.
This is a great subject, that came up at a good time, as I have been thinking about fans on my Factory Appearing build. I have a big block A body and standard its equipped with a 7 blade fixed fan with a 5/8" spacer , hoping that one of these short clutches fits and put the fan in a good spot within the shroud, otherwise a fixed 4 blade fan might be finding a home in it for racing. Been doing a lot of reading up on these clutches and the fans as well John. Right now, I'm leaning toward the 2947 clutch with a 7 blade fan unless someone convinces me that a different combo would be better. As I mentioned, I'm more concerned with cooling efficiency rather than hp loss. I use the Mopar Performance 5 blade works good for me . Tex I tried the MP 5 blade assembly a while back. Nice and quiet, lite, but didn't pull much air and hence, I had trouble keeping the engine cool. I believe it would be a good choice for a race only application. Not so much in a street/strip car. Again, just my 2 cents.
