Re: Who sells the big block A body exhaust manifold?
[Re: GODSCOUNTRY340]
#3212040
02/08/24 05:45 PM
02/08/24 05:45 PM
Posts: 8,650 fredericksburg,va
cudaman1969
fredericksburg,va
This is the C body manifold I have. (pic) Have it angle milled for outlet to tuck more to block then remove the outlet, weld in a 2-1/2” pipe with a flange. Accurate made one like that a few years back, worked nice. Might need a shield over factory starter.
[Re: cudaman1969]
#3212068
02/08/24 07:36 PM
02/08/24 07:36 PM
Posts: 43,843 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
This is the C body manifold I have. (pic) Have it angle milled for outlet to tuck more to block then remove the outlet, weld in a 2-1/2” pipe with a flange. Accurate made one like that a few years back, worked nice. Might need a shield over factory starter. I just sold my Accurate manifold for $1000 last year as I was never going to use it. Not sure if I have a picture of it available... Edit:: found a picture...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3212916
02/11/24 11:52 PM
02/11/24 11:52 PM
Posts: 5,126 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Mike you can make that with what you already have...
...FAFO...
[Re: skicker]
#3213149
02/12/24 11:10 PM
02/12/24 11:10 PM
Posts: 2,564 God's Country Maryland
GODSCOUNTRY340
Mike you can make that with what you already have... I wish someone had a pic with that manifold in relation to where it would dump out at the Z BAR! This is the main problem, it may fit an automatic car but what about a 4 speed car?
#3213162
02/13/24 02:22 AM
02/13/24 02:22 AM
Posts: 21,702 N.E. OHIO, USA
A12
N.E. OHIO, USA
Mike you can make that with what you already have... I wish someone had a pic with that manifold in relation to where it would dump out at the Z BAR! This is the main problem, it may fit an automatic car but what about a 4 speed car? I don't know if any of these photos will be of help or show what you need? This is my friend's M-Code 440 Dart that I have a lot of photos of but not exactly of what you may need? I'll include what I also have of the passenger's side exhaust manifold. Photo 4788 deliberately over exposed to show more down there. Mike
[Re: A12]
#3213196
02/13/24 11:15 AM
02/13/24 11:15 AM
Rhinodart
Rhinotruck
Rhinotruck
Which one(s) of these Is an original big block OEM exhaust manifold for the driver's side? They all are. The top one is the 017 M-Code 440 manifold, can't tell which year the middle picture is due to the angle but it is a 383 A-Body manifold, the bottom one is the 729 68-69 383 manifold.
A-Body's RULE!
#3213197
02/13/24 11:18 AM
02/13/24 11:18 AM
Rhinodart
Rhinotruck
Rhinotruck
Mike you can make that with what you already have... I wish someone had a pic with that manifold in relation to where it would dump out at the Z BAR! This is the main problem, it may fit an automatic car but what about a 4 speed car? I had that manifold on my 4-speed 69 GTS 383 and the bell crank cleared just fine.
A-Body's RULE!
[Re: Rhinodart]
#3213203
02/13/24 11:34 AM
02/13/24 11:34 AM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
Which one(s) of these Is an original big block OEM exhaust manifold for the driver's side? They all are. The top one is the 017 M-Code 440 manifold, can't tell which year the middle picture is due to the angle but it is a 383 A-Body manifold, the bottom one is the 729 68-69 383 manifold. Middle one appears to not have the #3 pipe indent so that would make it the 67 ?
Mainstream Media is the new Pravda
#3213204
02/13/24 11:35 AM
02/13/24 11:35 AM
JohnRR
A gulag near you.
Mike you can make that with what you already have... I wish someone had a pic with that manifold in relation to where it would dump out at the Z BAR! This is the main problem, it may fit an automatic car but what about a 4 speed car? If you're thinking of making it from your C body manifold you can position that pipe where every you'd want it to clear
[Re: JohnRR]
#3213210
02/13/24 12:45 PM
02/13/24 12:45 PM
Posts: 910 West Virginia
B1Frank
West Virginia
I had the same problem, went to a set of schumacher creative services headers that way to avoid the $$$ money hounds ! PS or not 4 speed or auto ........... hello brother Frank
[Re: B1Frank]
#3213299
02/13/24 08:20 PM
02/13/24 08:20 PM
Rhinodart
Rhinotruck
Rhinotruck
I had the same problem, went to a set of schumacher creative services headers that way to avoid the $$$ money hounds ! PS or not 4 speed or auto ........... hello brother Frank If you are doing a street machine no problem, but if you want a restoration then you have to buy the right parts. I have had quite a few big block A-Body's with hacked exhaust systems, no thanks!
A-Body's RULE!
[Re: Rhinodart]
#3214250
02/17/24 10:30 PM
02/17/24 10:30 PM
JohnRR
A gulag near you.
I snapped a couple pics of my modded manifold
[Re: JohnRR]
#3214494
02/18/24 11:48 PM
02/18/24 11:48 PM
GODSCOUNTRY340
Thanks for all the replies and pics. All the manifolds I tried dump right into the Z bar so I decided to go with the Wilwood/McLeod hydraulic clutch conversion. Not a direct bolt in kit, had to make a 35 degree firewall adapter to get the rod to line up with the clutch pedal attachment point. Looks like I'll be using the headers after all. The seller of the kit claimed I would have to cut up my firewall to get the master cylinder to line up with the pedal. I told them I wasn't hacking up my firewall, plus there was no way to mount it where it needed to be as it would run into either the brake master cylinder or the steering column mount at the firewall. They said they were actually made for Ford & Chevy vehicles and they weren't familiar with the kit installed on a Mopar A body and really couldn't give any recommendations on how to get it to work. I'll get a pic tomorrow on how I got it to line up.
[Re: A12]
#3214921
02/20/24 01:57 PM
02/20/24 01:57 PM
GODSCOUNTRY340
Here's the hydraulic throwout bearing being used. Need to add this, the directions say to have the bell attached to the engine and feed the trans with the throwout bearing with the hoses hooked to it through the hole in the bell. Well, they obviously have never tried this as the hydraulic throwout bearing with the hoses attached are bigger than the bell bearing retainer hole and will NOT go together like that. I had to remove the bell from the engine and angle it one way then another to get it to wiggle through, with the hoses OFF the throwout bearing.. So in reality, you have to have the bell hooked to the trans, then hook the hoses up and place them through the side of the bell to get it right. This would be a total PITA if done under the car.
#3214974
02/20/24 05:36 PM
02/20/24 05:36 PM
Rhinodart
Rhinotruck
Rhinotruck
Only difference in the 370 bellhousing to the 372 they used in the big block A-Body's was the hole for the clutch rod spring was missing on the 370 as far as I can tell...
A-Body's RULE!
#3215765
02/24/24 09:39 AM
02/24/24 09:39 AM
Posts: 3,371 Md.
carnut68
Md.
There's a pair of BB manifolds listed in the A body for sale section.
America First!
