Re: Clutch fan recommendation needed
[Re: 6PAX]
#3190605
11/13/23 12:53 PM
11/13/23 12:53 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I'm trying to choose a clutch fan for my 69 Dart and have several options available. Just got the engine in the car so it hasn't been driven yet. My engine is a 400/470 with 10.8 cr, Eddy heads, 727 and 3.73 gears. My radiator is a 3 core 22" factory radiator. I have a 195 degree thermostat installed. I have 3 fans with clutches to choose from. One is a factory 7 blade and clutch from a 67 GTX. The second is a factory 7 blade with aftermarket clutch (not sure of brand) from a 72 340 Duster and the third is the Mopar Performance 5 blade fan/clutch package. Which would you think would provide the best cooling? Have you tried to put any of them in there? The spacer used with a fixed fan is only 5/8" thick on a BB A body , if your engine and radiator are in factory locations there is not a lot of room. I imagine the factory would have put in a clutch fan if there was room ?
[Re: 6PAX]
#3190634
11/13/23 03:09 PM
11/13/23 03:09 PM
Posts: 5,448 So Cal
Sinitro
So Cal
Most clutch fans available today for Mopar are too tall if U have installed bigger radiator... I have a couple of short height(2.75") mopars with the closed WP hub if U require one. Just send me a PM if any further interest... Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: Sinitro]
#3190644
11/13/23 04:19 PM
11/13/23 04:19 PM
Posts: 5,663 Detroit area
6PAX
Detroit area
Most clutch fans available today for Mopar are too tall if U have installed bigger radiator... I have a couple of short height(2.75") mopars with the closed WP hub if U require one. Just send me a PM if any further interest...Just my $0.02... Thanks, I appreciate it. I will recheck everything again to see how far the fan blades go into the shroud as well as how much distance is between the fan blade and radiator fins. The radiator is a 22" 3 core from a 72 Duster or Dart as is the shroud..
[Re: 6PAX]
#3190649
11/13/23 04:34 PM
11/13/23 04:34 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Hayden do a short HD muscle car fan clutch . Stronger drive (less slip ?) than short Jag unit some use . I use this HD unit with Mopar 5 blade on my Satellite . I do use a manual control smallish electric fan on the front of radiator for the really hot days and heavy traffic .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3215332
02/22/24 11:49 AM
02/22/24 11:49 AM
6PAX
Detroit area
After taking some time away from it, I'm finally working on finishing up my engine cooling. Turns out with the radiator I ended up using that I am going to need a shorter fan clutch. The clutch I have is about 3 5/8" in depth. With it, the seven blade fan I am going to use sits all the way into the shroud to where the back edge of the blades are flush with the shroud opening. So, it looks like I will need a clutch less than three inches in depth to get the fan blade half in and half out of the shroud. Who sells clutches that are less than three inches in depth? Most clutch fans available today for Mopar are too tall if U have installed bigger radiator... I have a couple of short height(2.75") mopars with the closed WP hub if U require one. Just send me a PM if any further interest... Just my $0.02... I tried messaging you Sinitro but was unable to.
[Re: tex013]
#3215344
02/22/24 12:24 PM
02/22/24 12:24 PM
JohnRR
Tex hayden fan clutch If this is fairly cheap I may have to look into this , The fixed 7 blade I'm stuck with on my dart is a HP robbing POS
[Re: JohnRR]
#3215419
02/22/24 04:29 PM
02/22/24 04:29 PM
tex013
Sydney,Australia
bought mine @ Rockauto . Priced ok .
Tex
[Re: JohnRR]
#3215420
02/22/24 04:35 PM
02/22/24 04:35 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I use a Hayden Jag clutch with 7 blade fan. I use a 160* T Stat. Engine hardly ever reaches 160*. All fan clutches engage at around 180*. The degree of engagement is different from standard and heavy duty. If I recall, standard duty is about 60% engagement, while heavy duty is around 87% engagement
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: tex013]
#3215475
02/22/24 08:26 PM
02/22/24 08:26 PM
JohnRR
Tex I found it on rock auto , 49 and change but once you add in shipping it gets close to the amazon price of 59 with free shipping , still cheaper than summit at 69.99 plus the ride
[Re: 6PAX]
#3215477
02/22/24 08:27 PM
02/22/24 08:27 PM
JohnRR
I'm trying to choose a clutch fan for my 69 Dart and have several options available. Just got the engine in the car so it hasn't been driven yet. My engine is a 400/470 with 10.8 cr, Eddy heads, 727 and 3.73 gears. My radiator is a 3 core 22" factory radiator. I have a 195 degree thermostat installed. I have 3 fans with clutches to choose from. One is a factory 7 blade and clutch from a 67 GTX. The second is a factory 7 blade with aftermarket clutch (not sure of brand) from a 72 340 Duster and the third is the Mopar Performance 5 blade fan/clutch package. Which would you think would provide the best cooling? How much space do you have between the pulley face and the radiator , my car is apart so I can't measure it .
[Re: 68LAR]
#3215478
02/22/24 08:28 PM
02/22/24 08:28 PM
JohnRR
I use a Hayden Jag clutch with 7 blade fan. I use a 160* T Stat. Engine hardly ever reaches 160*. All fan clutches engage at around 180*. The degree of engagement is different from standard and heavy duty. If I recall, standard duty is about 60% engagement, while heavy duty is around 87% engagement What application is the Jag clutch for ?
[Re: JohnRR]
#3215498
02/22/24 09:25 PM
02/22/24 09:25 PM
6PAX
Detroit area
How much space do you have between the pullet face and the radiator , my car is apart so I can't measure it . 4 1/8"
[Re: 6PAX]
#3215554
02/23/24 10:05 AM
02/23/24 10:05 AM
JohnRR
How much space do you have between the pullet face and the radiator , my car is apart so I can't measure it . 4 1/8" Thanks , that hayden one should fit , I wonder if putting a thin spacer between it and the fan blade to move the blade back some , if it needs it , would cause a problem ?
[Re: 6PAX]
#3215608
02/23/24 01:14 PM
02/23/24 01:14 PM
JohnRR
I see that is the Hayden 2765 unit. I was reading a thread over on FABO where the Hayden 2947 unit was recommended. Does anyone have any experience as to which one is the better choice? They look pretty similar but the 2947 has a little large mount diameter. Good question , according to the specs on rockauto , the 2765 is about .050 shorter than the 2947 .
