Re: Moving leaf springs inboard
[Re: hemienvy]
#3214440
02/18/24 08:21 PM
02/18/24 08:21 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I don't understand why you would need offset rear hangers when you move the springs into the rails. I would think the easy and better way would be to use sliders instead of shackles. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hemienvy]
#3214441
02/18/24 08:21 PM
02/18/24 08:21 PM
Posts: 12,264 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I used a pre '71 B body housing. Fit fine and was cheap. On my Cuda, to take full advantage of the wheel well opening, I had custom back spaced wheels made. 10" rims with 275 or 295 tires fit fine.
Master, again and still
[Re: fourgearsavoy]
#3214452
02/18/24 08:54 PM
02/18/24 08:54 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I don't understand why you would need offset rear hangers when you move the springs into the rails. I would think the easy and better way would be to use sliders instead of shackles. Gus Agreed, plus if you use the rear offset , which moves the springs to the SIDE , how are you going to move it to the side in the front ? The offset is for people that don't want to cut the car I believe .
[Re: JohnRR]
#3214459
02/18/24 09:13 PM
02/18/24 09:13 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
My Challenger is mini tubbed, springs moved inboard with Caltracs and split mono leafs. Also squared the springs parallel to each other. My rear hangers are mounted to brackets on a chromoly tubular bar from frame rail to frame rail from the front. The bar serves three purposes. Ties the shackles as mentioned, my down bars in the trunk tie into this bar from the top through the trunk pan, and my parachute mount ties into it from the rear.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: hemienvy]
#3214474
02/18/24 10:04 PM
02/18/24 10:04 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
This is for E-body...
When you move the springs into the frame rails and use offset rear hangers, what is the new spring perch distance ? Center - to - center.
Factory E-body is 46". f you move the spring in 3" per side using the frame rail kit, the new perch center to center would be 40". If you move the front eye into the rails, there is a corresponding rear rail offset rail that allows the shackle to be the regular vertical kind. There is not a 3" offset shackle that allows the front eye to move into the frame rail while retaining the original shackle mounting point. If you look closely at the rear view in the linked USCT site, you will see this rear frame alteration. If you use the bolt in, 1" offset front hangers, which do not cut into the frame rail, you must also use the 1" offset shackle kit. Keep in mind that the rear frame rails in an E body are splayed wider at the rear. You can only move the wheel tub in about an inch, maybe 2, before you will now have frame rail interference, regardless of where your springs are located
[Re: TC@HP2]
#3214562
02/19/24 10:14 AM
02/19/24 10:14 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
When moving the spring that much, do you get into the rear valance with the shackle? I just used the good Dr's offset and had to 'massage' the relief in the rear pan for clearance.
[Re: hemienvy]
#3214571
02/19/24 11:13 AM
02/19/24 11:13 AM
TC@HP2
Pikes Peak Country
TC, curious have you done this operation on your E-body ? I evaluated both the 3" and 1" relocation. I elected to go 1". This is because it got the spring out of the way without needing to modify the wheel well or the frame rail. With this I change I have a 10" wheel with a 12"/305 metric tire and plenty of room everywhere. I have mocked up a 13.5"/335 metric tire that appears it would fit with a wheel with exact backspacing. If you look at the stock wheel well, there is around a 1-2" space between the rear edge of the well and the frame. If max tire size is the goal, splitting the well and installing the spacing strip, the USCT kit has this piece, would gain you that last 2 inches. In this case, a 15"/365 metric wide tire may be able to squeeze in there. Beyond that, you have to modify the frame rail. Don't forget we have a lot of the Direct Connection info along with some other members feedback in the Tech Section: http://www.moparts.org/Tech/Archive/rearsusp.html Look at the Rear Suspension Info, Spring Relocation (rear), and How to fit BIG tires on a Cuda.
[Re: TC@HP2]
#3214591
02/19/24 12:17 PM
02/19/24 12:17 PM
6PKRTSE
Motor City
TC, curious have you done this operation on your E-body ? I evaluated both the 3" and 1" relocation. I elected to go 1". This is because it got the spring out of the way without needing to modify the wheel well or the frame rail. With this I change I have a 10" wheel with a 12"/305 metric tire and plenty of room everywhere. I have mocked up a 13.5"/335 metric tire that appears it would fit with a wheel with exact backspacing. If you look at the stock wheel well, there is around a 1-2" space between the rear edge of the well and the frame. If max tire size is the goal, splitting the well and installing the spacing strip, the USCT kit has this piece, would gain you that last 2 inches. In this case, a 15"/365 metric wide tire may be able to squeeze in there. Beyond that, you have to modify the frame rail. Don't forget we have a lot of the Direct Connection info along with some other members feedback in the Tech Section: http://www.moparts.org/Tech/Archive/rearsusp.html Look at the Rear Suspension Info, Spring Relocation (rear), and How to fit BIG tires on a Cuda. Mine is moved in 3". It does not get into the rear valence. Here is a rear shot of my car done.
[Re: 6PKRTSE]
#3214639
02/19/24 02:36 PM
02/19/24 02:36 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Cuda vs Challenger maybe? Rear valances are very different in that area.
[Re: DaveRS23]
#3214641
02/19/24 02:40 PM
02/19/24 02:40 PM
6PKRTSE
Motor City
Cuda vs Challenger maybe? Rear valances are very different in that area. A Cuda may be different.
