Re: '14 JKU M-380 - "Kilroy"
[Re: Fat_Mike]
#3284218
01/22/25 10:47 AM
01/22/25 10:47 AM
Posts: 314 Falcon, CO
Mad-Max
Falcon, CO
yah having several 1, 2, and 3-foot sections laying around is pretty handy ok shop is cleaned up so back at it: the d-side half of the engine bracket was in the way of a bunch of stuff, and I'm not doing A/C, so removed it and gained a lot of nice clearance and simplifies things nicely - the alternator still has three big bolts securing the bracket to the engine nice n solid -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 52 Willys M-38 "Poncho"
[Re: Mad-Max]
#3284680
01/24/25 11:42 AM
01/24/25 11:42 AM
Mad-Max
Falcon, CO
...so my Sniper 2300 2bbl throttle body is rated at 580 cfm, but despite AFE telling me my air filter was rated at ~650 cfm I was still a little concerned that it was just a bit too small...so to assure myself it wasn't I made a template of the filter o.d. and flattened it out to compare it to the original filter for the engine (from an '02 Dakota), and sure enough it looks to be plenty big enough indeed - horray 👍
[Re: Fat_Mike]
#3285534
01/28/25 11:08 AM
01/28/25 11:08 AM
Mad-Max
Falcon, CO
