Re: A body BB to Hemi MM
[Re: mopar dave]
#3213158
02/13/24 12:12 AM
02/13/24 12:12 AM
Posts: 513 Temperance, MI
68 HEMI GTS
Temperance, MI
I may just do that. What all did you have to do to fit the Hemi? Lots….
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#3213173
02/13/24 07:39 AM
02/13/24 07:39 AM
Posts: 1,517 Martinsville, IN
cdwmotorsports
Martinsville, IN
I may just do that. What all did you have to do to fit the Hemi? Lots…. HAHA, that always sounded like a cool thing to have to me but what a packaging nightmare
eBay-cdwmotorsports
[Re: mopar dave]
#3213182
02/13/24 09:09 AM
02/13/24 09:09 AM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
One thing that will help is using bolts to hold the valve cover on instead of studs. Studs do make everything else easier though. You will have a little more movement w/o studs to help clear the fender.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3213192
02/13/24 09:47 AM
02/13/24 09:47 AM
Posts: 4,662 Motor City
6PKRTSE
Motor City
One thing that will help is using bolts to hold the valve cover on instead of studs. Studs do make everything else easier though. You will have a little more movement w/o studs to help clear the fender. Yes, I should have mentioned that also. My entire engine is mostly studded including the driver side rocker cover. Except for the passenger rocker cover for this very reason. I have 12 point s.s. ARP bolts in that cover.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: mopar dave]
#3213207
02/13/24 11:16 AM
02/13/24 11:16 AM
Posts: 2,767 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Gonna completely rebuild the front suspension using a tubular K, complete all the mods needed and strip and paint the engine bay body color, all but the firewall. I'm told I should space the K from the frame as well, but not sure how much spacer is needed for that. Some used 1/4" some 1/2", not sure what is really needed there. If you are using a tubular K-member I don't think you need to space it down at all. When they developed the Hemi A-bodies they said they did that to get room for the air horns.
2011 Drag Pak Challenger
[Re: topside]
#3213250
02/13/24 03:04 PM
02/13/24 03:04 PM
Posts: 3,206 Michigan
A727Tflite
No, the spacers were for carb clearance, which always seemed a bit odd to me. And my moving the K down, that likely put the right valve cover into the rt shock tower panel. Sorry if my earlier post was confusing in that regard. Yes, unless someone has limited hood clearance, you open a whole can of worms by using the k frame spacers. It made the early cars without the modified steering linkage all wonky running down the track.
[Re: A727Tflite]
#3213317
02/13/24 07:52 PM
02/13/24 07:52 PM
68 HEMI GTS
Temperance, MI
No, the spacers were for carb clearance, which always seemed a bit odd to me. And my moving the K down, that likely put the right valve cover into the rt shock tower panel. Sorry if my earlier post was confusing in that regard. Yes, unless someone has limited hood clearance, you open a whole can of worms by using the k frame spacers. It made the early cars without the modified steering linkage all wonky running down the track. Spacers provide header clearance to the steering linkage. Engine sits in the stock big block location. My car is a factory big block, that’s how I positioned the motor plate, hemi sits exactly where the factory 383 did. Without spacers the headers crash into the steering linkage. That’s true with the tti and hooker’s
[Re: 68 HEMI GTS]
#3214224
02/17/24 06:53 PM
02/17/24 06:53 PM
A727Tflite
No, the spacers were for carb clearance, which always seemed a bit odd to me. And my moving the K down, that likely put the right valve cover into the rt shock tower panel. Sorry if my earlier post was confusing in that regard. Yes, unless someone has limited hood clearance, you open a whole can of worms by using the k frame spacers. It made the early cars without the modified steering linkage all wonky running down the track. Spacers provide header clearance to the steering linkage. Engine sits in the stock big block location. My car is a factory big block, that’s how I positioned the motor plate, hemi sits exactly where the factory 383 did. Without spacers the headers crash into the steering linkage. That’s true with the tti and hooker’s The engine and k frame and steering move as a unit. Spacers do nothing for header clearance. Steering column is affected as it is fixed to the firewall but that can flex at the mounting flange.
[Re: mopar dave]
#3214254
02/17/24 10:06 PM
02/17/24 10:06 PM
A727Tflite
Someone told me the K spacers were for better handling and i might want to look it that. I know the spacers help nothing for header clearance. Eliminating the torsion bar is how you make room for headers, which im trying to do. I think those Hemi Denny torsion bar eliminators are the answer. Why has no one else ever came up with that simple design? All the other K member companies want to sell you a complete K member kit which eliminates the torsion bar for a large investment. Worst case scenario, TTI A body Hemi headers are designed for the factory K and steering and that is the way i will go if need be. The spacers were used to increase hood clearance. It actually made handling worse. That’s why Chrysler had to send out new tweaked steering components to the owners of the first cars shipped. The remainder of the cars had the parts already installed.
