Re: 440 Source Crankshaft journal diameters are very different. [Re: HardcoreB] #3211087
02/06/24 11:31 AM
02/06/24 11:31 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Originally Posted by HardcoreB
I measured an Ohio and it was pretty consistent FWIW.
I'd say less than .001 difference over all journals is pretty damn consistent !!
Re: 440 Source Crankshaft journal diameters are very different. [Re: Stanton] #3211095
02/06/24 12:36 PM
02/06/24 12:36 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
From what I hear the crankshaft manufactures are targeting low end of the spec or even slightly below to get the clearance where most performance builders what it. Most shoot for .001" for every inch of journal diameter so in our case .0028" clearance. If the journals where at nominal diameter it would probably be way to tight of a clearance.
Same for rod journals except that chevy journal sizes have a wider selection of under and oversized bearings.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: 440 Source Crankshaft journal diameters are very different. [Re: turbobitt] #3211108
02/06/24 01:38 PM
02/06/24 01:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I doubt it will be an issue for what you are doing. AS stated send it back if you feel like it but no guarantee the next one wont be different or "better".
Re: 440 Source Crankshaft journal diameters are very different. [Re: 19_Dart_68] #3211120
02/06/24 02:22 PM
02/06/24 02:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you haven't measured your clearances you haven't found a problem.
- Stu Harmon
Re: 440 Source Crankshaft journal diameters are very different. [Re: feets] #3211318
02/06/24 09:57 PM
02/06/24 09:57 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
wheres 440sourcedotcom you know they seen this what there answer ???
Re: 440 Source Crankshaft journal diameters are very different. [Re: HEMI472] #3211338
02/06/24 11:32 PM
02/06/24 11:32 PM
Pennsylvania
19_Dart_68 Offline OP
Pennsylvania
So, I was very wrong to be worried...and I am very impressed.
I went back over the crankshaft and re-measured everything. Made very sure I was getting the measurements using the same amount of drag across the journals with the mic...
Main Journal Measurements:
#1 - 2.7493
#2 - 2.7494
#3 - 2.7492
#4 - 2.7493
#5 - 2.7493
only .0002" variance between all journals
I set up my dial bore gauge off of each main journal measurement and came up with the following bearing clearances:
#1 - .0024
#2 - .0024
#3 - .0020
#4 - .0028
#5 - .0028
I'm going to swap the lower bearing halves for 1 and 2 with 4 and 5 and see what happens. Ran out of time tonight.
The issue is me being rusty, not the machine work.
68 Dart - 440 Swap in Progress...please stand by
Re: 440 Source Crankshaft journal diameters are very different. [Re: 19_Dart_68] #3211376
02/07/24 07:48 AM
02/07/24 07:48 AM
When in doubt, measure enough times to remove all DOUBT wrenchup bow grin
i like those measurements up
Good for you bow up
Re: 440 Source Crankshaft journal diameters are very different. [Re: Cab_Burge] #3211478
02/07/24 01:15 PM
02/07/24 01:15 PM
Pennsylvania
Pennsylvania
Good for you bow up
Yes sir! I also verified with a T-gauge and micrometer measurement...That was within .0002" of an inch of the direct measurements with the dial bore gauge...so definitely happy!
Hoping to get the mains switched around and re-checked and get the rods done tonight as well.
