drive shaft for my charger ?
#3210772
02/05/24 10:50 AM
02/05/24 10:50 AM
Posts: 19,641 north of coder
moparx
wanting to replace the driveshaft on my charger. 440/727/8 3/4 combo. the 8 3/4 will stay, and currently has a 741 case with 3.91 gears and a 7260 joint size yoke. the reason for a new shaft is the one front ear on the shaft has started to egg-out, with a just susceptible play noticeable. my plan is a billet or forged front yolk, 1350 joint sizes on both ends of the shaft, and a conversion 1350/7290 joint at the rear, as i have a 7290 yolk for the 741 case. [or i may spring for a quality 7290 yolk] what i am finding, however, is there are no solid 1350/7290 conversion joints out there. they all seem to be the greasable type. i would prefer a solid joint. i also want a high speed balance. [i think] denny's driveshafts offer a 10k rpm balance. i have also looked at doc diff's stuff as well. any thing i'm missing, or other suggestions ? TIA ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Re: drive shaft for my charger ?
[Re: moparx]
#3210790
02/05/24 12:00 PM
02/05/24 12:00 PM
Posts: 34,962 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
guess we are lucky here in my little town, we have a high quality torque tube builder here , I did buy a HD yoke from doctor diff
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3210793
02/05/24 12:04 PM
02/05/24 12:04 PM
moparx
there are a couple of shaft builders around here that are within 40 miles, but they are truck places, so their balance is only around 500-750rpm. that's why i'm asking about high speed balance. theirs might be ok for dirt burners, but not me. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#3210875
02/05/24 04:56 PM
02/05/24 04:56 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
wanting to replace the driveshaft on my charger. 440/727/8 3/4 combo. the 8 3/4 will stay, and currently has a 741 case with 3.91 gears and a 7260 joint size yoke. the reason for a new shaft is the one front ear on the shaft has started to egg-out, with a just susceptible play noticeable. my plan is a billet or forged front yolk, 1350 joint sizes on both ends of the shaft, and a conversion 1350/7290 joint at the rear, as i have a 7290 yolk for the 741 case. [or i may spring for a quality 7290 yolk] what i am finding, however, is there are no solid 1350/7290 conversion joints out there. they all seem to be the greasable type. i would prefer a solid joint. i also want a high speed balance. [i think] denny's driveshafts offer a 10k rpm balance. i have also looked at doc diff's stuff as well. any thing i'm missing, or other suggestions ? TIA ! If you are going to replace the rear yolk why not just get a 1350 yoke instead of doing the conversion u joint you are already changing out the yolk anyways.
[Re: JohnRR]
#3210917
02/05/24 07:29 PM
02/05/24 07:29 PM
Posts: 10,169 A Red State
SNK-EYZ
A Red State
wanting to replace the driveshaft on my charger. 440/727/8 3/4 combo. the 8 3/4 will stay, and currently has a 741 case with 3.91 gears and a 7260 joint size yoke. the reason for a new shaft is the one front ear on the shaft has started to egg-out, with a just susceptible play noticeable. my plan is a billet or forged front yolk, 1350 joint sizes on both ends of the shaft, and a conversion 1350/7290 joint at the rear, as i have a 7290 yolk for the 741 case. [or i may spring for a quality 7290 yolk] what i am finding, however, is there are no solid 1350/7290 conversion joints out there. they all seem to be the greasable type. i would prefer a solid joint. i also want a high speed balance. [i think] denny's driveshafts offer a 10k rpm balance. i have also looked at doc diff's stuff as well. any thing i'm missing, or other suggestions ? TIA ! If you are going to replace the rear yolk why not just get a 1350 yoke instead of doing the conversion u joint you are already changing out the yolk anyways. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) If you can get a 1350 size yoke for it why not go that route?
[Re: 67_Satellite]
#3211067
02/06/24 10:34 AM
02/06/24 10:34 AM
moparx
you guys are right, i might as well cough up for a 1350 yoke as well. the only reason i was thinking 7290, was i had one of those yolks on the shelf. i only want to do this once. this car is heavy, but it will never have lots of hp or dead hook, so by going overboard on a shaft, i shouldn't have to worry about this part for the rest of my time here. any suggestions on upgraded straps for the yoke ? what about ARP bolts for the yolk, or will common grade 8 bolts be ok ? ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#3211083
02/06/24 11:19 AM
02/06/24 11:19 AM
Posts: 22,734 Bitopia
jcc
Bitopia
Are the yokes different for 741 vs 742? I switched over to 1350's years ago on everything. Not sure I understand your need for a solid 1350, seems like a greaseable 1350 joint on the street has advantages. Also seems grade 8 is quite adequate for the application.
