Page 8 of 12 1 2 6 7 8 9 10 11 12
Re: 65 Coronet AWB build [Re: skicker] #3203517
01/10/24 12:05 AM
01/10/24 12:05 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I finished painting the dash today...
It's a little tricky trying to make it look like its old but have new paint on it...
It wasn't as shiny once everything dried...
Cleaned and painted the breathers also...
Almost all of the small parts to put this back together are painted and ready to go...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3203518
01/10/24 12:10 AM
01/10/24 12:10 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Drivers side 1/4 panel in progress...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3203734
01/10/24 11:48 PM
01/10/24 11:48 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I went to the body shop and took the steering column and the pedals out of the car today...
Completely disassembled the pedals...sanded and cleaned all the parts...then painted everything...
Put it all back together with new grease on the pivot points...
Steering column had to be fixed where the column shift lever was...
Don't tell anybody but the column and pedals were removed from a 3 on the tree 63 330 4 door car...
Got the column primed and painted with the steering wheel back on...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3203746
01/11/24 12:41 AM
01/11/24 12:41 AM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
Originally Posted by skicker
With no car here to work on it was back to finishing a lot of small parts...
I picked up this Tunnel Ram at Carlisle in July...
It is a Weiand but someone spent a bunch of time cutting all the extra aluminum out of it...
It needed some of the extra cast cleaned off of it and then blasted...
Sure did end up looking a lot different than one that is not modified...
Any chance you could post up the weight difference between the two? I'd be curious to know what all that work was worth beyond just doing it for looks. work
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 65 Coronet AWB build [Re: MadMopars] #3203747
01/11/24 12:42 AM
01/11/24 12:42 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Only about 6 lbs... work
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3203945
01/12/24 12:16 AM
01/12/24 12:16 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
More progress...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3204471
01/13/24 10:42 PM
01/13/24 10:42 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Still painting misc. parts...
Fuel filler neck and one of the front cage bars from the firewall to the frame...
Valve covers have been sanded and are ready for polish...
I never thought those old 4 bolt Offy's would clean up that nice... bow
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3204896
01/15/24 06:49 AM
01/15/24 06:49 AM
tboomer Offline
tboomer  Offline
Very nice build! up
Re: 65 Coronet AWB build [Re: tboomer] #3204905
01/15/24 08:36 AM
01/15/24 08:36 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Thx...
Really looking forward to getting this finished for this summer... runaway
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3206150
01/19/24 11:03 AM
01/19/24 11:03 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
More progress on the body work...
Some primer on the drivers side...
Once everything is ready it will get reprimed and blocked...
Working on the passenger side now...
Ordered a 65 AFX scoop from Larry at Sled City...
Axles on the way from Dr. Diff along with the 4 speed parts from Passon Performance...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3208682
01/28/24 10:11 AM
01/28/24 10:11 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Different pieces of the puzzle are coming together...
I went to the body shop and swapped out the 63 330 rear end housing for the original 65 one...
It has now been cleaned with the 4.11 gears installed...
Backing plates were assembled with the new axles from Cass also installed...
Brake lines are completed...
It's ready to go back into the car when it returns...
No pics of the finished unit... work
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3208684
01/28/24 10:16 AM
01/28/24 10:16 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Body work is ongoing...
Guide coat installed and removed on both sides of the car...
Body color for the stripe on the side was picked out and purchased...
It is nearly identical to the color on this oil can which matches pretty well with the other turquoise interior colors...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3208685
01/28/24 10:25 AM
01/28/24 10:25 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I got the Offy valve covers and the front wheels back from polishing...
He took the rear wheels and slicks to begin working on those...
As an additional surprise I got to hear the motor run on the run stand yesterday...
I should be picking it up this week...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3209152
01/30/24 09:38 AM
01/30/24 09:38 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Engine after break in on the run stand... up
I'll be picking it up today...
Need to get everything ready for paint and then install my tunnel ram and carbs
clutch pressure plate and bell housing and bolt on my "wedge" ears and into the chassis it will go once the car returns from paint...
Special thanks to Mike for the build on this... bow
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3209701
02/01/24 03:38 AM
02/01/24 03:38 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Motor is 95% together...
Going to hold off installing the tunnel ram till after it is in the car...
Waiting on some 4 bolt valve cover gaskets and a few other little parts and it is ready to drop in the car when it returns...
I also got the rear wheels back from polishing...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3210162
02/02/24 11:15 PM
02/02/24 11:15 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
The roll cage got painted the same color as the interior trim at the top of the door panels...
We sprayed the body colors on an old door and used a satin clear to see how everything will look...
The blue color looks more blue than it really is...
It actually matches the small can in the previous posts...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3210165
02/02/24 11:19 PM
02/02/24 11:19 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
The entire interior was sprayed with a heavy coat of primer prior to the cage being painted...
So everything in the interior and floors had to be sanded down...
That was another 10 hours worth of sanding...
Then the trunk and the interior were sprayed and cleared...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3210758
02/05/24 09:57 AM
02/05/24 09:57 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Saturday 2/3/24 makes 31 days the car has been in the body shop...
Plastic was draped through the interior above the cage in preparation for the roof to be painted...
Because of how far the rockers return on the bottom at the pinch weld we wanted to raise the car some for painting...
The roof rail trim install on 64-5 H/T separates the roof from the body...
It will be much easier to paint the roof 1st separately and then just cover it for the balance of the paint work...
The roof got a coat of sealer...then 3 coats of color and then 3 coats of clear...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3210761
02/05/24 10:04 AM
02/05/24 10:04 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
The paint color used is the 65 Dodge white...
We walked away from it at 4:00 pm on Saturday and left it alone until Sunday at noon...
I am using a Semi-Gloss clear as I don't want this to be a perfectly shiny new looking build...
It turned out right where I wanted it to be...
It has a nice sheen and will be very easy to clean and keep up with...
Peeled away the plastic and the tape and this what I have...
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #3210765
02/05/24 10:11 AM
02/05/24 10:11 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
In order to paint the balance of the body the first thing that will need done is to seal the body...
Then the color stripe on the side will need to be laid out and sprayed...
Tape up the color stripe and then shoot the entire balance of the body with 3 coats of white...
Then shoot 3 coats of semi gloss clear...
In order for everything to begin the entire frontend needed to reassembled and installed after all of the panels were primed...
Everything fit great and it looks like a car again...
Next Saturday is when the next paint day is scheduled...
...FAFO...
