Re: Holy Cow!1595.00 for tires/brakes on 2021 hyndai!
[Re: slantzilla]
#3209727
02/01/24 10:30 AM
02/01/24 10:30 AM
Posts: 10,762 North Dakota
6PakBee
North Dakota
10 years ago South Oak Dodge hit my ex with a bill for $600 for replacing shoes and drums on her 2010 Caliber. Labor alone was $300.
She took it in because one shoe squeaked against the backing plate when you put the brakes on. When she got it back it still squeaked. It seems no one can do anything right any more. The FSM directs you to lubricate the backing plate where the shoes ride.
[Re: 6PakBee]
#3209732
02/01/24 10:53 AM
02/01/24 10:53 AM
Posts: 3,461 Newburgh, NY
Old_Moparz
Newburgh, NY
This is so true ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif) Incompetence has taken over & getting worse. I left work one day & heard a noise in the front end of my truck. I'm only 3-1/2 miles from my office so I figured I'd get home, crawl underneath & take a look. Well, before I was halfway home I heard a much louder noise & felt a bad vibration in the steering. As much as I knew that the local Chrysler dealer would be expensive, it was right there so I pulled in & made the appointment to have them look at it. I also needed the annual state inspection which they can do, so it was easier to do it this way. The next day the service manager calls to tell me I passed inspection but that I need a new transfer case & a new rear axle housing. ![work work](/ubbthreads/images/graemlins/custom/work.gif) I said, "How can that be? The noise is in the front & the steering vibrated." He explained, "They found nothing wrong in the front & the vibration was being transferred from the transaxle to the frame so that's what you're probably feeling." Then he drops the bomb saying they want $6000 to fix it all. ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) I told him to forget it, I can't spend $6000 right now. I went in, paid for the inspection & had it towed to another shop that I usually go to. The other shop calls me & the guy says, "You have a broken front axle & there's nothing wrong with the transaxle or your rear. That'll be $800 total. And by the way we did your state inspection because it was overdue." The dealer did the inspection but never put the sticker on. ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif)
[Re: slantzilla]
#3209784
02/01/24 02:33 PM
02/01/24 02:33 PM
Posts: 2,279 ILLINOIS
volaredon
ILLINOIS
She took it in because one shoe squeaked against the backing plate when you put the brakes on. When she got it back it still squeaked. South oak Dodge... I worked there back around '89-90ish
[Re: GarageDodge]
#3209794
02/01/24 03:08 PM
02/01/24 03:08 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You can cut some rotors,depending the type&condition.I see alot of rotors so rusty they can not be cut.Most gm rotors chatter when you try to cut them. Many new cars have rotors that are surface hardened. It makes the initial surface last longer and the softer core helps reduce noise. If a tech cuts through the hardened surface the rotors will die quickly.
[Re: 67vertman]
#3209802
02/01/24 03:27 PM
02/01/24 03:27 PM
Posts: 21,546 N.E. OHIO, USA
A12
N.E. OHIO, USA
I just replaced the tires on my wife's Lexus LS 460. Michelin 235/50r18 - price was almost $1200, without mounting and balancing, plus disposal fees and taxes..... ![argue argue](/ubbthreads/images/graemlins/custom/argue.gif) Oh yeah, they also wanted to charge me for new valve stems and $12:50 for TPS removal and reinstall per tire..... A few months ago (Dec) I replaced my wife's (still in All Season tread wear condition) Dunlop Winter Force dedicated snow tires with Blizzak WS90 snow tires @ $268 each. Add on $125 mounting and balancing PLUS TAX and it's just a little over $1300. Replaced O.E.M. Brake rotors and pads for her GLK and that's over $600 in parts (discounted as MB parts manager in a long, long time friend) and I replaced them with my labor, didn't even think about asking the price if she had the MB shop do it. I'm guessing over a grand if the shop did them. Check with the dealer about doing a transmission service (filter, pan gasket, level spout and fluid) $772.00 ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) And milk WAS .25 cents and IT WAS DELIVERED TO YOUR DOORSTEP!! Nope it will never be the same, it is what it is and too many CYA costs included. Remember when a member tried to get a tire patched but the first dealer said NO. So we move on or we rant here ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: feets]
#3209921
02/02/24 12:16 AM
02/02/24 12:16 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
You can cut some rotors,depending the type&condition.I see alot of rotors so rusty they can not be cut.Most gm rotors chatter when you try to cut them. Many new cars have rotors that are surface hardened. It makes the initial surface last longer and the softer core helps reduce noise. If a tech cuts through the hardened surface the rotors will die quickly. That isn't a recent thing. My 90 Supercoupe had the same thing. Don't buy ford rotors. The aftermarket were actually better and that is just plain nuts ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif)
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Dcuda69]
#3210000
02/02/24 01:05 PM
02/02/24 01:05 PM
Posts: 11,455 NJ
rdrnr6970
Your #1 source for current events
NJ
You're wright!It's been nearly 20 years!! ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) lol! ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
[Re: A12]
#3210736
02/05/24 04:57 AM
02/05/24 04:57 AM
Posts: 4,809 Castlegar, BC, Canada
That AMC Guy
That's no shock. I recently paid over $1100 for four winters for my daily Hyundai. Cost us roughly that for four Cooper Cobras for the truck last summer.
I remember putting four Cooper Cobras on my AMC Hornet in 2002.... they were ON SALE.... $40 each. And I saved myself an additional $25.... because I took them to college with me and used the mounting machines we had in the shop. Buying tires never used to be such a production.
Brakes I do myself.
I'm even lucky enough to be getting a local tire shops' old equipment. Brake Lathe, Balancer, Tire machine and wash tank all for very good prices. I figure the tire machine and balancer will pay themselves off after 9-10 uses, since a change-over now costs minimum $125.
I'll also have one of the only brake lathes' in town. I went searching last summer for someone to turn a pair of drums for me and that's when I found out - nobody has one. The only place that DID have one, was this local tire shop.... and that's when they started offering me their old stuff.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: Dcuda69]
#3211403
02/07/24 10:04 AM
02/07/24 10:04 AM
Posts: 19,641 north of coder
moparx
luckily, i can turn drums and rotors on a "real" lathe when needed, as well as whittle out many other projects using said lathe and bridgeport mill. not many here can, or have access to real machinist equipment. having fabricated a manual tire changing machine 40+ years ago, it has served my needs well over the years. however, it's a real cardio workout now that i'm old. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) i have thought about purchasing a machine, but i haven't quite made up my mind. at my age, it might not be cost effective. the one thing about having one's own machine, you have total control over very expensive tires and wheels, thus damage to said items is greatly reduced by eliminating the "bubba" factor. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
