Re: Shock adjustment help needed, launch video
[Re: ksj]
#3209812
02/01/24 03:51 PM
02/01/24 03:51 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
Be curious to know where the 4 link is set up is at.
The "bog" I am sure is caused by the dead hook issues. Pulling the engine down. More RPM, less clutch etc will likely help with both.
[Re: ksj]
#3209815
02/01/24 03:57 PM
02/01/24 03:57 PM
Posts: 10,091 MN
JERICOGTX
MN
A torque converter would also be a good solution and it would get that pesky stick out of the way This is why no one will remember your name Claude... Savage reply. LOL. If he gets the reference, I'll buy him ice cream at Drag Week.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3209819
02/01/24 04:08 PM
02/01/24 04:08 PM
Posts: 3,596 Topeka Kansas
ksj
Topeka Kansas
A torque converter would also be a good solution and it would get that pesky stick out of the way This is why no one will remember your name Claude... Savage reply. LOL. If he gets the reference, I'll buy him ice cream at Drag Week. He should get it.
[Re: JERICOGTX]
#3209823
02/01/24 04:19 PM
02/01/24 04:19 PM
Posts: 8,079 Tulsa OK
Bad340fish
Tulsa OK
A torque converter would also be a good solution and it would get that pesky stick out of the way This is why no one will remember your name Claude... Savage reply. LOL. If he gets the reference, I'll buy him ice cream at Drag Week. Well you can save your ice cream money. I'll have to go get it from Bailey's ice cream truck if it happens to run long enough to make there.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3209844
02/01/24 05:39 PM
02/01/24 05:39 PM
Posts: 8,222 Plymouth, MI
Blusmbl
Plymouth, MI
Well you can save your ice cream money. I'll have to go get it from Bailey's ice cream truck if it happens to run long enough to make there. I got breakfast sandwiches, hot dogs, ice cream and water from the truck when it was on Sick Summer and Joe Barry was driving it…. before they ripped the gas tank out of it later in the week.
[Re: Blusmbl]
#3209852
02/01/24 06:01 PM
02/01/24 06:01 PM
Bad340fish
Tulsa OK
Well you can save your ice cream money. I'll have to go get it from Bailey's ice cream truck if it happens to run long enough to make there. I got breakfast sandwiches, hot dogs, ice cream and water from the truck when it was on Sick Summer and Joe Barry was driving it…. before they ripped the gas tank out of it later in the week. I think the rear axle failed on sick week last year, Joe got the gas tank, and the trans went out on Sick Week this year. Solid unit.
[Re: Bad340fish]
#3209884
02/01/24 09:26 PM
02/01/24 09:26 PM
Posts: 7,521 Minnesota
Hemi_Joel
Minnesota
For my past at Valdosta today, I took advice from this thread and loosened up the extension on the front shocks two clicks, tightened up the extension on the rear shocks three clicks, loosened up the clutch. Our group was last to run today and about 1:00 I was just two cars from the burnout box. I started the car and had zero oil pressure. It ended up to be a broken off oil pump drive shaft. So I need to tow it back to Minnesota and my racing is over until springtime. Then I'll get serious about getting this thing dialed in. Thanks for all your help everybody!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#3210190
02/03/24 02:33 AM
02/03/24 02:33 AM
Posts: 9,112 Rogue River, OR
Jeremiah
Rogue River, OR
Tightewn the extension to start on the rear....What is the rest of the rear suspension? The car has a 4 link rear. I run my rear shocks on the Road Runner, at full stiff on both Extension, and rebound. The more RPM, and harder I hit the tire, the faster it goes. I second the motion. If we back the launch RPM off to say 3k I can take some compression out of the rear shocks to get better weight transfer on a marginal surface. If you launch ot as god intended, at 4500-6000, it needs all of the shock it can get out back and as said it crushes the rear tires as launch RPM is increased.
