Re: Mopar Performance master cylinders with the plastic housing
[Re: calrobb2000]
#3208422
01/27/24 08:12 AM
01/27/24 08:12 AM
Posts: 4,753 Florida
BDW
You can buy from local parts store, I got mine from Advanced Auto, lifetime warranty. I'm using Diplomat application, manual brakes, 11.75 disc, with 11 drums.
[Re: BDW]
#3208428
01/27/24 08:54 AM
01/27/24 08:54 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
You can buy from local parts store, I got mime from Advanced Auto, lifetime warranty. I'm using Diplomat application, manual brakes, 11.75 disc, with 11 drums. This ^^^^ , the MP unit is the same as what was used on the production line .
[Re: JohnRR]
#3208483
01/27/24 01:06 PM
01/27/24 01:06 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
I would contact DrDiff. Tell him what brakes you have and let him recommend the correct Master Cylinder size. All depends on the size and number of the caliper pistons.
[Re: GomangoCuda]
#3208546
01/27/24 04:06 PM
01/27/24 04:06 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I would contact DrDiff. Tell him what brakes you have and let him recommend the correct Master Cylinder size. All depends on the size and number of the caliper pistons. Agree. That's where I got mine.
[Re: markz528]
#3208574
01/27/24 06:05 PM
01/27/24 06:05 PM
Posts: 5,931 ohio
ruderunner
ohio
Just to add, with 4 wheel disk, don't rule out fwd applications
Angry white pureblood male
[Re: calrobb2000]
#3208986
01/29/24 01:20 PM
01/29/24 01:20 PM
Posts: 2,405 Wichita,KS
Blakcharger440
Wichita,KS
hi smaller bore gives more stoping power but also causes longer pedal movement .
i tryed 15 / 16 and had pedal go close to floor so wound up using the 1.031 . 66 belvedere with a hemi , manual disc / rear drum . Thanks for posting this. I definitely want a short pedal movement as my pedal movement right now is way too long.
[Re: BDW]
#3208991
01/29/24 01:39 PM
01/29/24 01:39 PM
Blakcharger440
Wichita,KS
You can buy from local parts store, I got mine from Advanced Auto, lifetime warranty. I'm using Diplomat application, manual brakes, 11.75 disc, with 11 drums. Awesome information and reminder! However I will still need to purchase a adapter mount for the MP master cylinder because my power brake booster has the 4 stud mount and the current master cylinder having 4 holes like factory style for front disc/rear drum. I always thought that a smaller bore MC would give less brake pedal travel but it seems everyone here says the larger bore MC would actually give less travel of the brake pedal which is exactly what I want.
[Re: Blakcharger440]
#3209055
01/29/24 07:45 PM
01/29/24 07:45 PM
Posts: 2,956 GA
roadrunninMark
GA
Just as a reminder, those cheaper units at the parts store need to be modified if using a manual brake push rod (the ones under 1"). They don't have the slot for the retainer, and without the slot, the push rod can fall out and leave you without brakes. If you don't have the tools or know how to modify, like me, it is just easier to but the one that already has it done. If you do have that ability, then disregard.
As mentioned, call Dr Diff, he carries a couple different sizes and will help you decide. I have manual disc brakes so I went with 15/16", even with the 92 Viper front calipers. Also have 10.7 disc rear kit from the Doc.
