Re: Mopar 337 intake port question
[Re: Brad_Haak]
#3207461
01/23/24 11:32 AM
01/23/24 11:32 AM
Posts: 878 Pittsburgh, Pa
Jeff_383
Pittsburgh, Pa
522 bottom end (10.6-1), XTQ294 cam, TF240's, QF1050AN (4150). PTC 9.5, 3.91's. 3900lb B-body. Current Holley SD
[Re: Jeff_383]
#3207469
01/23/24 11:43 AM
01/23/24 11:43 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d say the basic combo would pick up power with the 337. How much of a gain there would be……..only one way to know for sure.
And…….the port mismatch is probably not going to help matters. But, it may not be the kiss of death either. Again, you’d have to try it to know.
I’ve tested BBC rectangle port manifolds on oval port heads(which is a huge mismatch) that picked up power over their oval port counterparts.
If the manifold is priced friendly enough, just try it. If it doesn’t do what you want……. Flip it.
[Re: fast68plymouth]
#3207473
01/23/24 11:51 AM
01/23/24 11:51 AM
Jeff_383
Pittsburgh, Pa
The price seems decent. I'll get it. This is the one we're talking about I hope.
[Re: Jeff_383]
#3207479
01/23/24 12:15 PM
01/23/24 12:15 PM
fast68plymouth
So. Burlington, Vt.
I haven’t had one in my shop in several years, but that looks right.
The stage 6 intakes are the same design, but are for raised port heads and are taller.
[Re: AndyF]
#3208204
01/26/24 12:37 AM
01/26/24 12:37 AM
Posts: 3,505 DFW
mr_340
DFW
I don't think people realized the 337 was any good until about the same time MP decided to quit making them. I don't know what they sold for new "way back when", but popular used BB Mopar intakes seem to be bringing good money these days. That was back when Zippy was still working at MP. They killed the 337 and then he talked them into bringing it back. I did some dyno tests with it for a magazine article and made really good power. They sold a few more after that and then killed it again. They really just didn't want to sell parts like that anymore no matter how good they were. I think Mopar Performance did a lousy job of marketing the 337 intake. I looked at it for years wondering if it would fit a 440 with MW heads. I wasn't willing to buy one to find out if that was the case. Andy finally bought one and published the results. I snagged one before they disappeared completely. Thanks to Andy for buying one and letting everyone know what it was.
Floyd Lippencott IV
[Re: Jeff_383]
#3208213
01/26/24 04:41 AM
01/26/24 04:41 AM
Posts: 3,262 Md.
carnut68
Md.
I was swapping parts with a guy in Pa and he had 3 of them on a shelf along with about a dozen other BB mopar intakes.
America First!
[Re: AndyF]
#3209957
02/02/24 09:24 AM
02/02/24 09:24 AM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Like has been suggested...take a hand file, use some tape, and a vacuum 'trunk monkey' and artfully remove any down-stream interference and it'll pick the combo up for certain. Make you efforts/expense worthwhile. If it makes you feel any better you should know at Roush we'd occasionally tickle NASCAR intake manifolds ON THE DYNO to help fuel distribution. And he'd use no vacuum but blast it with shop air for clean-up. If you knew the man, you'd know he'd sell his soul for a good running engine, at that time anyway.
[Re: Jeff_383]
#3210239
02/03/24 12:14 PM
02/03/24 12:14 PM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
That's encouraging, at least as a starting point. I bought a cheap(?) Harbor Freight bore scope for checking port alignment between intake and heads when installing 'em cuz you can't really see the full interface without sticking a scope way down the intake runner. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Jeff_383]
#3213249
02/13/24 04:03 PM
02/13/24 04:03 PM
Posts: 31,105 Oregon
AndyF
