Page 2 of 3 1 2 3
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3205731
01/17/24 07:17 PM
01/17/24 07:17 PM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
Here are the four (yes, apparently I had four) 143-tooth flywheels...
I have photographed and then rotated them to get as near as I can to having the 6-bolt pattern at the right angle: It now occurs to me that the 'datum line' I am seeking is the line through the pressure plate holes on the North/South axis, that it might be easier with this drilling location for those holes.
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3205735
01/17/24 07:37 PM
01/17/24 07:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mark you 130 tooth flywheel per the diagram. Bolt the 143 and the 130 together. Transfer the marking points from the 130 to the 143. The engine doesn't care what flywheel is on it. As long as the imballance is clocked right on the crank.
Doug
Re: How do I locate the 360 flywheel drilling? [Re: dvw] #3205758
01/17/24 08:41 PM
01/17/24 08:41 PM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
Interesting that you should mention that...
I don't know how you would bolt them together, nor transfer the marking points. I guess if you made a mandrel of some kind that fitted between the flywheels you could get them on the same axis.
Ultimately I think I might make a drilling jig based on this kind of idea, then I could repeat the process on both sizes of flywheel whenever I need to.
There'd be a lot of machining involved but I can take care of that.
Speaking of the flywheel sizes, here are a couple of 130-tooth flywheels I photographed as well: One is untouched (as far as 360 external balance is concerned) and the other is the one I had drilled in Spokane when I bought my van there. Unfortunately, that drilling isn't repeatable because the bottoms of the holes are round. Anyway, notice these have the different pressure plate bolt locations:
Edit: I've changed the second pic in this post as I realised it was a Slant flywheel. This one is a 318 flywheel, but maybe a 340 with the scallops and the ⅞" deep drillings in it. I have a couple with these deep drillings, the other having four of these holes (approximately ⅝" diameter) rather than the five in this one.
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3205762
01/17/24 08:44 PM
01/17/24 08:44 PM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
And here is moparmark's flywheel pic from page 1 with the flywheel rotated to the 'standard' position...
This is a 143-tooth flywheel I now realise.
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3205791
01/17/24 11:06 PM
01/17/24 11:06 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
It's a 143T from a 72-80 truck. I've parted out a lot of those over the years and I used to have several of these wheels. My 73 W200 360 has it's original wheel which is the same as this one. I don't have any other 143T wheels left but I do have an original 130T 360 wheel.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: How do I locate the 360 flywheel drilling? [Re: moparmarks] #3205810
01/18/24 04:33 AM
01/18/24 04:33 AM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
Thanks for that information, Mark...
I'd imagine there's a few of these hanging around places like Delta, Montrose and Grand Junction. While looking at different stuff, here's another flywheel I have, it's for a 9¼" clutch (slant or early 273?), it has the large holes drilled into it, but at a much greater distance from the centre than the 3.88" specified, more like 5.5":
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3205836
01/18/24 10:33 AM
01/18/24 10:33 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do you have a way to , or a shop that could , check the wheel you plan to use to confirm it is neutral balance before you attempt to drill it ?
Most of the flywheels you show all have been balanced for something except for the top left one in the post with 4 flywheels pictured ...
Re: How do I locate the 360 flywheel drilling? [Re: JohnRR] #3205917
01/18/24 03:19 PM
01/18/24 03:19 PM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
I'd have assumed all of them had some form of factory balancing done...
The location of the (relatively small) balancing marks is nowhere near the balancing necessary for externally balanced cranks.
Re: How do I locate the 360 flywheel drilling? [Re: John_Kunkel] #3205940
01/18/24 03:44 PM
01/18/24 03:44 PM
moparx Online content
moparx  Online Content
Originally Posted by John_Kunkel
Originally Posted by moparx
as a machinist, what bothers me, there is no mention of what angle the drill is sharpened to.
135* ? 118*? 90*? something else ?
I've been asking that for years...common consensus is 118 degrees which is considered the standard.
118* is standard.
if i had a factory flywheel to look at, i could easily determine the drill angle.
however, i'm an automatic guy, as i have never been able to speed shift a stick worth a hoot. laugh2
therefore, all my parts stash contains just "shift for you" items. biggrin
beer
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3205966
01/18/24 04:49 PM
01/18/24 04:49 PM
JohnRR Offline
JohnRR  Offline
Yes , the ones with the small scallops are more than likely the factory balance for neutral , the ones with the holes drilled are for some other balancing of some sort. I had a funny vibration in my 383 dart , when I had my machine shop cut the flywheel and check it balance it was way out and part of the reason was because at one point someone somewhere along the line cut the flywheel at an angle when resurfacing it , it was about .030 thinner on one side vs. the other.
If it were me ... and the shops around me were capable of doing it ... I would clean the wheel I want to use that I ASSuME is neutral, have it re surfaced .... if all the heat check marks were out of it then I would have it neutral balanced WITH the pressure plate I plan on using , then do the drilling for the external balance. When I have my neutral flywheels done it's with the pressure plate and the shop marks the 2 pieces of the assembly so I can assemble it as balanced .
Re: How do I locate the 360 flywheel drilling? [Re: JohnRR] #3206096
01/19/24 06:13 AM
01/19/24 06:13 AM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
I'm pretty happy now that I'll be able to use the first one, without any balancing marks and drill to the plan satisfactorily...
I have worked out how to make a drilling jig for the job and that's the way I think I'll go.
With regard to the other flywheels, to avoid any problems, I'd probably send them to a shop with a 360 crank and have it done there. The 130-tooth flywheels especially, I feel, need proving. Now that I look at my 'stocks' I'm surprised that I have so few unaltered flywheels. Or more to the point, so many which appear to have been altered.
When I get around to making the jig I'll post progress pics etc. Thanks very much to Mike (mkdart) for the additional help he gave me.
Re: How do I locate the 360 flywheel drilling? [Re: John_Kunkel] #3206103
01/19/24 07:56 AM
01/19/24 07:56 AM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
Quote
Hi John, over 11 years since we had a chat...
I have to work out properly what the drill is. As stated, it's an unused one as far as I know, there are no marks at all on the fluting and it otherwise looks like it's been lying around without any use at all.
Trying to calculate the angle from a photo I find it's very hard to do this. I got 132° using this method, but it is fraught with variables.
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3206106
01/19/24 08:43 AM
01/19/24 08:43 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have to laugh, all these variables and you guys are worried about the angle of the bit...... laugh2
Re: How do I locate the 360 flywheel drilling? [Re: B1MAXX] #3206225
01/19/24 02:53 PM
01/19/24 02:53 PM
looks like a 135* bit.
beer
Re: How do I locate the 360 flywheel drilling? [Re: B1MAXX] #3206732
01/21/24 06:23 AM
01/21/24 06:23 AM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
Quote
Which variables?
I don't think there are any variables, it's all pretty exact. Which makes asking about that angle relevant.
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3206755
01/21/24 09:59 AM
01/21/24 09:59 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Just how close do think any of this stuff will be (factory balance)? I can tell you from balancing crankshafts that the tip of that bits angle will be insignificant compared to the overall bobweight. I'm sure the rods are out further than the difference in point angles.
If you are trying to duplicate a factory tolerance just drill the holes was my point smoke. They are notoriously horrible which is why the point angle is not worth debating.
Re: How do I locate the 360 flywheel drilling? [Re: Phoenix] #3206837
01/21/24 01:17 PM
01/21/24 01:17 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Since you have examples, you could obtain “real numbers” on the unbalance weights needed, by spinning those flywheels on a balance machine.
Electric motor repair shops usually have balance measuring machines for large rotors.
Hunter computerized tire and wheel balance machines could calculate a result if an adapter can adjust to flywheel center hole.
You correctly are trying to “get the correct balance.”
By knowing the numerical imbalance you could drill slightly smaller balance holes in the flywheel, then “dial in” a nearly exact balance by enlarging the holes.
There has to be matching “bob weight correction” at the other end of the engine.
When balancing large electric motor rotors it is very common that the two shaft ends need different weight corrections for smooth high speed rpms.
Re: How do I locate the 360 flywheel drilling? [Re: 360view] #3206859
01/21/24 02:09 PM
01/21/24 02:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
just drill the holes, some of those engines would rattle your fillings out from new.
They were never a precision balance.
Re: How do I locate the 360 flywheel drilling? [Re: 360view] #3206871
01/21/24 02:45 PM
01/21/24 02:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
To do that assumes all the pistons, rod small ends, rod big ends, crank weigh the same to start with. Which is not case from the factory.
Doug
Re: How do I locate the 360 flywheel drilling? [Re: B1MAXX] #3206942
01/21/24 05:56 PM
01/21/24 05:56 PM
The Summit
Phoenix Offline OP
Phoenix  Offline OP
The Summit
Quote
That's fine...
Now I know that if I do the best job I can it will be all that's needed. And I intend doing the best job I can.
Just reading up on the drill tip angles, it would seem to me very likely that the 135° angle is the one. All the stuff I read suggests that the 118° drill is most efficient in 'soft metals' and cites aluminium as the standard there while the 135° drills come into play in harder metals. And while it would be nice to know just to be more correct, it's also good to know that my tooth fillings are likely to stay in as I cruise the B350 at 2,500rpm.
This discussion has pretty much forced me to add an avatar to my membership here... here's the full picture which really identifies that it's important for me to get things right as I work on this van:
Page 2 of 3 1 2 3
