Page 7 of 8 1 2 3 4 5 6 7 8
Re: 572 all aluminum headed to dyno [Re: Al_Alguire] #3030955
04/05/22 02:45 PM
04/05/22 02:45 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I did not know that. Interesting.
69 GTX 68 Road Runner
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036407
04/23/22 06:13 PM
04/23/22 06:13 PM
AndyF Offline OP
AndyF  Offline OP
Belvedere was back at the track today making passes. First pass he hooked up and the car went way up into the air. Scared the driver a bit since the car had never gone that high. Front was probably 4 or 5 feet in the air. Next pass he lowered the two step too much and the car bogged off the line. So it is a work in progress.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036423
04/23/22 07:05 PM
04/23/22 07:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Only made two passes?
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3036434
04/23/22 07:32 PM
04/23/22 07:32 PM
AndyF Offline OP
AndyF  Offline OP
They were still racing when I left. Even with the bog off the line he ran a 9.30 so once he gets the launch sorted out he should pick up some.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036459
04/23/22 09:20 PM
04/23/22 09:20 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looks like the car would benefit from an anti roll bar.
Re: 572 all aluminum headed to dyno [Re: JERICOGTX] #3036479
04/23/22 10:35 PM
04/23/22 10:35 PM
AndyF Offline OP
AndyF  Offline OP
Yeah they were talking about that. I think they are going to put wheelie bars on it and add a rear anti-roll bar.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036630
04/24/22 04:04 PM
04/24/22 04:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Definitely NEEDS an anti roll. Lots of ways t tune a wheelie out and if only using them as a "safety" device will be just bad as tuning the wheelie out on performance.
Re: 572 all aluminum headed to dyno [Re: 572B1] #3036633
04/24/22 04:19 PM
04/24/22 04:19 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by 572B1
Thats about 772 hp at the engine. going by the wallace calculator.
Ran a 9.27 today without any changes to the engine.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036697
04/24/22 08:06 PM
04/24/22 08:06 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Getting there Andy. 794 hp what was the best mph?
Re: 572 all aluminum headed to dyno [Re: 572B1] #3036706
04/24/22 08:38 PM
04/24/22 08:38 PM
AndyF Offline OP
AndyF  Offline OP
145 mph. Wallace says 850 hp, Moroso slide rule says 810 hp. I don't think the calculators are correct yet since the car isn't dialed in. The driver is still working on the best launch RPM as well as shift points. The chassis hasn't been fully sorted out either.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036873
04/25/22 10:45 AM
04/25/22 10:45 AM
So. Burlington, Vt.
So. Burlington, Vt.
I thought the race weight was in the 3200lb range??
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3036896
04/25/22 11:16 AM
04/25/22 11:16 AM
AndyF Offline OP
AndyF  Offline OP
I posted that the car weighs 3000 lbs
Re: 572 all aluminum headed to dyno [Re: AndyF] #3036942
04/25/22 12:57 PM
04/25/22 12:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
So, 3000+ driver.
I guesstimated 3200........ I suppose that could also be 3300, or more.
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3036958
04/25/22 01:41 PM
04/25/22 01:41 PM
AndyF Offline OP
AndyF  Offline OP
Yep, driver is a very big guy.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3205060
01/15/24 09:22 PM
01/15/24 09:22 PM
AndyF Offline OP
AndyF  Offline OP
The Big EZ heads made it two seasons before they developed leaks in multiple intake ports. So we're looking at different options. Looks like the best bet is to step up to a set of 440-1 castings with the 345cc porting package. We'll have the heads cut to the same 74 cc combustion chamber so the CR stays the same. Hopefully valve to piston stays the same but that will need to be checked. Hopefully the valves, springs, rocker arms, etc. all swap over from the Big EZ heads to the -1 heads. As far as I can tell everything will swap over, but I could be overlooking something.
Re: 572 all aluminum headed to dyno [Re: AndyF] #3205162
01/16/24 09:50 AM
01/16/24 09:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I was of the assumption that the intake port of the EZ was the same as the -1. The difference between the two being the exhaust port height. I have to say I wouldn't be happy with multiple intake port leaks after 2 years of use.
Doug
Re: 572 all aluminum headed to dyno [Re: dvw] #3205187
01/16/24 10:41 AM
01/16/24 10:41 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Oooof! that's not right. Hope there is some restitution for you. Do they leak OIL or COOLANT? What MPH/ET did the car wind-up running? Probably not great MPH because it's not the most aerodynamic set-up.
Re: 572 all aluminum headed to dyno [Re: HardcoreB] #3205208
01/16/24 11:32 AM
01/16/24 11:32 AM
So. Burlington, Vt.
So. Burlington, Vt.
The cnc345 is really better with a 2.25” intake valve.
Were those used in the EZ heads?
Re: 572 all aluminum headed to dyno [Re: HardcoreB] #3205213
01/16/24 11:43 AM
01/16/24 11:43 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Doug
As cast, the EZ head has its own unique port shapes not shared with the other models. The floor is higher than a -1, with a much more rounded approach to the SSR, and a larger SSR radius.
I do believe the ez325 and the -1 325 utilize the same cnc program in the intake ports(I’m not certain of this since I haven’t had a pair of each here in the shop at the same time), which removes quite a bit of material from the EZ floor.
Re: 572 all aluminum headed to dyno [Re: fast68plymouth] #3205219
01/16/24 12:01 PM
01/16/24 12:01 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Agreed...the -1 345 SHOULD have the 2.25" And IIRC AndyF said his had the 2.25 installed by BEST. Wonder if they use the 'SR' INTAKE port with a lower exhaust? Randy has the cnc '345' -1 Indys with 2.25" Intakes on his jalopy with a SMALL/gentle cam you spec'd. 540" 12.9:1 It showed about 146 or so MPH so far @ 3300lbs. But there's definitely room for more in it's performance.
