Re: Almost had a disaster, need a solution
[Re: TJP]
#3205907
01/18/24 03:02 PM
01/18/24 03:02 PM
Posts: 20,380 north of coder
moparx
those awful sounding door is [not] a jar buzzers work great for use in diagnosing/trouble shooting/installing [new] wiring components as a means to see or find which wires are hot or shorted to ground. i have several in my box with different clips and/or terminals i have used for many years. they work great, especially when working by yourself, as i most often do.
Re: Almost had a disaster, need a solution (almost fixed)
[Re: moparx]
#3206273
01/19/24 05:11 PM
01/19/24 05:11 PM
Posts: 4,901 Florida
BDW
I think I got it, bought an A-body safety latch off Ebay, only $30. Much cheaper than an E-body part, and was hoping it's shorter, but not the case. My hood already had holes for the latch, but the header panel is much lower for some reason, so the latch contacted the catch opening before fully closing. I relocated my trans cooler down 1", cut down the latch by 1", and trimmed the latch hook radius so it doesn't interfere. But this things works! Hood comes up 4-5" and catches. It's not pretty, I wish I could weld, but it will do for now. Now if I just had the balls to try it without the pins in...........
[Re: BDW]
#3206373
01/19/24 10:47 PM
01/19/24 10:47 PM
Posts: 15,928 Omaha Ne
TJP
Omaha Ne
Re: Almost had a disaster, need a solution (Fixed)
[Re: stumpy]
#3206376
01/19/24 10:50 PM
01/19/24 10:50 PM
TJP
Omaha Ne
Not to be negitive but If the hood is lifted up with a bit of force that fiberglass holding the saftey latch is a goner. Do NOTE "My hood already had holes for the latch," that would depend on the strength of the fiberglass and how it's attached. I'm thinking the glass is pretty thick /strong in that area. Looking at the nearby holes seems to confirm that If not it can be reinforced several ways.
[Re: BDW]
#3206418
01/20/24 03:17 AM
01/20/24 03:17 AM
Posts: 43,808 Bend,OR USA
Cab_Burge
Why would you want to try it without the pins , why? NOT ME
[Re: IMGTX]
#3206552
01/20/24 03:58 PM
01/20/24 03:58 PM
moparx
Looks good. You did the hard part.
Should be someone in your circle that can weld. If not then mail it to someone here who can do it and send it back to you.
That is a small weld job. Wouldn't take much. easy-peasy job for sure. could be taken apart at the rivets, a piece added for the correct length, a filler piece added in the front, then weld the piece[s] together, making it appear as a single piece.
[Re: stumpy]
#3206652
01/20/24 08:31 PM
01/20/24 08:31 PM
BDW
Not to be negitive but If the hood is lifted up with a bit of force that fiberglass holding the saftey latch is a goner. That's a good point, hadn't thought of that. The fiberglass header portion is pretty thick, but I'm pretty sure it would be be good for <50mph. Up at highway speed, 70-80mph, probably gonna be a problem. So you got me thinking, I might need that pressure switch to trigger a buzzer deal to really idiot proof this thing. Buzzer will go off immediately, and the latch will give me enough time to slow down. I'm getting trained to look for that pink ribbon, so all this may be unnecessary, but then again, never thought it would have happened in the first place. I appreciate all the replies, wealth of knowledge here is awesome!
[Re: TJP]
#3206693
01/21/24 12:17 AM
01/21/24 12:17 AM
Posts: 10,219 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I would suggest 2 TWO as in 2 rubber tarp straps.... I can attest if you only use one it will let you down at some point.
STOP POTATO HATE!
