Re: T/A and AAR Side Exhaust...Why???
[Re: Flat-Tappet]
#3206020
01/18/24 08:18 PM
01/18/24 08:18 PM
Posts: 22,724 Bitopia
jcc
Bitopia
Side exhausts are used in road racing, primarily for safety during refueling at a pit stop. It keeps the exhaust exits away from the fuel cell and the fuel filler located at the rear of the car. I copied the T/A AAR exhaust routing with mufflers for my Mustang, now made street legal after many years as race-only. You have a very nice car, and this your second post, so I will be very gentle, but I disagree.
[Re: moparx]
#3206022
01/18/24 08:22 PM
01/18/24 08:22 PM
jcc
Bitopia
nicely done mustang ! if i may ask, on the jack locator on the rear end housing, what is the cotter pin's purpose, and the square item [retained by the cotter pin perhaps ?] in the center of the locator use for? In road racing, an analog tracking device for high speed off track excursions?
[Re: topside]
#3206034
01/18/24 08:57 PM
01/18/24 08:57 PM
Posts: 7 CT & ME
Flat-Tappet
CT & ME
Yup, likely a combination drain plug & jacking point. Plug pinned to prevent unwanted loosening. Yes, that’s it.
[Re: jcc]
#3206037
01/18/24 09:08 PM
01/18/24 09:08 PM
Posts: 7 CT & ME
Flat-Tappet
CT & ME
Side exhausts are used in road racing, primarily for safety during refueling at a pit stop. It keeps the exhaust exits away from the fuel cell and the fuel filler located at the rear of the car. I copied the T/A AAR exhaust routing with mufflers for my Mustang, now made street legal after many years as race-only. You have a very nice car, and this your second post, so I will be very gentle, but I disagree. Thanks, it’s been a 28 year journey with this car, and loads of fun. I’m curious to hear your thoughts as to why you disagree. Below is a photo of a hot pit refueling of the Sunoco Camaro that drove the point home -for me anyway. Several early Ferraris with rear exit exhausts had a protective horizontal flange of sheet metal over the pipes exit to prevent refueling spills from hitting the exhaust tips directly.
[Re: Flat-Tappet]
#3206057
01/18/24 10:59 PM
01/18/24 10:59 PM
jcc
Bitopia
Since you asked, our biggest difference here centers around your use of "primarily". My first counterpoint is if safety indeed was a motivation, the lack of any fire suit, goggles, gloves, no socks, and the amount of gas regularly spilled in pit stops, safety seemed to be of minor concern in the big picture IMO, and there are a number of other advantages side exhaust provide that would go more toward winning races, which again IMO was the "primary" concern. I suspect that pavement wetness pictured might be from spilled fuel as is the feeble attempt at the use of safety dri? Although there is a crew barely shown with a water? hose aimed at the refueler just in case. Speaking of old pictures, my favorite related fueling pic is at Sebring with a Ferrari team using a very large galvanized wide open top funnel to dump fuel in in the trunk area for a refueling pit stop BTW, is that Roger Penske at the RF kneeling?
[Re: topside]
#3206102
01/19/24 07:17 AM
01/19/24 07:17 AM
jcc
Bitopia
It looks like a typical semi gas tanker hose set-up. Typical Roger.
[Re: topside]
#3206362
01/19/24 10:01 PM
01/19/24 10:01 PM
Posts: 7 CT & ME
Flat-Tappet
CT & ME
Yup, that's Roger - he typically released his cars in that era. That fueling hose may be attached to the huge gravity-fed rig they ran that year, which IIRC, SCCA eventually banned. Filled the car VERY quickly...but could make a mess... I’ve always admired Roger Penske and his outside of the box thinking. His team chilled the fuel in that big gravity rig you described using dry ice to make it more dense, and blew it through that ginormous hose into the cell in a matter of seconds. I believe they were filling a 24 gallon cell in just a few seconds. In addition to speed of refueling, they were able to pack a few percent more fuel into the cell when compared to others fueling up at ambient summer temps. I read Mark Donohue’s book “Unfair Advantage” many years ago. And I recall he touched on this refueling topic in it. It’s a great read.
[Re: moparx]
#3206364
01/19/24 10:10 PM
01/19/24 10:10 PM
Posts: 7 CT & ME
Flat-Tappet
CT & ME
Yup, likely a combination drain plug & jacking point. Plug pinned to prevent unwanted loosening. Yes, that’s it. never gave that a thought ! thanks for pointing that out guys ! you learned an old guy something, now if i can just put it somewhere i can remember it....... Yes, that plug and Jack point combo allows you to drain all the oil out of a 9” rear without removing the pumpkin, while also giving some protection for that low hanging plug And in road racing, I’m changing it every couple of events. I believe there a lot of opportunity for “cross pollinating” of ideas between road race and my newfound interest in big Mopar stuff and vice versa.
[Re: Flat-Tappet]
#3206379
01/19/24 11:04 PM
01/19/24 11:04 PM
jcc
Bitopia
I personally have a tough time accepting the loss of 1" of sacred hard earned ground clearance with something likely rather adept at catching on something all for the convenience of a jack point.
[Re: topside]
#3206400
01/20/24 12:05 AM
01/20/24 12:05 AM
jcc
Bitopia
So we agree, no need for the drain plug protector aspect? BTW, have you ever left the track at say 100mph only partially under control in a lowered car with some DF, for any number of reasons?
[Re: A12]
#3206452
01/20/24 11:08 AM
01/20/24 11:08 AM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I know it was factory and one of the things that makes these cars unique. I personally have never been a fan of the look. Just looks cheap to me and outcof place.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
