Page 2 of 3 1 2 3
Re: 632 dyno time [Re: hemienvy] #3203046
01/07/24 06:18 PM
01/07/24 06:18 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by hemienvy
Maybe one last question, what is the intake lobe centerline set at ?
OK maybe one more, what does the ignition timing curve look like ?
No idea on lobe centerline. It is whatever GM set it at. There is no easy way to check this stuff since the engine doesn't even have a TDC pointer. You can't set the timing on the engine since you don't know what it is. You just have to trust that GM built it correctly.
The ignition curve in the engine at the moment 25 at idle and 32 at WOT. There is another 6 degrees of vacuum advance built in. But who knows what the actual timing is since we can't check it.
Re: 632 dyno time [Re: Dragula] #3203050
01/07/24 06:24 PM
01/07/24 06:24 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by Dragula
When you have a big throttle body, it makes the throttle tip in very sensitive. Maybe even un-drivable if its a street car. I prefer, on any engine making north of 650hp, to use a progressive TB...Like a four barrel with progressive linkage. Drivability will improve. An engine will only use the amount of air it needs, no matter how big the TB is, so one that is sized a little better will give you better control. Just my 2 cents....
PS...That is the best bang for the buck engine out there right now. Thought about putting one in my Duster. Very well thought out engine, and the power it makes shows this.
It is the best bang for the buck. I've worked on a few 1000 hp engine projects and this engine at $30,000 makes more power than last several projects I saw which all cost well over $40,000. Most of that is due to the fact that this is a factory designed engine that has been tested and debugged by experts. Customers who want 1000 hp sometimes don't know exactly how to get there so they waste money on the wrong parts.
Re: 632 dyno time [Re: AndyF] #3203100
01/07/24 09:10 PM
01/07/24 09:10 PM
I hope your customer has the skills needed to drive that motor on the streets luck up work
Some do, some don't shruggy
Re: 632 dyno time [Re: Cab_Burge] #3203193
01/08/24 12:59 PM
01/08/24 12:59 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Thanks much Andy !
Re: 632 dyno time [Re: AndyF] #3203272
01/08/24 06:45 PM
01/08/24 06:45 PM
AndyF Offline OP
AndyF  Offline OP
Best power was 1060 hp at 6700 rpm and 910 torque at 5900 rpm. It is going in a tube chassis 57 Chevy that weighs around 2800 with driver. Should run pretty good. Bracket car so he'll mess around with a delay box or whatever to get it to run the way he wants it to run.
Re: 632 dyno time [Re: AndyF] #3203284
01/08/24 07:27 PM
01/08/24 07:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Plenty to run bottom 8's with
Re: 632 dyno time [Re: Al_Alguire] #3203311
01/08/24 09:33 PM
01/08/24 09:33 PM
gregsdart Offline
gregsdart  Offline
My WAG,,,, 8 TEENS AT 160?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: 632 dyno time [Re: Cab_Burge] #3203333
01/08/24 11:12 PM
01/08/24 11:12 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
It's good it lived up to its power rating. We did a zz572/620 hp swap into a car that was pretty quick with a small block chev and that 572 was a dud.
Re: 632 dyno time [Re: Uberpube] #3203346
01/09/24 12:17 AM
01/09/24 12:17 AM
Why?
What was wrong with it?
I'm getting ready to order a BB Chevy pump gas crate motor with 700+ HP and don't want to make any mistakes on getting the best one for my customer on the first order luck help up
Re: 632 dyno time [Re: AndyF] #3203434
01/09/24 03:23 PM
01/09/24 03:23 PM
Chicago-area Illinois
4mopower Offline
4mopower  Offline
Andy, how was the AF distribution with that intake? Cylinder to Cylinder?
Re: 632 dyno time [Re: 4mopower] #3203436
01/09/24 03:30 PM
01/09/24 03:30 PM
AndyF Offline OP
AndyF  Offline OP
EGT's look good for what this worth. Customer has custom headers in the drag car with O2 sensor in each head pipe so we'll see what they say and go from there. One the dyno we only had one O2 sensor per side.
Re: 632 dyno time [Re: AndyF] #3203455
01/09/24 05:40 PM
01/09/24 05:40 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Does the ecu that comes with that engine do individual cylinder correction? Would love to see the software that comes with it.
Joe
Without Data, you’re just another guy with an opinion.
Re: 632 dyno time [Re: sr4440] #3203456
01/09/24 06:05 PM
01/09/24 06:05 PM
AndyF Offline OP
AndyF  Offline OP
Yes, it can do individual fuel correction since it has an injector in each runner. It can also do individual cylinder timing since there are 8 coils. So each cylinder can be tuned by itself if you have enough data to know what to do. For the dyno we ran all cylinders the same since we didn't have individual cylinder information.
Re: 632 dyno time [Re: sr4440] #3203472
01/09/24 06:42 PM
01/09/24 06:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Joe
I think it is a Holley terminator system so I doubt it. I am not sure any of the Holley products can correct individual cylinders.
68 Barracuda Formula S 340
Re: 632 dyno time [Re: AndyF] #3203479
01/09/24 07:52 PM
01/09/24 07:52 PM
AndyF Offline OP
AndyF  Offline OP
Video of one of the dyno pulls: https://youtu.be/2OqE1TnDf4M
Re: 632 dyno time [Re: Cab_Burge] #3203519
01/10/24 12:14 AM
01/10/24 12:14 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Why?
It just felt lazy, like it didn't have enough compression for the cam, It sounded good, ran good, but was underwhelming for the size of the engine.
Re: 632 dyno time [Re: Uberpube] #3203561
01/10/24 12:13 PM
01/10/24 12:13 PM
AndyF Offline OP
AndyF  Offline OP
I have a buddy with a crate 572 in his Camaro. It runs low 9's. Those engines can make pretty good power but they'll never make great power since the heads are small. Basically just an Edelbrock head. But they'll make 700+ hp with the right mixture of cam and compression.
Re: 632 dyno time [Re: Bad340fish] #3203566
01/10/24 12:22 PM
01/10/24 12:22 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I think terminator x, HP and Dominator have it.
Re: 632 dyno time [Re: INTMD8] #3203571
01/10/24 01:18 PM
01/10/24 01:18 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Yes, that is individual fuel trim, which is not the same as having 8 o2's and having the computer make adjustments, up and down, so they are all at the targeted AFR throughout the rpm range. IE closed loop correction by cylinder.
Re: 632 dyno time [Re: sr4440] #3203578
01/10/24 01:54 PM
01/10/24 01:54 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
[quote=INTMD8]
Yes I'm aware.
The ecu has the capability of individual cylinder fuel and timing correction which would be useful for this car considering-
"Customer has custom headers in the drag car with O2 sensor in each head pipe"
You're the first to mention 8 closed loop widebands. Holley will run closed loop with a max of 2.
Page 2 of 3 1 2 3
