Re: oil filter
[Re: DusterKid]
#3203538
01/10/24 09:03 AM
01/10/24 09:03 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Is there any downside to running a smaller oil filter like Wix 51085 vs the larger Wix 51515 I don't think so if you are using light oil like a 5-30 or 10-40. Now if you are still using a heavy 20-50 type oil then I could se it would have a herd time with the smaller pleats in the filter medium IMO. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: oil filter
[Re: fourgearsavoy]
#3203543
01/10/24 09:50 AM
01/10/24 09:50 AM
Posts: 4,990 new jersey usa
11secdart
new jersey usa
I haven't had or seen any problems since changing to TTI headers and using the 51085 filter from before using a 90 degree adaptor and a 51515 ... I use 10W30 in my 410 c.i. small block
Re: oil filter
[Re: DaveRS23]
#3203567
01/10/24 12:34 PM
01/10/24 12:34 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
One downside to smaller filters: Less filter media means a greater pressure differential before and after the media. This will cause the filter’s internal bypass to open sooner when the conditions are right (colder higher viscosity oil, high flow rates due to higher rpm). I personally don’t like the idea of open bypass, but they are necessary.
Re: oil filter
[Re: DusterKid]
#3203583
01/10/24 02:17 PM
01/10/24 02:17 PM
Posts: 31,060 Oregon
AndyF
I run the super small Mopar filter on my stuff. The small filter fills up sooner so you get oil pressure sooner and it takes up a lot less space. If you're worried about it just change it more often.
Re: oil filter
[Re: AndyF]
#3203675
01/10/24 07:38 PM
01/10/24 07:38 PM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I run the super small Mopar filter on my stuff. The small filter fills up sooner so you get oil pressure sooner and it takes up a lot less space. If you're worried about it just change it more often. Those are non issues on a big block with a preluber like an Accusump, which in my humble opinion is the single best lubrication addition for those of us that only occasionally drive our cars.
Master, again and still
Re: oil filter
[Re: DusterKid]
#3203824
01/11/24 02:28 PM
01/11/24 02:28 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
Is there any downside to running a smaller oil filter like Wix 51085 vs the larger Wix 51515 Yes, don't do it unless you have to. Why run a smaller filter when you don't need to? I've tested different oil filters on different engine dyno years ago in SO CA on "The Carb Shop" engine dyno both stock and then two remote mounted stock type and then four remote mounted stock type and size. No gain or loss on using multiple filters, the smaller filters have less filter media in them so they have to bypass more oil to flow the same volume of oil than the larger filters due Unfiltered oil isn't as clean as filter oil is, correct I use one of the much larger size NASCAR size remote mounted oil filters now IHTHs
