Idler/pitman arm questions #3203232
01/08/24 04:22 PM
01/08/24 04:22 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
The pitman arm in the pic is a new Mevotech arm and the idler arm is an original. I have a couple of questions. Is there any reason not to use an original idler arm in conjunction with a new pitman arm or should I buy a new idler arm as well? The idler arm is in pretty nice condition but doesn't have a grease fitting on it and I can't get the stud to pivot. Probably a dumb question but is the stud supposed to pivot? Should I inject some grease into it with a needle fitting on my grease gun? And last, the idler arm fits snugly into the k-frame tabs as-is but I was reading about some new idler arms that come with foam-like washers. Do I need to add those? Not sure how I would get any in there though with the snug fit of the arm as-is.
Re: Idler/pitman arm questions [Re: 6PAX] #3203254
01/08/24 05:32 PM
01/08/24 05:32 PM
IMGTX Offline
IMGTX  Offline
IMHO no reason not to use it if you are just looking to drive the car. If you are racing there are advantages to some aftermarket parts.
It is not uncommon for them to be too stiff to rotate or pivot. Especially when new.
Grease is always good.
The ones I have seen with foam were greasable and the foam was like dust seal to keep the grease clean.
Re: Idler/pitman arm questions [Re: 6PAX] #3203280
01/08/24 07:20 PM
01/08/24 07:20 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Bergman has an idler with a bearing that seems like a good idea. Most if not all 'stock' type of idlers have some amount of slop unless you nearly put them into bind with the bolt. Just depends on what you are trying to achieve.
Master, again and still
Re: Idler/pitman arm questions [Re: DaveRS23] #3203286
01/08/24 07:44 PM
01/08/24 07:44 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Firm Feel has a bearing kit for idler arms
that is a nice upgrade.
Mike
Re: Idler/pitman arm questions [Re: mkdart] #3203429
01/09/24 02:40 PM
01/09/24 02:40 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Bergman is only real option for the bearing these days. Firm feel has the kit, but the supply of arms that can be converted is all gone.
I want my fair share
Re: Idler/pitman arm questions [Re: SomeCarGuy] #3203576
01/10/24 01:43 PM
01/10/24 01:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What arm is used ?
