Re: Racing plans for 2024?
[Re: Brad_Haak]
#3201930
01/03/24 01:30 PM
01/03/24 01:30 PM
Posts: 2,126 Byron, NY
W.I.N. Racing
Byron, NY
I like to get out 8-10 events a year, last year I sort of lucked out as my local track had multiple T/S events and Blown Door car events so I didn't have to stray far (30 min away). Coincidently none of the tracks within a 3-4 hr radius held any similar events so I didn't have a lot of options. There are 4 T/S events planned at the local track and rumors of some Q 8 stuff to the east and west. Also considering a East Coast Truck Wars event in VA. so we will see where we wind up.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: GY3]
#3201936
01/03/24 01:45 PM
01/03/24 01:45 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Not sure how much longer the restoration phase will last, but am enjoying not being in a rush. The hard work is all finished, Rich! That's what I keep telling myself. Especially two nights ago, laying in the trunk, putting the trunk lid torsion bars back on lol.
Rich H.
Esse Quam Videri
[Re: Al_Alguire]
#3201937
01/03/24 01:47 PM
01/03/24 01:47 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Get "lil bull" dialed in to run 8.50 every round! Currently motor is apart for repair, pin cam bearings, new rod and main bearings, then acquire wheels and a nostalgia style hood scoop to run with nostalgia cars in the MELTSOWN DRAGS at Rockfalls wis.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Blusmbl]
#3201960
01/03/24 03:28 PM
01/03/24 03:28 PM
Posts: 5,169 CT
GTX MATT
CT
I don't have a ton of upgrade and racing plans for the year. Have some minor things I want to do to the car before Sick Summer in June, hoping to average 11.5x and spray it at each track this year instead of just running on motor. Also need to install the tailpipes + TTI exhaust, fix a pinion seal leak, replace the tailshaft bushing in the trans, and I may also swap over to manual brakes. I have the pedal assembly but need to track down a manual pushrod.
Depending on the tracks I am thinking about doing Drag Week this year as well. I will probably apply to Roadkill Nights again. Beyond that, I don't do any real t&t nights or have any other race plans. There are some local daily driver type races at Milan but my rear tires are too big for the class and don't want to put small tires on it for just one series.
Have started collecting parts to build a mild-ish 540 to replace the 440 currently in the Fury but I don't expect it will be done this year. Still need machinework, custom pistons and most of the valvetrain. Switch to manual? You have power with the 590 Purpleshaft?
[Re: Mopar.70]
#3201967
01/03/24 03:50 PM
01/03/24 03:50 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I don't have any drag and drive plans this year but I do hope to race more often at home.
68 Barracuda Formula S 340
[Re: GTX MATT]
#3202005
01/03/24 07:06 PM
01/03/24 07:06 PM
Posts: 8,192 Plymouth, MI
Blusmbl
Plymouth, MI
Switch to manual? You have power with the 590 Purpleshaft? Yes, but it had a vacuum canister on the car initially that didn't work well at all, you'd get one stop and be out of luck for braking assist. I put a Leeds vacuum pump on it and that works really well, but the booster itself is starting to fail so I think it's time to swap it to manual to clean up the engine compartment some and save weight.
[Re: Blusmbl]
#3202014
01/03/24 08:08 PM
01/03/24 08:08 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
well our season has been underway for me since last September . New national series & points scheme with it running as a Western & Eastern division with a stand alone invitational Grand Final to find #1 racers in the various classes . Only thing odd is conference finals are in April & June with GF in October We run both 1/8 & 1/4 tracks . This is complicated that we have 2 sanction bodies so I need 2 licences and 2 tech inspections . So I will be doing a few more away events and almost no local track championship events . Certainly easier now I have a ute and open trailer plus a tent . Currently sitting ok with 2 finals , a semi & a 1/4 final from 4 events run .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3202024
01/03/24 08:13 PM
01/03/24 08:13 PM
Posts: 16,555 On the run…
BloFish
On the run…
Try to go as often as possible, weather permitting to Redding, Sonoma and Kingdon drags. Sorry to see Sacramento gone.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Brad_Haak]
#3202129
01/04/24 01:39 AM
01/04/24 01:39 AM
Posts: 1,366 Out of the State of Confusion
blue_stocker
Y'all almost make me yearn for my old car back, but not quite! I sold my stock eliminator car in June (after having it mostly sit for 39 years) so now, I'm building a new and my last one. Class racing has become too expensive for my poor old butt and when I see and hear some of the guys talk about how much their Don Little/Steve Wann/Eric Jones parts cost and I dig into my pockets only to find lint...I'm done! Hahaha, even though I'm building it as a SS car, I know it's just a dream I can no longer chase, BUT...this one will probably be a lot more fun!!! Hope y'all have a great time at the track...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: blue_stocker]
#3202141
01/04/24 08:53 AM
01/04/24 08:53 AM
Posts: 327 Northport, al.
tvt59
Northport, al.
Going to add a vacuum pump and oil accumulator to the AMX. I plan on racing Fridays at Lassiter Mountain and Saturdays either I22 or Montgomery International Raceway. Brakets and 6.00 index. At the end of 2024 I'll probably sell the AMX and try to get my 68' Valiant finished for the 2025 season.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: Brad_Haak]
#3202239
01/04/24 05:07 PM
01/04/24 05:07 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I got out like 2 times to test n tune last yr but I commited to the next 2 yrs to more tnt with new M/T slicks,new belts,newer helmet good for 8 more years so I will see how many tests I can get out to.I am working on my 60' with the slicks and cal tracs and fresh Rossler th400w/brake and some carb tunning and a new intercooler pump/tank from 1 gal for 10sec to 5gal for 10 sec with a rule 2000 pump.I wish you all a great year,good luck,have fun,be safe. PS: I just switched pumps to a Meziere wp336s 55gpm and will be a direct swap with the wp136 in line w/3gall cell still.
[Re: RTSE4ME]
#3202799
01/06/24 05:13 PM
01/06/24 05:13 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
I will probably just hit the Mopar shows and make a few passes. Putting the Richmond trans back in the car so I don't break a perfectly good quiet and smooth shifting Hemi box. Was considering making the switch over to E85 and see how that works out. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
