Re: 440 six pack stock rods crank gram weight ?
[Re: B1MAXX]
#3200676
12/29/23 01:18 PM
12/29/23 01:18 PM
Posts: 910 West Virginia
B1Frank
West Virginia
I checked out the ross pistons #80762 ...like good, ..... i think with a 88cc head with a #40 felpro head gasket comp around 11.00 to 11.25 ...............i have not checked out the price yet. ?
[Re: cudaman1969]
#3200682
12/29/23 01:24 PM
12/29/23 01:24 PM
B1Frank
West Virginia
Thank you i really needed that info cudaman 69 .......... is it the same with a HP block ???
[Re: B1Frank]
#3200696
12/29/23 02:23 PM
12/29/23 02:23 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
Thank you i really needed that info cudaman 69 .......... is it the same with a HP block ??? Reg piston was not in a HP block but the combined one was. Slight difference in height between the 2, 68 being taller but neither as tall as the 6 pac. Remember the 69-1/2 6 pac had the regular pistons and LY rods, 70-71 had the high compression 4 valve notch pistons and big rods, externally balanced. I’m thinking the LY rod and lighter pin would get close to the regulars setup with internal balance, with a little metal removal in the piston (30 grams). That’s what I’m looking to do
[Re: B1Frank]
#3200749
12/29/23 06:31 PM
12/29/23 06:31 PM
Posts: 201 PA
Scully
PA
Thank you i really needed that info cudaman 69 .......... is it the same with a HP block ??? You need the small and big end weights for the rod to calculate the bob weight.
[Re: B1MAXX]
#3200909
12/30/23 01:10 PM
12/30/23 01:10 PM
B1Frank
West Virginia
Thank you sir, it has been a struggle matching parts ! all the stroker kits from Jegs ...........need balancing too ! *&^%$#@! it is hard when you have not bought the pistons yet,.........LOL LOL
[Re: B1MAXX]
#3201900
01/03/24 11:43 AM
01/03/24 11:43 AM
B1Frank
West Virginia
Why can't some body made a affordable forged piston with a compression radio around 11.00 to 11.50 with a open chamber head in a stock block ? ..................... please i don't understand !
[Re: B1Frank]
#3201978
01/03/24 04:32 PM
01/03/24 04:32 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Why can't some body made a affordable forged piston with a compression radio around 11.00 to 11.50 with a open chamber head in a stock block ? ..................... please i don't understand ! Because aftermarket choices are bleak to non existent for mopars... now it it were a chevy or smallblock ford ...
[Re: B1Frank]
#3202237
01/04/24 04:50 PM
01/04/24 04:50 PM
Posts: 31,082 Oregon
AndyF
Why can't some body made a affordable forged piston with a compression radio around 11.00 to 11.50 with a open chamber head in a stock block ? ..................... please i don't understand ! Because that is a bad combination. Most customers want a combination that they can daily drive with pump gas. A modern closed chamber aluminum head with 10:1 compression using an off the shelf flat top piston makes great power and works with pump gas.
[Re: d-150]
#3202354
01/05/24 02:41 AM
01/05/24 02:41 AM
Posts: 201 PA
Scully
PA
They are old stock 2295. I think they used to call them 6 pack pistons The TRW 6 Pack pistons have 4 notches and are identical to the stock ones in shape.
[Re: Scully]
#3202366
01/05/24 08:44 AM
01/05/24 08:44 AM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
They are old stock 2295. I think they used to call them 6 pack pistons The TRW 6 Pack pistons have 4 notches and are identical to the stock ones in shape. Yep, the 2295 are what gets termed "old trw dome tops". The six pac is 2355
[Re: B1Frank]
#3202488
01/05/24 03:26 PM
01/05/24 03:26 PM
cudaman1969
fredericksburg,va
Thanks all the pistons for-sale i have seen are the low compression one's Then they’re not 6 pac pistons, should be 2.05 compression height at least.
