Re: 59 dodge 4 door: tombstones on speedo ???????
[Re: dart67]
#3199881
12/24/23 05:26 PM
12/24/23 05:26 PM
Posts: 1,883 Northern OH
rapom
Northern OH
I have a 59 dodge. From zero to 30 there is a green bar, then from 30 to 50 its orange, Over 55 the whole bar turns red. These colors are on a rolling pin behind the speedometer. I can see where you could access this because it is normal to service and lube this. And while your back there, draw things on the bar that would show up once your reach a certain speed.
[Re: Wagonmaster]
#3199894
12/24/23 06:39 PM
12/24/23 06:39 PM
rapom
Northern OH
Green LED’s really make it pop. The factory lighting left a lot to be desired.
[Re: rapom]
#3199911
12/24/23 09:04 PM
12/24/23 09:04 PM
Posts: 5,911 ohio
ruderunner
ohio
I have a 59 dodge. From zero to 30 there is a green bar, then from 30 to 50 its orange, Over 55 the whole bar turns red. These colors are on a rolling pin behind the speedometer. I can see where you could access this because it is normal to service and lube this. And while your back there, draw things on the bar that would show up once your reach a certain speed. Don't choke on your burger! Dang it, picture didn't copy.
Angry white pureblood male
[Re: Magnumguy]
#3199973
12/25/23 02:31 PM
12/25/23 02:31 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
IIRC, the 57 and 8 was red all the way across. At least my 57 is. '58 (I think?) This was in a local supermarket parking lot.
[Re: rapom]
#3200001
12/25/23 05:14 PM
12/25/23 05:14 PM
A12
N.E. OHIO, USA
Four door hardtops are rare. But you can say that about all of them So true on the 4-door hardtops as I went looking for something to ID the year of the car I posted the photos of and found 99% of them as 2-door models in both '58 and '59 think that was the year of this '57 model.
