Re: Good magnetic screwdriver bits?
[Re: BSharp]
#3206025
01/18/24 08:31 PM
01/18/24 08:31 PM
Posts: 1,849 South Bend
John Brown
South Bend
How about something like the spring loaded tool used for installing screws in distributors?
[Re: BSharp]
#3206165
01/19/24 11:55 AM
01/19/24 11:55 AM
Posts: 6,324 nowhere
Sniper
nowhere
Thought I'd follow up. Astoninglishly, I wasn't the first to think of the ring magnet. That's the Grainger magnet on the left, glued to a screwdriver bit. It does have the strongest magnetic pull and has the smallest diameter, so that's a win. The two in the middle are random examples from Amazon. They're both better than magnetic bits alone, but the red one is too big for tight spaces. The tool on the right is the Greenlee, and positively locks the screw in place for installation and removal. When you really don't want to drop that little screw, use the Greenlee. Comes in #1 and #2 sizes. I have that Greenlee tool. It works, within limitations. If the head of the screw is too big, it doesn't work. You cannot tighten the screw completely, you have to start it and use a regular screwdriver to finish the job. The head is too big for tight spaces. I'd rather use a longer 1/4" hex bit with a ring magnet
[Re: cagebob1]
#3206209
01/19/24 02:10 PM
01/19/24 02:10 PM
Posts: 19,624 north of coder
moparx
Wow! I haven't thought about that tool in ages !!! i have several in different sizes, including one for #2 phillips head screws. i use them frequently, although they will occasionally drop the screws.
