Re: Good magnetic screwdriver bits? [Re: 360view] #3199327
12/22/23 09:00 AM
12/22/23 09:00 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Did a quick experiment putting “a speck” of Mortite caulking cord
on a Phillips screw head to see if it would temporarily & lightly stick the bit to screw.
Worked somewhat.
Wonder about other “sticky stuff”
Right Stuff quick gasket
Command Wall Hook “taffee” stretchy adhesive
Re: Good magnetic screwdriver bits? [Re: 360view] #3199344
12/22/23 10:18 AM
12/22/23 10:18 AM
Virginia
BSharp Offline OP
BSharp  Offline OP
Virginia
Re: Good magnetic screwdriver bits? [Re: BSharp] #3206017
01/18/24 07:49 PM
01/18/24 07:49 PM
Virginia
BSharp Offline OP
BSharp  Offline OP
Virginia
Thought I'd follow up. Astoninglishly, I wasn't the first to think of the ring magnet. That's the Grainger magnet on the left, glued to a screwdriver bit. It does have the strongest magnetic pull and has the smallest diameter, so that's a win. The two in the middle are random examples from Amazon. They're both better than magnetic bits alone, but the red one is too big for tight spaces. The tool on the right is the Greenlee, and positively locks the screw in place for installation and removal. When you really don't want to drop that little screw, use the Greenlee. Comes in #1 and #2 sizes.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3206025
01/18/24 08:31 PM
01/18/24 08:31 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
How about something like the spring loaded tool used for installing screws in distributors?
Re: Good magnetic screwdriver bits? [Re: BSharp] #3206093
01/19/24 05:46 AM
01/19/24 05:46 AM
USA
3
360view Offline
360view  Offline
3
USA
Thank you for that follow up.
Now I have presents for next Christmas.
Re: Good magnetic screwdriver bits? [Re: John Brown] #3206163
01/19/24 11:49 AM
01/19/24 11:49 AM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
Wow! I haven't thought about that tool in ages !!!
Re: Good magnetic screwdriver bits? [Re: BSharp] #3206165
01/19/24 11:55 AM
01/19/24 11:55 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I have that Greenlee tool. It works, within limitations. If the head of the screw is too big, it doesn't work. You cannot tighten the screw completely, you have to start it and use a regular screwdriver to finish the job. The head is too big for tight spaces.
I'd rather use a longer 1/4" hex bit with a ring magnet
Re: Good magnetic screwdriver bits? [Re: cagebob1] #3206209
01/19/24 02:10 PM
01/19/24 02:10 PM
moparx Offline
moparx  Offline
i have several in different sizes, including one for #2 phillips head screws.
i use them frequently, although they will occasionally drop the screws.
beer
Re: Good magnetic screwdriver bits? [Re: 360view] #3206825
01/21/24 12:52 PM
01/21/24 12:52 PM
USA
3
360view Offline
360view  Offline
3
USA
I wonder if “heat shrink tubing”
could be shrunk to fit over screwdriver,
then different diameter for screw
