Re: Dyno Results 540 CID Indy 345 CNC
[Re: jcc]
#3198703
12/19/23 07:33 PM
12/19/23 07:33 PM
Posts: 2,527 PA
moparacer
PA
Nice Jim! That is basically my next engine but with higher compression. Want low to mid 900s and looks like with more compression it will do it easily.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3198715
12/19/23 08:14 PM
12/19/23 08:14 PM
Posts: 31,091 Oregon
AndyF
If you are looking for low to mid 900 HP, using a big bore block, and building with all new parts, then the 572-13 heads are probably a better starting point. Using the better head allows you to soften up the camshaft a little bit which allows the parts to all live longer. So you can make the same power but have a longer life.
[Re: AndyF]
#3198894
12/20/23 03:11 PM
12/20/23 03:11 PM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
If you are looking for low to mid 900 HP, using a big bore block, and building with all new parts, then the 572-13 heads are probably a better starting point. Using the better head allows you to soften up the camshaft a little bit which allows the parts to all live longer. So you can make the same power but have a longer life. Even though Moparacer has a stout 500" combo now and you think it'd translate to the gains he's expecting, I have to agree with you Jim. Not everyday you see a 900+HP -1 build.
[Re: HardcoreB]
#3198912
12/20/23 04:28 PM
12/20/23 04:28 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Even though Moparacer has a stout 500" combo now and you think it'd translate to the gains he's expecting, I have to agree with you Jim. Not everyday you see a 900+HP -1 build. [/quote] Nah according to dyno sheets and owners there are alot of them out there. Just not so many timeslips that confirm that sort of performance ![cool cool](/ubbthreads/images/graemlins/custom/cool.gif)
[Re: 440Jim]
#3198915
12/20/23 04:37 PM
12/20/23 04:37 PM
AndyF
Just had one of those come into the shop. 540 inches, aluminum block, Indy -1 heads with the 345 CNC port package. Be a few months before it is fresh and ready to go on the dyno. I'd be shocked it it made 900 hp, these things usually top out around 850 with a wet sump and cast intake.
[Re: AndyF]
#3198970
12/20/23 08:14 PM
12/20/23 08:14 PM
Posts: 2,527 PA
moparacer
PA
I agree it would be easier, but already have 345 CNC-1s on my engine and I was trying to soften the blow to the wallet by reusing them. Going to 572-13s changes everything. I have been 5.47 with my setup at 502 cid with an iron block, and can only go 5.35 on a 8.50 cert so my thinking was 540/aluminum block should put me there pretty easy. If I was going the 572-13 route I would build a 572 and not a 540. I really don't want to go much faster in the old crate anyways.... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: AndyF]
#3198981
12/20/23 08:45 PM
12/20/23 08:45 PM
Posts: 2,527 PA
moparacer
PA
Yes, if you are going to be reusing parts then the build goes down a different path. Sounds like the short block will be all new parts though? Yes, I would be starting from scratch on the short block unless I stumble onto a good deal used. I do like the idea of going bigger with the engine and being easier on parts. Lower RPM etc. I race a lot and longevity is a requirement.
[Re: AndyF]
#3198993
12/20/23 09:44 PM
12/20/23 09:44 PM
Posts: 9,884 MI, usa
dvw
MI, usa
Mine is a -1 engine. It's never been on the dyno. But its gone 5.639@121.4 at 3350 lbs. That was at 1.030 correction factor. I would bet it makes around 900. Doug
[Re: moparacer]
#3199002
12/20/23 11:01 PM
12/20/23 11:01 PM
AndyF
Yes, if you are going to be reusing parts then the build goes down a different path. Sounds like the short block will be all new parts though? Yes, I would be starting from scratch on the short block unless I stumble onto a good deal used. I do like the idea of going bigger with the engine and being easier on parts. Lower RPM etc. I race a lot and longevity is a requirement. Aluminum block lets you go 4.500 piston which is a good size to use since lots of choices for rings. I'd go with a 540 if you use an internal oil pickup, or a 572 if you are already set up for external oiling. The weight reduction from the block plus the extra torque from a bigger short block should both help the car get moving. I had a customer step up from a 505 to a 572 last year and the extra torque scared the heck out of him. First time at the track with the new motor the car lifted the front tires about 3 feet and that freaked him out. It looked cooler than hell but his eyes were big when he got back to the pits! He ended up swapping out the 727 for a Glide and that helped to settle the car down. Also made it more consistent.
[Re: dvw]
#3199004
12/20/23 11:05 PM
12/20/23 11:05 PM
Posts: 16,932 NC
440Jim
NC
I was surprised to see the >900 hp number too. But everybody should remember, the heads had some work, not OTTB CNC345, and the -3X intake was tweaked. And he does have a vacuum pump on it. Still, better numbers than I expected. If, if, if, we ignore the drop at 6800, and peak at 6900 rpm, this dyno still says 910 ish. About the most I could expect from a 540 CID with CNC345 heads. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 440Jim]
#3199060
12/21/23 09:33 AM
12/21/23 09:33 AM
HardcoreB
Shelby Twp. Mi
I was surprised to see the >900 hp number too. But everybody should remember, the heads had some work, not OTTB CNC345, and the -3X intake was tweaked. And he does have a vacuum pump on it. Still, better numbers than I expected. If, if, if, we ignore the drop at 6800, and peak at 6900 rpm, this dyno still says 910 ish. About the most I could expect from a 540 CID with CNC345 heads. So Jim, all along here NO DISRESPECT for your friend intended. If anything, I give him respect to pick a good shop and let them handle the build because most of us know enough to be dangerous. Buck is a good shop from what I understand. When i learned that they did the build, I started to reconsider the number may be closer to reality. And it's possible we may not have the most accurate details in the build. Doug's motor is a good example of a 900HP -1. It has some really good heads, a big cam with a 4/7 swap, 15:1, good piston/ring pack, good machining, good oiling system, and it's 58x CID. I have no doubt there is more in a better cam, Ti valves, better headers and a better intake. One other thing that probably isn't emphasized is the rest of the car when considering how much corrected HP a motor makes as measured on a dyno (let alone WHO'S dyno facility). How good is the trans, converter and the tune-up when it's in the car vs. on the dyno? How much effort was taken in most cases to find the most in the combo? Even if it makes 'only' 850HP that's pretty good when you consider it's still a low-port max wedge head. This all may make me more unpopular but, if we can't share our thoughts and debate, we'll continue to evolve slowly.
[Re: moparacer]
#3199112
12/21/23 01:45 PM
12/21/23 01:45 PM
Posts: 10,023 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I agree it would be easier, but already have 345 CNC-1s on my engine and I was trying to soften the blow to the wallet by reusing them. Going to 572-13s changes everything. I have been 5.47 with my setup at 502 cid with an iron block, and can only go 5.35 on a 8.50 cert so my thinking was 540/aluminum block should put me there pretty easy. If I was going the 572-13 route I would build a 572 and not a 540. I really don't want to go much faster in the old crate anyways.... Why not put 572 cubes under your 440-1 heads? They may be restricted on max power, but you will see that max power EARLY. Don't forget you will be running less rpm and putting less stress on the motor, which means longer life.
[Re: HardcoreB]
#3199191
12/21/23 05:38 PM
12/21/23 05:38 PM
Posts: 16,932 NC
440Jim
NC
So Jim, all along here NO DISRESPECT for your friend intended. It is all good. The dyno numbers are that dyno, thats all. I just don't want anybody to buy the same parts and expect the same results. Heads and intake were worked somewhat (I don't have details).
[Re: sean1970]
#3199321
12/22/23 08:14 AM
12/22/23 08:14 AM
Posts: 173 Sticky South
Rodenteliminator
Sticky South
With Todd’s combo and assembly and a pull on Charlie’s Bucks dyno my 540 with -1’s made 880, I am getting close to having it ready to hit the track so we will see how it translates to real track results. Doug
Sorry honey I spent the rent
[Re: Rodenteliminator]
#3199328
12/22/23 09:22 AM
12/22/23 09:22 AM
gregsdart
With Todd’s combo and assembly and a pull on Charlie’s Bucks dyno my 540 with -1’s made 880, I am getting close to having it ready to hit the track so we will see how it translates to real track results. Doug i have no doubt your motor will be making great power, and given all the driveline and suspension are set for that motor, you will be pleased with the results. As i said in an earlier comment, it is just a little easier to pull 880 to 920 hp out of a bigger shortblock like a 572 or even bigger. It may require a different converter and rear gear should it be a big increase, like more than 572. I have a 580 inch combo i could run with my 572-13 heads, but it would require a gear change minimum and i am already certain my 549/572-13 motor will go faster than my 8,50 cert, plus i would need to retune it as well.
[Re: gregsdart]
#3199394
12/22/23 12:16 PM
12/22/23 12:16 PM
Al_Alguire
Las Vegas
Aint always about cubes ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) My little 540 pushes my 3600 turd into the 8.80's here in Vegas. I have no doubt it made that number for sure on the dyno. As said before the track is always the true barometer of an engines performance.
