Re: Dyno Results 540 CID Indy 345 CNC [Re: jcc] #3198703
12/19/23 07:33 PM
12/19/23 07:33 PM
PA
moparacer Offline
moparacer  Offline
PA
Nice Jim! That is basically my next engine but with higher compression.
Want low to mid 900s and looks like with more compression it will do it easily.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Dyno Results 540 CID Indy 345 CNC [Re: moparacer] #3198715
12/19/23 08:14 PM
12/19/23 08:14 PM
AndyF Offline
AndyF  Offline
If you are looking for low to mid 900 HP, using a big bore block, and building with all new parts, then the 572-13 heads are probably a better starting point. Using the better head allows you to soften up the camshaft a little bit which allows the parts to all live longer. So you can make the same power but have a longer life.
Re: Dyno Results 540 CID Indy 345 CNC [Re: AndyF] #3198894
12/20/23 03:11 PM
12/20/23 03:11 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Even though Moparacer has a stout 500" combo now and you think it'd translate to the gains he's expecting, I have to agree with you Jim. Not everyday you see a 900+HP -1 build.
Re: Dyno Results 540 CID Indy 345 CNC [Re: HardcoreB] #3198912
12/20/23 04:28 PM
12/20/23 04:28 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Even though Moparacer has a stout 500" combo now and you think it'd translate to the gains he's expecting, I have to agree with you Jim. Not everyday you see a 900+HP -1 build. [/quote]
Nah according to dyno sheets and owners there are alot of them out there. Just not so many timeslips that confirm that sort of performance cool
Re: Dyno Results 540 CID Indy 345 CNC [Re: 440Jim] #3198915
12/20/23 04:37 PM
12/20/23 04:37 PM
AndyF Offline
AndyF  Offline
Just had one of those come into the shop. 540 inches, aluminum block, Indy -1 heads with the 345 CNC port package. Be a few months before it is fresh and ready to go on the dyno. I'd be shocked it it made 900 hp, these things usually top out around 850 with a wet sump and cast intake.
Re: Dyno Results 540 CID Indy 345 CNC [Re: AndyF] #3198970
12/20/23 08:14 PM
12/20/23 08:14 PM
PA
moparacer Offline
moparacer  Offline
PA
I agree it would be easier, but already have 345 CNC-1s on my engine and I was trying to soften the blow to the wallet by reusing them. Going to 572-13s changes everything. I have been 5.47 with my setup at 502 cid with an iron block, and can only go 5.35 on a 8.50 cert so my thinking was 540/aluminum block should put me there pretty easy.
If I was going the 572-13 route I would build a 572 and not a 540.
I really don't want to go much faster in the old crate anyways.... laugh2
Re: Dyno Results 540 CID Indy 345 CNC [Re: moparacer] #3198972
12/20/23 08:23 PM
12/20/23 08:23 PM
AndyF Offline
AndyF  Offline
Yes, if you are going to be reusing parts then the build goes down a different path. Sounds like the short block will be all new parts though?
Re: Dyno Results 540 CID Indy 345 CNC [Re: AndyF] #3198981
12/20/23 08:45 PM
12/20/23 08:45 PM
PA
moparacer Offline
moparacer  Offline
PA
Yes, I would be starting from scratch on the short block unless I stumble onto a good deal used. I do like the idea of going bigger with the engine and being easier on parts. Lower RPM etc. I race a lot and longevity is a requirement.
Re: Dyno Results 540 CID Indy 345 CNC [Re: AndyF] #3198993
12/20/23 09:44 PM
12/20/23 09:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine is a -1 engine. It's never been on the dyno. But its gone 5.639@121.4 at 3350 lbs. That was at 1.030 correction factor. I would bet it makes around 900.
Doug
Re: Dyno Results 540 CID Indy 345 CNC [Re: moparacer] #3199002
12/20/23 11:01 PM
12/20/23 11:01 PM
AndyF Offline
AndyF  Offline
Aluminum block lets you go 4.500 piston which is a good size to use since lots of choices for rings. I'd go with a 540 if you use an internal oil pickup, or a 572 if you are already set up for external oiling. The weight reduction from the block plus the extra torque from a bigger short block should both help the car get moving.
I had a customer step up from a 505 to a 572 last year and the extra torque scared the heck out of him. First time at the track with the new motor the car lifted the front tires about 3 feet and that freaked him out. It looked cooler than hell but his eyes were big when he got back to the pits! He ended up swapping out the 727 for a Glide and that helped to settle the car down. Also made it more consistent.
Re: Dyno Results 540 CID Indy 345 CNC [Re: dvw] #3199004
12/20/23 11:05 PM
12/20/23 11:05 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I was surprised to see the >900 hp number too.
But everybody should remember, the heads had some work, not OTTB CNC345, and the -3X intake was tweaked. And he does have a vacuum pump on it.
Still, better numbers than I expected. If, if, if, we ignore the drop at 6800, and peak at 6900 rpm, this dyno still says 910 ish.
About the most I could expect from a 540 CID with CNC345 heads. up
Re: Dyno Results 540 CID Indy 345 CNC [Re: 440Jim] #3199060
12/21/23 09:33 AM
12/21/23 09:33 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
So Jim, all along here NO DISRESPECT for your friend intended. If anything, I give him respect to pick a good shop and let them handle the build because most of us know enough to be dangerous. Buck is a good shop from what I understand. When i learned that they did the build, I started to reconsider the number may be closer to reality. And it's possible we may not have the most accurate details in the build. Doug's motor is a good example of a 900HP -1. It has some really good heads, a big cam with a 4/7 swap, 15:1, good piston/ring pack, good machining, good oiling system, and it's 58x CID. I have no doubt there is more in a better cam, Ti valves, better headers and a better intake. One other thing that probably isn't emphasized is the rest of the car when considering how much corrected HP a motor makes as measured on a dyno (let alone WHO'S dyno facility). How good is the trans, converter and the tune-up when it's in the car vs. on the dyno? How much effort was taken in most cases to find the most in the combo? Even if it makes 'only' 850HP that's pretty good when you consider it's still a low-port max wedge head. This all may make me more unpopular but, if we can't share our thoughts and debate, we'll continue to evolve slowly.
Re: Dyno Results 540 CID Indy 345 CNC [Re: moparacer] #3199112
12/21/23 01:45 PM
12/21/23 01:45 PM
gregsdart Offline
gregsdart  Offline
Why not put 572 cubes under your 440-1 heads? They may be restricted on max power, but you will see that max power EARLY. Don't forget you will be running less rpm and putting less stress on the motor, which means longer life.
Re: Dyno Results 540 CID Indy 345 CNC [Re: HardcoreB] #3199191
12/21/23 05:38 PM
12/21/23 05:38 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
It is all good. The dyno numbers are that dyno, thats all.
I just don't want anybody to buy the same parts and expect the same results. Heads and intake were worked somewhat (I don't have details).
Re: Dyno Results 540 CID Indy 345 CNC [Re: 440Jim] #3199282
12/21/23 11:06 PM
12/21/23 11:06 PM
Houston, Texas
sean1970 Offline
sean1970  Offline
Houston, Texas
I can vouch for Charlie Buck his dyno is very accurate and one of the best engine builders in the country. Solid as they come.
Re: Dyno Results 540 CID Indy 345 CNC [Re: sean1970] #3199321
12/22/23 08:14 AM
12/22/23 08:14 AM
Sticky South
Rodenteliminator Offline
Sticky South
With Todd’s combo and assembly and a pull on Charlie’s Bucks dyno my 540 with -1’s made 880, I am getting close to having it ready to hit the track so we will see how it translates to real track results. Doug
Sorry honey I spent the rent
Re: Dyno Results 540 CID Indy 345 CNC [Re: Rodenteliminator] #3199328
12/22/23 09:22 AM
12/22/23 09:22 AM
gregsdart Offline
gregsdart  Offline
i have no doubt your motor will be making great power, and given all the driveline and suspension are set for that motor, you will be pleased with the results. As i said in an earlier comment, it is just a little easier to pull 880 to 920 hp out of a bigger shortblock like a 572 or even bigger. It may require a different converter and rear gear should it be a big increase, like more than 572. I have a 580 inch combo i could run with my 572-13 heads, but it would require a gear change minimum and i am already certain my 549/572-13 motor will go faster than my 8,50 cert, plus i would need to retune it as well.
Re: Dyno Results 540 CID Indy 345 CNC [Re: gregsdart] #3199394
12/22/23 12:16 PM
12/22/23 12:16 PM
Las Vegas
Las Vegas
Aint always about cubes smile My little 540 pushes my 3600 turd into the 8.80's here in Vegas. I have no doubt it made that number for sure on the dyno. As said before the track is always the true barometer of an engines performance.
Re: Dyno Results 540 CID Indy 345 CNC [Re: Al_Alguire] #3199556
12/23/23 04:03 AM
12/23/23 04:03 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well sportsfans
yes I was involved but did not assemble or machine. Charlies crew did all that. He does almost all of my machine work. Having dynoed all of my engines at Charlies over the last decade or so I can tell you that it is not a happy dyno and we have backed up almost all of the numbers it posted at the track. People have been telling me for 25 years now what Indy headed motors will or will not do. My friend Larry was a big part of what success we have had and yeah he worked on these. That dip in the numbers has happened on every motor that we have tested there. It is a glitch in the software and yes Charlie knows about it and had had the manufacturer look at it several times. The combination was simply reusing some existing parts and marrying them up with some new stuff. Yes it is a 540 (4.25 stroke 4.500 bore) . All I can tell you is that over the last decade and at least 30 to 40 motors tested at that facility the numbers have proven to be reliable data for me.
Todd
