Dyno sheet Hp vs. Corrected Hp
#3197298
12/13/23 06:16 PM
12/13/23 06:16 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
Which number would you use for a Wallace calculator guess at Hp, Weight, and ET? Sheet is for a 500 inch Brodix headed RB. Hp is 710, Corrected is 790. Is that enough steam to push a 3000# A body to mid/low 9s? Thanks! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Dyno sheet Hp vs. Corrected Hp
[Re: slantzilla]
#3197312
12/13/23 07:31 PM
12/13/23 07:31 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Depending on setup, i assume 710 honest, at your DA during run, will get you 9.50s? Mineshaft air, obviously better. If your dyno numbers were with better headers, that may affect ootential ET. What is your motor, trans, etc combo?
[Re: gregsdart]
#3197330
12/13/23 08:52 PM
12/13/23 08:52 PM
slantzilla
Park Forest, IL
Car is a 68 Dart. Looks like it has a good set of big tube headers in it. 727 stall unknown, brake, supposedly 4.88 Dana, ladder bar/coil over. No idea on cam specs. Just looking for a good guess. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: slantzilla]
#3197384
12/14/23 12:25 AM
12/14/23 12:25 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Which number would you use for a Wallace calculator guess at Hp, Weight, and ET? Sheet is for a 500 inch Brodix headed RB. Hp is 710, Corrected is 790. Is that enough steam to push a 3000# A body to mid/low 9s? Thanks! I don't care about corrected HP on engine dyno, it is just a correction formula number for what that motor would supposedly put out at 60 degrees F at zero humidity with 29.92 inches of barometric pressure at mean sea level. mid way between high and low tide ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) I did pay attention to them when doing flight planning in the summer flying in the Mojave Desert in the summer ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Automotive and Aviation ISA (instrument standard atmosphere), vary by one degree F, Aviation is done at 59 F, automotive is done using 60F ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Not enough to worry over ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: slantzilla]
#3197392
12/14/23 01:53 AM
12/14/23 01:53 AM
Posts: 31,077 Oregon
AndyF
Which number would you use for a Wallace calculator guess at Hp, Weight, and ET? Sheet is for a 500 inch Brodix headed RB. Hp is 710, Corrected is 790. Is that enough steam to push a 3000# A body to mid/low 9s? Thanks! Depends on the weather conditions that you race in. Here in the northwest we race near standard conditions a fair amount of the time so corrected power is okay to use. If you're racing in heat or at altitude you should stick with actual power since that is what you'll be making most of the time.
[Re: mopar873]
#3197438
12/14/23 11:18 AM
12/14/23 11:18 AM
fast68plymouth
So. Burlington, Vt.
My experience has been that for non-altitude adjusted tracks, it’s not at all uncommon to have the performance calculators show 5-15% lower power than stp hp from the dyno. You have the combination of the parasitic losses that are incurred by running the transmission, converter, etc, along with how much the weather at the time differs from a “standard” day. For altitude adjusted tracks, the difference will obviously be even greater. In theory, the performance calculator is showing the in car/at the track power for that moment in time. Keep in mind, the poorer the car set up is, the greater the difference you’ll see between the stp dyno hp and the performance calculator. I have a few customers who run at fast tracks in good air where the stp dyno hp and the performance calculators are very very close. Is that enough steam to push a 3000# A body to mid/low 9s? Using the Moroso calculator, 10% off 790, at 3000lbs is about a 9.25
[Re: slantzilla]
#3197445
12/14/23 11:56 AM
12/14/23 11:56 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Which number would you use for a Wallace calculator guess at Hp, Weight, and ET? Sheet is for a 500 inch Brodix headed RB. Hp is 710, Corrected is 790. Is that enough steam to push a 3000# A body to mid/low 9s? Thanks! I'd think mid 9's wouldn't be a problem unless something in the car is way out in left field. My small block made 703 on the engine dyno and 545 at the wheels on a chassis dyno. It's in a street/strip 69 Dart, 727,4.10 gears with 28" tall radials, almost 3300# race ready. It went 10.008 @ 134.74 in poor air, the 1/8 mile et and 60' was off by over .1 and the mph was down over 1 mph. It's been 6.25 @ 110 in good air.
