Re: 70 440 valve covers help
[Re: DD_lover]
#31989
08/08/08 06:53 PM
08/08/08 06:53 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
This thread has helped me numerous times in the past couple years...
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: daniel_depetro]
#31990
08/16/08 11:23 AM
08/16/08 11:23 AM
daniel_depetro
Sorry to bring up an old post but now I need some clearification and figured I might as well add it to this thread. OK this is a 1971 non HP 440 I just picked up. The chrome valve covers came with the non HP 1968 440 I also bought (pictured in the following post). The VC on the passenger side is what I believe to be a 1968-69 HP style cover. The VC on the driver side is what I believe to be a 1968-69 non HP style cover. From what I understand I can easily turn this one into a 1968-69 HP cover by removing the 'tabs'. Is this correct?
#31991
08/16/08 11:25 AM
08/16/08 11:25 AM
daniel_depetro
This is a 1968 non HP 440 I bought a couple months ago. Installed are the original valve covers for the engine. The engine was removed from a wagon and these covers originally looked just like the turqouise ones pictured a few posts above so I am guessing it was a C-body? I removed the brackets and it has the flexible wire holders, however it never had any tabs. It now looks like a 1968-69 HP cover but does not have the correct tabs to be a 1968-69 HP cover. I already removed the tabs off of this cover to make it a 1968-69 HP cover. ![](http://img518.imageshack.us/img518/4227/p1030428mg8.jpg)
#31992
08/16/08 11:26 AM
08/16/08 11:26 AM
daniel_depetro
This is a 1977/78 400 I bought about a year ago. My father has a 1970 F440HP2 six pack engine he bought that was missing the original valve covers as it came with M/T aluminum ones. I wanted a set of aluminum covers for my 400 engine so I bought him the correct ones for his six pack engine as he was going to need them anyways. These were bought from a reputable source and are supposedly 1970 only HP covers. The thing that makes me nervous is the indent on the cover. They each have a different dent in them on the end from the 1968-69 covers. It is more squared off (like 90*). You can barely see it just below the massive distributor on the front of the cover. Was this for A/C cars or for 1971+ cars? Are these the 1970 only HP covers? This is suppose to be a 1970 only HP cover. They each have a different dent in them on the end from the 1968-69 covers. It is more squared off (like 90*). You can barely see it on the bottom side in the very back on the cover. Was this for A/C cars or for 1971+ cars? Is this a 1970 only HP cover? ![](http://img518.imageshack.us/img518/7091/p1030432ap5.jpg)
#31993
08/16/08 09:48 PM
08/16/08 09:48 PM
Posts: 75,271 A gulag near you.
JohnRR
A gulag near you.
Is this correct?
No you are not correct , the right side cover is 69 ONLY if it's a factory installed cover , 68 has a bracket welded on for heater hose retention , the left cover is 68-69 used in HP applications ONLY if it were a factory installed cover .
[Re: JohnRR]
#31995
08/17/08 12:00 AM
08/17/08 12:00 AM
daniel_depetro
Shoot! I was afraid of that... So what makes it a C-body cover? What does a 1970 B-body/E-body HP valve cover look like?
#31996
08/18/08 09:12 AM
08/18/08 09:12 AM
JohnRR
A gulag near you.
The tabs for the spark plug wire , but I can't think of a C body model that would have chrome covers in 1969 ? I still think those are over the counter generic 1969 covers .
The 1970 cover for the pass side has an indent on the end under the dist SIMILAR to the 68-69 cover , look on the first page , there are examples of it .
[Re: JohnRR]
#31997
08/18/08 05:33 PM
08/18/08 05:33 PM
daniel_depetro
I do not doubt these are over the counter pieces, but they are definately Mopar (Hustle Stuff/Direct Connection) parts. They are identical to my painted ones in construction and if they were painted, nobody could tell the difference. They are baffled the same and everything. Personally I was just going to paint them...
#31998
08/19/08 08:40 AM
08/19/08 08:40 AM
JohnRR
A gulag near you.
When I said over the counter I meant over the dealer parts counter , not aftermarket .
