Page 2 of 3 1 2 3
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A39Coronet] #3195047
12/03/23 09:20 AM
12/03/23 09:20 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Originally Posted by A39Coronet
In an NA application, I can't imagine it would make any difference on the time slip.
Should help with consistency though, If you use traction control (which is an option on some of the digital ignition / FI units available now) stable timing is a must.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: Tig] #3195113
12/03/23 01:52 PM
12/03/23 01:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A crank trigger is going to make a difference in ANY combo. If you are trying to go fast the last thing you need is timing being inconsistent.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: CMcAllister] #3195168
12/03/23 05:27 PM
12/03/23 05:27 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
In an NA application, I can't imagine it would make any difference on the time slip. Unless you're running nitrous on the ragged edge, what's the justification for it? Rock steady timing is neat, but if your timing jumps around that much you need a new chain.
Chain, gear slop, driveshaft moving around, oil pump affecting the whole mess. Plus cam twist if it's a small block. If you're okay with it moving around a couple degrees, then it doesn't matter.
Crank trigger, what you see with a timing light is like a snapshot. Zero movement.
With the ignition stuff available now, you can set the base timing ahead of where you want it and dial in a retard curve. Some guys I know are using various amounts of retard at different places on the track. No reason it couldn't be done on the street. Even dialing in the timing precisely on each cylinder, if you are collecting data.
Yeah I get where all the "slop" could come from, but does it make a drop in the oceans worth of difference on a time slip? Especially in a motor that's owned by someone who's going to spend money to add a crank trigger (ie fairly tight motor without 100k miles)? I'll wait for Engine Masters to prove it but I seriously doubt it. Certainly not enough to make the cost worth it.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A39Coronet] #3195184
12/03/23 06:16 PM
12/03/23 06:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I guess it depends. Do you want to know it moved 2, and not 3 or 4, when you wanted to bump it 2? Are you trying to optimize what you have or OK with just changing the number on the window? Are you looking for tenths or hundredths? Do you need to be able to control the timing at every part of the track? Is consistency important?
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A39Coronet] #3195201
12/03/23 07:22 PM
12/03/23 07:22 PM
AndyF Offline
AndyF  Offline
The OEM engineers must think so. Distributors are gone these days and most engines now use a trigger wheel that is mounted on the crankshaft.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: AndyF] #3195228
12/03/23 09:44 PM
12/03/23 09:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
With a crank trigger you can use any beater distributor. The cost yhen is very close. i bought a close out 440 source billet ball bearing unit with no elctronics for $25
Doug
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: dvw] #3195243
12/03/23 11:15 PM
12/03/23 11:15 PM
Minnesota
Hemi_Joel Online content OP
Hemi_Joel  Online Content OP
Minnesota
Good point.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: dvw] #3195246
12/03/23 11:51 PM
12/03/23 11:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doug
Hint...old Mopar Lean Burn distributors were solid shaft, no advance, spinning a reluctor and a rotor button. Period. Pull the reluctor/plate/guts, and voila, you have a perfect crank trigger distributor.
Probably for free if you can find one.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: CMcAllister] #3195249
12/04/23 01:28 AM
12/04/23 01:28 AM
AndyF Offline
AndyF  Offline
Yes, I used a Lean Burn distributor once a long time ago. But I grew tired of the crappy spark plug wire ends that those old distributors had so eventually I switched over to a locked out MSD. After that I migrated to a belt drive distributor. The belt drive distributor solved a bunch of issues although it did create a couple in the process.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: AndyF] #3195257
12/04/23 07:18 AM
12/04/23 07:18 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The ATI dampner with magnets is the way to go. I used Andy's bracket that also has a pointer on it. It really cleans everything up nice.
As for why run a crank trigger? Well some engines are that finicky on timing. Some will see decent gains, just by 1/2 degree of timing. Only way to do that is with a crank trigger.
69 GTX 68 Road Runner
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: JERICOGTX] #3195287
12/04/23 11:56 AM
12/04/23 11:56 AM
AndyF Offline
AndyF  Offline
Nice looking engine. The turquoise and black is a good combination.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: AndyF] #3195290
12/04/23 12:17 PM
12/04/23 12:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Can guarantee with 100% certaintly that if we end up with an extra degree of timing at certain point in a run we will melt parts..But thats what happens when you are in an all out venture. We add timing on a run, a LOT of timing in lower gears. If for some reason we end up with to much in high gear the engine is very unhappy. The amount of fuel we run in the engine combined with its octane and will defintely hurt parts with to much, Yep even a degree or two will kill parts.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: JERICOGTX] #3195310
12/04/23 02:02 PM
12/04/23 02:02 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
They look great and I thought of using one of those but we swap the crank trigger stuff between 2 engines.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: CMcAllister] #3195387
12/04/23 10:12 PM
12/04/23 10:12 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Doug
Yup. What I use.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: markz528] #3195407
12/05/23 12:01 AM
12/05/23 12:01 AM
Minnesota
Minnesota
Lots of good info here. Thanks everyone for all the replies!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A39Coronet] #3195540
12/05/23 07:20 PM
12/05/23 07:20 PM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
I spoke with Kent Ritter about this subject just last week. My engine builder is recommending that I go to a crank trigger on our next build . Kent said that is was not necessary for my application . My car is a low 9 second braket car with an alcohol carb.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: tvt59] #3195553
12/05/23 08:42 PM
12/05/23 08:42 PM
A727Tflite Offline
A727Tflite  Offline
When is it ever “necessary” ?
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A727Tflite] #3195832
12/07/23 09:47 AM
12/07/23 09:47 AM
an8sec70cuda Offline
It's necessary when you are pulling a lot of timing out (nitrous/boost) to keep the rotor phased or when you have a very timing sensitive combo that you're running on the ragged edge.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: Al_Alguire] #3195858
12/07/23 11:07 AM
12/07/23 11:07 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
To add to this, a friend of mine has run a grudge racing turned LDR car in our local heads up series for the last decade or so, it was a 23* conventional SBC with a few kits for a while, then moved to a big block with a couple foggers. A degree of timing on his combo was sometimes the difference of a clean pass or an oil pan smashing wheelie. Stuff on the ragged edge is really that sensitive!
Low compression and low output is totally different, it's got a tuning window you can drive a truck through, lol
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: an8sec70cuda] #3195874
12/07/23 11:56 AM
12/07/23 11:56 AM
AndyF Offline
AndyF  Offline
Good point about rotor phasing. That is one big benefit of splitting the distributor from the timing pickup. With a crank trigger and a belt drive distributor the rotor is always exactly where it needs to be regardless of what the timing is doing.
Page 2 of 3 1 2 3
