Page 3 of 3 1 2 3
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: AndyF] #3195941
12/07/23 06:54 PM
12/07/23 06:54 PM
Minnesota
Hemi_Joel Online content OP
Hemi_Joel  Online Content OP
Minnesota
Being able to use a cheap distributor, if a guy choses to, makes a big difference if you start adding up the costs. If you are buying a new damper anyway, it's $145 extra to add the magnets. A trigger is $120, a bracket is $145. So $420 + the distributor. A new MSD Probillet dist. is $440. So In this instance, it seems the crank trigger is the way to go.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: Hemi_Joel] #3196027
12/08/23 08:54 AM
12/08/23 08:54 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
And we know how cheap you can be…
Since you have a shelf full of distributors, you should use the cable driven tach unit, BUT, there better be a cable driven tach hooked up to it… would fit the look, and old school vibe the Coupe has. Just remember to pack a spare, since you have plenty.
69 GTX 68 Road Runner
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: an8sec70cuda] #3196029
12/08/23 09:49 AM
12/08/23 09:49 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
We just braket race. I do have a 150 shot on it for those times when I feel like it's not going to run the number. our engine is 11.2 to 1 with aluminum heads and only 34 degrees of timing. on alcohol. Maybe if I ever build my W7 engine I might consider a crank trigger and belt drive. This current engine is a stock block 421" with Rod Bloomer heads.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Page 3 of 3 1 2 3
