Re: Anyone ever Take the Hot motor out ?
[Re: Dragula]
#3194202
11/29/23 04:22 PM
11/29/23 04:22 PM
Posts: 31,100 Oregon
AndyF
And put a boring run of the mill motor in, just to have more time enjoying driving the car vs. all the maintenance and bad manners?
Been trying to find a happy medium on the Hemi for years. Looking to make ok power, but still be able to drive it all over...I have to say, its been a fight. Still not sure I found it since the wiring burned up the day we got the new Hemi in the car, and I haven't put a single mile on it this year... I've been reducing the cam timing in my hot rod every time I build a new motor. I've done several new motor builds for my Coronet over the past 20 years and have gone with a smaller cam each time. What is interesting is that the peak power hasn't gone down, but the idle has improved and drivability has improved each time I reduced cam timing. The trick has been using better cylinder heads and porting the intakes. My current engine is a 496 inch big block with Trick Flow heads and a ported intake. Cam is 239 duration but engine make 600 torque and 600 hp. 20 years ago I was using 20 degrees more duration but making less power and the engine was lumpy at idle and tough to drive at low speeds.
[Re: Dragula]
#3194219
11/29/23 05:30 PM
11/29/23 05:30 PM
Posts: 43,335 Bend,OR USA
Cab_Burge
I like between 250 up to 270 degrees at .050 and closer lobe centers on roller cams than a lot of others advise based on my personnel testing and likes and dislikes on Mopar wedge street motors. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) . ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Dragula]
#3194251
11/29/23 07:55 PM
11/29/23 07:55 PM
Posts: 10,024 Frostbitefalls MN (Rocky&Bullw...
gregsdart
[quote=Dragula]And put a boring run of the mill motor in, just to have more time enjoying driving the car vs. all the maintenance and bad manners?
Been trying to find a happy medium on the Hemi for years. Looking to make ok power, but still be able to drive it all over...I have to say, its been a fight. Still not sure I found it since the wiring burned up the day we got the new Hemi in the car, and I haven't put a single mile on it this year... [/quote ]my left over parts would build what you want, on steroids. The ported 440-1 heads that made 926 hp, a megablock combo that has 580 cubic inchs, Jesel 1.7 rockers, and two very long duration roller cams i could have reground. With e85 and twelve to one compression, and cammed for max torque at 4,000 to 4500 it should be a brute wanting a 3.55 gear and tight eleven inch converter. Max rpm could be 6200 And maybe make 700 hp?
[Re: Dragula]
#3194533
11/30/23 05:03 PM
11/30/23 05:03 PM
fast68plymouth
So. Burlington, Vt.
It sure seems like at this point, the logical step forward would be to get the wiring done. Then see if the last round of the changes you made yielded the desired results.
[Re: fast68plymouth]
#3194791
12/01/23 10:56 PM
12/01/23 10:56 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
We did something similar with our 64 Savoy. Dad is 75yrs old and is not able to get around in the garage like he used to, so we replaced the 'good motor' that had lots of compression and cam with a stock stroke 440 w/ Indy SR heads, smaller solid flat tappet cam, and the factory Max Wedge intake. It now runs perfectly fine on pump gas, it's low maintenance with a shortblock that was last refreshed in 1995, and he can drive the car whenever he wants. It can run 10.90s when it has to and he races it a couple times a year, but he's done sitting in the heat at the race track, high entry fees, etc...He simply enjoys driving the car, and is not afraid to run it hard.
At some point it will get an updated 'good motor', but he's having too much fun with the current combo for us to take it apart.
[Re: Dragula]
#3195063
12/03/23 10:22 AM
12/03/23 10:22 AM
Posts: 630 Ct
Wirenut
Ct
Yeah, I like going fast, but running around the car all day just to make a couple passes....When I can mild it up a little, and put fuel in it ever couple rounds, and street it.... Not trying to agitate, just curious, . What’s all the running around the car you have to do just to make a couple of passes ? What about the engine / car is not reliable ?
