Re: Having a Distributor curve set at a speed shop [Re: CMcAllister] #3194240
11/29/23 07:26 PM
11/29/23 07:26 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Originally Posted by CMcAllister
Originally Posted by sr4440
Originally Posted by Cab_Burge
Thats a lot of money for it down twocents
Not when you don't have to buy, mount and wire an MSD box and distributor. Just one distributor and 2 wires to a coil and a hot. I have set up 5 or 6 of them on the dyno, and they are impressive.
Joe
First I've seen them. Pretty cool if it works and lives. Poor man's Grid. Wonder where it's made,
ETA I see designed and assembled in the USA.
What I heard from my customers is the feature they really like is being able to disable it when they walk away from their car. No way in h&ll to "hot wire" it.
Without Data, you’re just another guy with an opinion.
Re: Having a Distributor curve set at a speed shop [Re: sr4440] #3194250
11/29/23 07:50 PM
11/29/23 07:50 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Joe
A distributor that has 2 wires to make it run & you can’t hot wire it?
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3194341
11/30/23 12:29 AM
11/30/23 12:29 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
LOL, it's disabled/re-enable via your smartphone (Bluetooth), same way you tune it. Once you disable it, you need to log back in and re-enable it before it will ever fire.
Joe
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3194347
11/30/23 01:56 AM
11/30/23 01:56 AM
Washington
madscientist Offline
Washington
Lots of good info & stuff I hadn’t considered. I was kicking around locking this distributor out & getting the newest MSD offering that has timing control, it’s now only around $400, The MSD 6AL Ultra Plus, I can load maps to it set the curve based off RPM & vacuum. By using my dual point distributor, I can still run a tach drive tachometer & leave the factory wiring intact, just disconnect it & if the MSD unit goes out I can hook it back stock & get it back home on the points & not be stranded.
https://www.holley.com/products/ignition/ignition_boxes/street/parts/6523
Either way, it’s still much more difficult to set up a curve without being on the dyno. The programmable stuff is great. But you still need to know what key strokes to make.
Re: Having a Distributor curve set at a speed shop [Re: madscientist] #3194517
11/30/23 03:44 PM
11/30/23 03:44 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I recently worked with Joe White at Joe's Distributor Restoration and was very happy with his service and pricing.
You can check out his work on Facebook; or call him at 330-843-0335.
He restores distributors primarily but, has a distributor machine and does custom curving.
I've personally experienced big gains more than once when messing with custom timing curves.
The first time, I picked up 1.5 tenths going from a distributor that I knew was not curved correctly, to one that FBO spec'd for me.
This last time, I switched from the FBO distributor to a NOS Mopar Performance Distributor from the 80's that Joe curved for me and picked up 3 tenths and 2.5 MPH. Disclaimer, I made other changes at the same time but, none I really felt on the butt dyno; I really feel that most came from the distributor. Did a bunch of street testing with all changes 1 by 1 and most were "meh, maybe that did something". Did testing with the distributor and was blown away with the difference I felt. So, did the distributor account for all the found time, MPH? Probably not but, I bet that it was most of it.
Re: Having a Distributor curve set at a speed shop [Re: parksr5] #3195074
12/03/23 10:59 AM
12/03/23 10:59 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Went ahead & picked up a MSD 6AL Ultra Plus so I can just do the timing curve, have full control & adjustability of it. Going to lock out the Prestolite & see how this thing works out.
2021 Toyota Supra
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3195093
12/03/23 12:25 PM
12/03/23 12:25 PM
AndyF Offline
AndyF  Offline
Yep, digital work around for analog problem!
Re: Having a Distributor curve set at a speed shop [Re: AndyF] #3195110
12/03/23 01:43 PM
12/03/23 01:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
All you need is a Progression Ignition distributor and a Carb Cheater with a couple smartphones to help tune your car. shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Having a Distributor curve set at a speed shop [Re: fourgearsavoy] #3195122
12/03/23 02:54 PM
12/03/23 02:54 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
No need for the carb cheater, I’ve had an O2 in the car for years, they work great for dialing in the carb.
2021 Toyota Supra
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3195181
12/03/23 06:11 PM
12/03/23 06:11 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Performance Trends engine program will calculate a timing curve for whatever fuel and engine combo you have. I have used it a bunch and it is always close.
If you have a timing light just get a buddy to help you, get a piece of paper have your buddy rev the engine at 250 rpm increments record the timing on the paper plot your advance curve. Distributor machine is faster but few of them are left around.
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3197408
12/14/23 08:08 AM
12/14/23 08:08 AM
New York
lvlrlvlopar Offline
lvlrlvlopar  Offline
New York
Have you had a chance to install the MSD and play with it yet? I am considering getting one and was wondering if you can update the timing curve on the fly while driving or dyno tuning without having to shut it down and restarting? I called and talked to a tech at Holley. It didn’t seem like they had a complete grasp on everything it did yet. I saw in the features that it said up to 35 degrees max retard and in the installation manual it said 30 degrees. They seemed to think you could get the 5 extra degrees only by doing the nitrous retard. I’m not sure which to believe.
Re: Having a Distributor curve set at a speed shop [Re: lvlrlvlopar] #3197850
12/16/23 12:17 AM
12/16/23 12:17 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
I have not yet, I got a new, to me, winter 4x4 & I have been going thru doing maintenance to that before I get that MSD unit hooked up. Hopefully the week of Christmas I can get it in & see how it works. My understanding is the nitrous retard is not going to be adding to the 30 total because the point when you would hit the nitrous switch, you wouldn’t be near the max retard, you would be somewhere in the middle of the timing.
2021 Toyota Supra
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3197912
12/16/23 11:35 AM
12/16/23 11:35 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Is that a "race only" system? By that, I mean, it doesn't appear to have an engine load setting I.E. a vacuum advance. I never had one in my hands and there is no mention of any kind of light load (cursing) setting
Joe
Re: Having a Distributor curve set at a speed shop [Re: sr4440] #3198048
12/16/23 08:12 PM
12/16/23 08:12 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Joe
It does have a vacuum/boost port to connect to for advancing/retarding timing, see below pic.
2021 Toyota Supra
Re: Having a Distributor curve set at a speed shop [Re: grancuda] #3198071
12/16/23 11:37 PM
12/16/23 11:37 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I don't know how I missed that. blush thanks, looks like a good system.
