Re: Having a Distributor curve set at a speed shop
[Re: CMcAllister]
#3194240
11/29/23 07:26 PM
11/29/23 07:26 PM
Posts: 725 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Thats a lot of money for it Not when you don't have to buy, mount and wire an MSD box and distributor. Just one distributor and 2 wires to a coil and a hot. I have set up 5 or 6 of them on the dyno, and they are impressive. Joe First I've seen them. Pretty cool if it works and lives. Poor man's Grid. Wonder where it's made, ETA I see designed and assembled in the USA. What I heard from my customers is the feature they really like is being able to disable it when they walk away from their car. No way in h&ll to "hot wire" it.
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3194250
11/29/23 07:50 PM
11/29/23 07:50 PM
Posts: 1,014 Central US
grancuda
Central US
Thats a lot of money for it Not when you don't have to buy, mount and wire an MSD box and distributor. Just one distributor and 2 wires to a coil and a hot. I have set up 5 or 6 of them on the dyno, and they are impressive. Joe First I've seen them. Pretty cool if it works and lives. Poor man's Grid. Wonder where it's made, ETA I see designed and assembled in the USA. What I heard from my customers is the feature they really like is being able to disable it when they walk away from their car. No way in h&ll to "hot wire" it. A distributor that has 2 wires to make it run & you can’t hot wire it?
1967 Barracuda Formula S FB 383/727 1967 Chevy C10 Short Stepper LS1/TKO 600/7675 Precision 1979 Ford F150 LWB 300 / 4 speed 1996 Toyota Land Cruiser 2024 Ford Bronco Badlands Sasquatch 2022 Kawasaki Z900RS
[Re: grancuda]
#3194341
11/30/23 12:29 AM
11/30/23 12:29 AM
sr4440
Central TEXAS!!!!
A distributor that has 2 wires to make it run & you can’t hot wire it? LOL, it's disabled/re-enable via your smartphone (Bluetooth), same way you tune it. Once you disable it, you need to log back in and re-enable it before it will ever fire. Joe
[Re: grancuda]
#3194347
11/30/23 01:56 AM
11/30/23 01:56 AM
Posts: 4,457 Washington
madscientist
Washington
Lots of good info & stuff I hadn’t considered. I was kicking around locking this distributor out & getting the newest MSD offering that has timing control, it’s now only around $400, The MSD 6AL Ultra Plus, I can load maps to it set the curve based off RPM & vacuum. By using my dual point distributor, I can still run a tach drive tachometer & leave the factory wiring intact, just disconnect it & if the MSD unit goes out I can hook it back stock & get it back home on the points & not be stranded. https://www.holley.com/products/ignition/ignition_boxes/street/parts/6523 Either way, it’s still much more difficult to set up a curve without being on the dyno. The programmable stuff is great. But you still need to know what key strokes to make.
[Re: madscientist]
#3194517
11/30/23 03:44 PM
11/30/23 03:44 PM
Posts: 896 Oh
parksr5
Oh
I recently worked with Joe White at Joe's Distributor Restoration and was very happy with his service and pricing.
You can check out his work on Facebook; or call him at 330-843-0335.
He restores distributors primarily but, has a distributor machine and does custom curving.
I've personally experienced big gains more than once when messing with custom timing curves.
The first time, I picked up 1.5 tenths going from a distributor that I knew was not curved correctly, to one that FBO spec'd for me.
This last time, I switched from the FBO distributor to a NOS Mopar Performance Distributor from the 80's that Joe curved for me and picked up 3 tenths and 2.5 MPH. Disclaimer, I made other changes at the same time but, none I really felt on the butt dyno; I really feel that most came from the distributor. Did a bunch of street testing with all changes 1 by 1 and most were "meh, maybe that did something". Did testing with the distributor and was blown away with the difference I felt. So, did the distributor account for all the found time, MPH? Probably not but, I bet that it was most of it.
[Re: parksr5]
#3195074
12/03/23 10:59 AM
12/03/23 10:59 AM
grancuda
Central US
Went ahead & picked up a MSD 6AL Ultra Plus so I can just do the timing curve, have full control & adjustability of it. Going to lock out the Prestolite & see how this thing works out.
[Re: AndyF]
#3195110
12/03/23 01:43 PM
12/03/23 01:43 PM
Posts: 10,613 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yep, digital work around for analog problem! All you need is a Progression Ignition distributor and a Carb Cheater with a couple smartphones to help tune your car. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3195122
12/03/23 02:54 PM
12/03/23 02:54 PM
grancuda
Central US
No need for the carb cheater, I’ve had an O2 in the car for years, they work great for dialing in the carb.
[Re: lvlrlvlopar]
#3197850
12/16/23 12:17 AM
12/16/23 12:17 AM
grancuda
Central US
Have you had a chance to install the MSD and play with it yet? I am considering getting one and was wondering if you can update the timing curve on the fly while driving or dyno tuning without having to shut it down and restarting? I called and talked to a tech at Holley. It didn’t seem like they had a complete grasp on everything it did yet. I saw in the features that it said up to 35 degrees max retard and in the installation manual it said 30 degrees. They seemed to think you could get the 5 extra degrees only by doing the nitrous retard. I’m not sure which to believe. I have not yet, I got a new, to me, winter 4x4 & I have been going thru doing maintenance to that before I get that MSD unit hooked up. Hopefully the week of Christmas I can get it in & see how it works. My understanding is the nitrous retard is not going to be adding to the 30 total because the point when you would hit the nitrous switch, you wouldn’t be near the max retard, you would be somewhere in the middle of the timing.
[Re: grancuda]
#3197912
12/16/23 11:35 AM
12/16/23 11:35 AM
sr4440
Central TEXAS!!!!
Is that a "race only" system? By that, I mean, it doesn't appear to have an engine load setting I.E. a vacuum advance. I never had one in my hands and there is no mention of any kind of light load (cursing) setting . Joe
[Re: sr4440]
#3198048
12/16/23 08:12 PM
12/16/23 08:12 PM
grancuda
Central US
It does have a vacuum/boost port to connect to for advancing/retarding timing, see below pic.
[Re: grancuda]
#3198071
12/16/23 11:37 PM
12/16/23 11:37 PM
sr4440
Central TEXAS!!!!
I don't know how I missed that. thanks, looks like a good system.
