Re: B/RB hydraulic roller lifters which ones are good now
[Re: MarkZ]
#3194456
11/30/23 12:28 PM
11/30/23 12:28 PM
Posts: 4,715 Wichita
GY3
Wichita
I'm following this as well. I'm running Comp retrofit lifters in my big block and while I could stand the noise at first, now it's just grating. To the point I'd be willing to drop $1k on new lifters to shut it up if that is an option. A friend had this problem in his 440 Dart. He asked what I was using and ended up buy a set of Howards hydraulic rollers. Replaced the Comp's and everything was fine. Comp's are hot garbage!
[Re: Car Nut]
#3194457
11/30/23 12:29 PM
11/30/23 12:29 PM
GY3
Wichita
Close to 9,000 miles on my Howards with hundreds of dragstrip passes.
No issues at all and quiet as can be. Can you post the item number of the Howards? It's been 8 years and I don't recall the number nor do I have it written down. Sorry, I'm usually good about remembering numbers but not this time. LOL
[Re: GY3]
#3194520
11/30/23 03:57 PM
11/30/23 03:57 PM
Posts: 4,595 Motor City
6PKRTSE
Motor City
We have had issues with all of the different brands. Luckily, we have enough inventory of most that if we get a bad lifter. We swap it from another set and then when we accumulate an entire set of 16 bad lifters. I then return that full defective set.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
