Crate hemi block #3192132
11/20/23 02:26 AM
11/20/23 02:26 AM
Out of the State of Confusion
blue_stocker Offline OP
I bought this 472 a few years back and have been trying to find out what year it was made. Curiously, it has no casting date(s) nor any stamping(s) but it does have that the larger reinforced lifter bosses, std hemi engine mount pads and the typical casting number. Any idea what year this beast was made? Thanks in advance...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Crate hemi block [Re: blue_stocker] #3192166
11/20/23 10:59 AM
11/20/23 10:59 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Looks like an early non-siamese block. Post a picture of the front around the oil pump. That will narrow down the year of the block.
2011 Drag Pak Challenger
Re: Crate hemi block [Re: rickseeman] #3192202
11/20/23 02:09 PM
11/20/23 02:09 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Zippy might be able to chime in on the stampings on the block ID pad or the numbers above the casting plants logo to give a date on the block.
Re: Crate hemi block [Re: rickseeman] #3192215
11/20/23 03:16 PM
11/20/23 03:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks similar to mine but mine is Siamesed bore block at 528". Mine is an early 2000's. First built by RBRE in 2007ish.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Crate hemi block [Re: rickseeman] #3192216
11/20/23 03:21 PM
11/20/23 03:21 PM
Nothing like the later World block with the drilled and tapped area above the pump mount.
Thomas Jefferson
Re: Crate hemi block [Re: blue_stocker] #3192228
11/20/23 04:07 PM
11/20/23 04:07 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, and the area is also not filled in so that makes the block pre 2006. I think the casting numbers above the Motor Casting logo and the stamping on the ID pad mean something. We just need some help decoding.
Re: Crate hemi block [Re: rickseeman] #3192241
11/20/23 05:34 PM
11/20/23 05:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The 472 crate motor came out in 1998 and that block is before 2006 so we are closing in.
Re: Crate hemi block [Re: rickseeman] #3192243
11/20/23 05:43 PM
11/20/23 05:43 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I bought a 426 crate motor in the middle of '05 and the front of the block has that boss to run the external line, I've always wondered if I could modify it to look like and original ?
Mainstream Media is the new Pravda
Re: Crate hemi block [Re: JohnRR] #3192248
11/20/23 06:03 PM
11/20/23 06:03 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think it's solid so yes, I wish someone had a program to mill that out and make it look proper.
Re: Crate hemi block [Re: rickseeman] #3192350
11/21/23 05:24 AM
11/21/23 05:24 AM
NY
B1duster Offline
B1duster  Offline
NY
Re: Crate hemi block [Re: B1duster] #3192397
11/21/23 12:18 PM
11/21/23 12:18 PM
central il.
second 70 Offline
second 70  Offline
central il.
Zippy tried to get info on casting numbers and cast dates years ago and got nothing. So the best you can do is it's a MP water block
Re: Crate hemi block [Re: second 70] #3192420
11/21/23 01:58 PM
11/21/23 01:58 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Anybody know the “power limit” for the water block?
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Crate hemi block [Re: metallicareload] #3192497
11/21/23 07:04 PM
11/21/23 07:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would guess a lot. They have a lot of meat in the mains.
Re: Crate hemi block [Re: blue_stocker] #3192561
11/22/23 04:01 AM
11/22/23 04:01 AM
That block looks like and reminds me of the first "Mopar Mega block street Hemi block" I built from Glendora Dodge while I was still in SO CA. back in the mid to late 1990s shruggy
The cast in funny looking M was on it also up
Re: Crate hemi block [Re: metallicareload] #3192596
11/22/23 12:42 PM
11/22/23 12:42 PM
central il.
second 70 Offline
second 70  Offline
central il.
John Arruzza Hemi told me they're good to 1200. Here's the casting difference between the 2 blocks. Siamese has Mopar cast above the 2468330
As far as crate hemi's they are hit and miss. No way of knowing without checking them. Some people get lucky others are nightmares.
Re: Crate hemi block [Re: second 70] #3192600
11/22/23 12:51 PM
11/22/23 12:51 PM
central il.
second 70 Offline
second 70  Offline
central il.
This is my water block. It's easy to see the extra meat in the lifter galley.
Re: Crate hemi block [Re: rickseeman] #3194174
11/29/23 01:58 PM
11/29/23 01:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Love to help when possible, but I can't do anything with these that others here haven't already done.
Every inquiry I processed during my run there was first processed through an engineering authority who preferred zero documentation, and was then forwarded
to the embedded supplier/Cummins recon sales. The supplier would then process it through their secret decoder ring/contacts to come up with an answer.
Rich H.
Esse Quam Videri
Re: Crate hemi block [Re: ZIPPY] #3194175
11/29/23 02:06 PM
11/29/23 02:06 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Do you know who was casting blocks and heads during the Arrow and Cummins recon days , Pre World blocks ?
Re: Crate hemi block [Re: JohnRR] #3194181
11/29/23 02:28 PM
11/29/23 02:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Motor Castings was the predecessor to Dalton. "MC inside a shield" is the foundry mark, shown on previous pics in this thread.
"DF" (with a backwards "F") is Dalton/so-called World era foundry mark.
I'm not sure the Callies blocks still have the Dalton marking, but since the foundry never changed between MP/World mgt and Callies mgt, and was Dalton all along......for the time being I am assuming the mark is most likely still there.
Rich H.
Esse Quam Videri
Re: Crate hemi block [Re: ZIPPY] #3194396
11/30/23 10:09 AM
11/30/23 10:09 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Thanks Rich.
