Page 3 of 3 1 2 3
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3190571
11/13/23 08:05 AM
11/13/23 08:05 AM
west palm beach, florida
modelmakerinc Offline OP
Time to start on the dash and fix some wiring, My brother Ricky (Copper Dart) remade the under-hood wire harness and re-engineered some bulkhead connections for clean install of MSD ignition. I started with cleaning up the rats nest and backwoods retarded hillbilly wiring that was done by the previous owners. This is only a couple of examples of what I found.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3192141
11/20/23 08:31 AM
11/20/23 08:31 AM
I gutted the gauge cluster cause we are using mechanical gauges, the speedo had a broken needle and we dint want to buy a replacement plus the Tach was not wanted on top of the dash. I created a support panel with room to add future functionality and house what we have. I made a pattern for an aluminum face plate which i will cover in a faux carbon fiber vinyl.
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3192149
11/20/23 09:15 AM
11/20/23 09:15 AM
In between the steps for the gauge panel, I started in on rebuilding the tubs. It took a little bit to decide the direction, first was to install the inside tubs. Please forgive the chicken scratch welding as the panels were ground as clean as possible but there is ages of oxidation through the original sheet-metal and residue of bedliner and tar and seamsealer and crud plus, plus, plus. eyes
Anyway, I trimmed the wheelwell's factory floor to the pinch weld which gave me a good edge for alignment albeit about 5/16" lower due to the floor serrations and clearanced the bed floor flush to the frame rail. My Fabrication Mentor Dave lent me his bead roller to make filler panels and after bending and fitting about 80 times I buzzed them in. Basically spent 2 full days still need to make the top section on both sides. then to grind them smooth put some rattle can black undercoat the bottoms and I will wire brush with a grinder the entire bed and put a fresh coat of bedliner .
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3192151
11/20/23 09:17 AM
11/20/23 09:17 AM
few more pics and the proper sized tire in place cool
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3192188
11/20/23 11:51 AM
11/20/23 11:51 AM
moparx Offline
moparx  Offline
looks good to me. up
beer
Re: POWER DRAGON D150 build [Re: moparx] #3192469
11/21/23 04:25 PM
11/21/23 04:25 PM
finished the dash structure and face panel. simple faux carbon fiber Vinyl.
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3192793
11/23/23 07:33 AM
11/23/23 07:33 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Amazing work! Wish I had 1/10th of your fab skills.
Keep old mopars alive.
Re: POWER DRAGON D150 build [Re: 2boltmain] #3193829
11/28/23 07:49 AM
11/28/23 07:49 AM
I had made an access hole in the bed for the fuel fill, so I needed a basic cover to keep crap out and to dress the hole a little.
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3193835
11/28/23 08:15 AM
11/28/23 08:15 AM
finished up the tubs, flapper wheeled the welds, re-welded the pin holes and used a 3" coarse wire cup on a grinder to remove all the, flaking paint, rust blisters and random crap that had accumulated over time. sprayed ospho and wiped it down to prep for fresh coat of bed-liner. just the basic Rustoleum gallon give a nice completed finish. From wet and shiny to a good satin.
worked on the tailgate to get the mechanism functioning and tailgate hangars straitened. in a few weeks it will get a stock bumper to finish the back.
Re: POWER DRAGON D150 build [Re: modelmakerinc] #3193836
11/28/23 08:20 AM
11/28/23 08:20 AM
only a few items remain under hood and waiting on a replacement temp gauge so I can finish the dash. then Run-in and drive drive here is how it sits on all 4s. Still gonna do new cab mounts but it is mostly how it is gonna look.
Page 3 of 3 1 2 3
