Re: 4150/4500 base plate [Re: fast68plymouth] #3192622
11/22/23 02:17 PM
11/22/23 02:17 PM
NC
440Jim Offline
440Jim  Offline
NC
That is a nice adapter.
It has the large 4500 gasket area and the smaller 4150 footprint on the other side to clear linkages and even the 50cc accelerator pump housing.
And the tapered transition is a good feature.
Re: 4150/4500 base plate [Re: 440Jim] #3192667
11/22/23 04:47 PM
11/22/23 04:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It seems like the dual bolt pattern 4150 carbs have been gaining in popularity……so I’m surprised that Holley/QFT decided to discontinue this item.
I guess that’s why I’m not a marketing expert.
Re: 4150/4500 base plate [Re: fast68plymouth] #3192697
11/22/23 06:47 PM
11/22/23 06:47 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I've been making carb spacers for local engine builders for a number of years. I've been asked twice to make a 4150-4500 spacer. I haven't bothered making them a stock item for that reason.
Alan Jones
Re: 4150/4500 base plate [Re: LA360] #3192802
11/23/23 09:37 AM
11/23/23 09:37 AM
NC
440Jim Offline
440Jim  Offline
NC
Disclaimer: These are my measurements and are NOT intended as manufacturing specifications or any specific brand.
When putting a 4150 carb on a 4500 intake, there is only 1/4" gasket sealing area as shown below (5.25-4.75)/2 = 0.25
That might be enough, but is minimal. And if using a gasket with the 4150 center hole, the gasket will not be supported above most of the intake plenum.
An adapter plate improves both of these. In addition, a 50cc accelerator pump body extends below the carb's baseplate, and can contact the intake without a spacer.
Re: 4150/4500 base plate [Re: 440Jim] #3192850
11/23/23 12:42 PM
11/23/23 12:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ours are open spacers with o rings...Not any issue sealing things. We make them oprn to be able to support oval blade carbs which work very well.
