Very interesting info on pre oiling oil filters
#3189294
11/07/23 10:25 AM
11/07/23 10:25 AM
Posts: 12,299 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A bit long and windy at 14 minutes long, but they cover some cool information on oil and filters that you don't normally hear about. www.youtube.com/watch?v=939WTeorBnQ
Master, again and still
Re: Very interesting info on pre oiling oil filters
[Re: Pacnorthcuda]
#3189352
11/07/23 01:37 PM
11/07/23 01:37 PM
Posts: 2,527 PA
moparacer
PA
OK first off, I have never drawn fresh oil out of a 55 gallon drum. But I could see where there is a much higher risk of contaminants in a drum vs out of plastic quarts or gallon jugs. I have never seen anything come out of plastic containers that I questioned.
That first 4 or 5 seconds those guys talk about in the video is why I have always prelubed my engine with an accumulator.
I have a remote filter, oil cooler and a bunch of lines that would take a lot longer to fill up. And that 14:1 compression would be beating the crap out of the rod bearings. I would bet if I changed oil and screwed the filter on dry it would take long enough to cause engine damage.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3189398
11/07/23 03:50 PM
11/07/23 03:50 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Yep, I ALWAYS have full oil pressure before I even hit the key. And I prefill the filter, too.
[Re: DaveRS23]
#3189531
11/07/23 11:22 PM
11/07/23 11:22 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
One of the things I will never be without on a race car, accumulator.
[Re: MoonshineMattK]
#3189707
11/08/23 09:03 PM
11/08/23 09:03 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Today's ultra thin oils also play a roll in that.
[Re: DaveRS23]
#3190896
11/14/23 05:42 PM
11/14/23 05:42 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Today's ultra thin oils also play a roll in that. And ultra thin rings
[Re: HotRodDave]
#3190901
11/14/23 05:53 PM
11/14/23 05:53 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
Today's ultra thin oils also play a roll in that. And ultra thin rings ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I was shocked how much the newer thin rings make in the reduction of rotational torque needed to rotate on a new motor without the heads on them ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: DaveRS23]
#3190910
11/14/23 06:17 PM
11/14/23 06:17 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I read the part about people actually believing that you shouldn't prefill the oil filter, because that oil will hit the galleries BEFORE it goes thru the filter media, thus damaging the bearings. Vs. starting up with NO oil being delivered to the bearings while the filter fills up from the oil pump. How can anyone be that clueless, and repeat this nonsense online? And how can enuff people be that gullible as to repeat it? These must be the ones who have magnets on their fuel lines, little propeller blades under the throttle blades, and spark plugs with 8 electrodes each. Obviously, running brand new, clean oil fresh from the bottle thru a filter does not clean it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: DaveRS23]
#3190946
11/14/23 08:46 PM
11/14/23 08:46 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
Today's ultra thin oils also play a roll in that. And ultra thin rings And that roll is: Low tension rings take less soot to stick in the piston groove. Change the oil before it's saturated with soot and coating engine internals. Cam phasers can stick. Also, people are not used to checking oil levels anymore. Rings stick, oil usages begins. Turn fast or break hard enough to uncover the oil pickup. Oil pump sucks some air. Now the hydraulically tensioned timing chain can jump and ruin the day in a hurry.
[Re: '72CudaRacer]
#3190971
11/14/23 10:32 PM
11/14/23 10:32 PM
Posts: 21,846 Kirkland, Washington
Pacnorthcuda
Dirty oil is ALWAYS better than no oil. Thats why so many oil filters have by-pass valves.
Brian I disagree. A bypass built into a FILTER is done so that the filter medium can filter to a much smaller micron. A Full flow filter sacrifices this in order to flow ALL oil through the media.
