Re: Aluminum Block prep. [Re: Tig] #3191824
11/18/23 04:11 PM
11/18/23 04:11 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted by Tig
Originally Posted by racerx
Originally Posted by sasquatch
The INdy is not date stamped but they do have serial numbers that you can call Indy to get more info. Or just send me an email and I will get you a copy of the original order. On the indy blocks, take a boroscope or bright light and go up the main oil feed holes to where it intersects the main galley. Make sure that intersection is fully drilled and free of slag and crud. I also enlarge the oil drain holes on the top of the cam tunnel about double what they come at. I also drill a small hole in the China wall in the front of the block to allow oil to go down the front of the block. Other wise all it gets is splashed off the crank up there. Important for gear drives and timing chains both. Wash, wash and wash it again......Todd
Thanks Todd coffee can you explain a little more on the china wall shruggy
I'm pretty sure this is what Todd was referring to, #1 and #2 lifter galley pictured. Todd built our 655. Apologies for butting in here Todd.
Update.... thread chase all the bolt holes on this block (I was surprised on all the crap that came out of some of the holes) open up the drain hole on top of the cam tunnel to 5/8's ,any ideal of the size of the hole on the China wall on the front side of the block?
Re: Aluminum Block prep. [Re: racerx] #3191860
11/18/23 05:26 PM
11/18/23 05:26 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think I used 1"
2011 Drag Pak Challenger
Re: Aluminum Block prep. [Re: rickseeman] #3191926
11/19/23 01:56 AM
11/19/23 01:56 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted by rickseeman
I think I used 1"
Did you open up the drain holes above the cam tunnel ?If so what size?
Re: Aluminum Block prep. [Re: racerx] #3191963
11/19/23 09:38 AM
11/19/23 09:38 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I put 9/32 holes at the bottom point of the web v and out the front. The thinking was to try keep oil off the rotating assy.
Re: Aluminum Block prep. [Re: B1MAXX] #3191967
11/19/23 09:51 AM
11/19/23 09:51 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
One thing that was not discussed is seating the sleeves. My shop (Opel Engineering) will take a brand new aluminum block, torque an o-ringed iron head on each side and put it in the hot tank for a couple hours. You'd be suprised how many sleeves drop from this process. If not done the sleeves will drop after some heat cycles and may cause head gasket problems. There have been a few posts on the sleeve dropping subject.
