73CHALLENGER ON UHAUL TRALER #3188504
11/03/23 02:54 PM
11/03/23 02:54 PM
Dennispsalm91 Offline OP
Just got the call, the car is done from the paint shop. I need to go get her, she's a roller. Anyone used Uhaul trailer, they say it will fit. Its only a 2 hour drive . Any input would be appreciated.
Re: 73CHALLENGER ON UHAUL TRALER [Re: Dennispsalm91] #3188513
11/03/23 03:28 PM
11/03/23 03:28 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
I have used a U haul trailer for a Duster...fit easily with room to spare. twocents
Plymouth Makes It!
Re: 73CHALLENGER ON UHAUL TRALER [Re: RoadRunnerLuva] #3188516
11/03/23 03:36 PM
11/03/23 03:36 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Possible the U-Haul trailer does not have a winch to pull it on?
Re: 73CHALLENGER ON UHAUL TRALER [Re: Neil] #3188537
11/03/23 04:54 PM
11/03/23 04:54 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I found a local guy on facebook who rents out trailers, he had one with a flatbed and a winch which made picking up my car on casters really easy.
Re: 73CHALLENGER ON UHAUL TRALER [Re: EV2RTSE] #3188542
11/03/23 05:02 PM
11/03/23 05:02 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
My '73 Satellite WAGON fit on a Uhaul trailer no problem.
BUT, all the Uhaul trailers I've used/seen did NOT have a winch or come along on it. Bring friends or bring your own (preferably both)
John
Re: 73CHALLENGER ON UHAUL TRALER [Re: Dennispsalm91] #3188551
11/03/23 05:48 PM
11/03/23 05:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
You can find a cheap small ATV/UTV 12v 3,700 lb. winch for around $60-$75 online or at places like Tractor Supply or with one friend do this......... you only need to watch the first minute to see how it was done. Probably cost you as much for the tow rope and chain and hook as for the ATV/UTV winch.
Re: 73CHALLENGER ON UHAUL TRALER [Re: Neil] #3188560
11/03/23 06:23 PM
11/03/23 06:23 PM
no drivetrain = piece of cake
Re: 73CHALLENGER ON UHAUL TRALER [Re: Dennispsalm91] #3188563
11/03/23 06:41 PM
11/03/23 06:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My Coronet fit a Uhaul traler just fine
Re: 73CHALLENGER ON UHAUL TRALER [Re: gtx6970] #3188565
11/03/23 06:47 PM
11/03/23 06:47 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Forget that wench, I loaded a full dressed 1972 New Yorker with two come-alongs with ease with the help of my very young son. The wasp nests were the biggest problem.
Re: 73CHALLENGER ON UHAUL TRALER [Re: Dennispsalm91] #3188573
11/03/23 07:14 PM
11/03/23 07:14 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Come on guys, it's a winch, not a wench. panic Pretty significant difference between the two. runaway
Earning every penny of that moderator paycheck.
DBAP
Re: 73CHALLENGER ON UHAUL TRALER [Re: not_a_charger] #3188579
11/03/23 07:24 PM
11/03/23 07:24 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Watch the trailer fenders on the car door. Many car doors do NOT clear the fenders when the car doors are opened. Those first chips on a new paint job are the worst, especially when they happen for dumb reasons.
Re: 73CHALLENGER ON UHAUL TRALER [Re: poorboy] #3188583
11/03/23 07:44 PM
11/03/23 07:44 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Seen that happen. Or the doors clear the fenders just barely when nobody is in the car, and then someone opens the door and jumps inside to put it into park after it's loaded and the extra weight of someone sitting in the car
makes the door drop down enough to hit the fender.
My brother once drove one of his cars onto a borrowed trailer and broke both front mag wheel center caps when they rubbed on the trailer fenders as he drove past them. Nobody would even think that a car trailer wasn't wide enough to drive the car in-between the fenders, but it wasn't.
Re: 73CHALLENGER ON UHAUL TRALER [Re: not_a_charger] #3188590
11/03/23 08:04 PM
11/03/23 08:04 PM
SattyNoCar Offline
SattyNoCar  Offline
work Not really. They both can pull you in and hold you down. Old crusty ones can cause physical injury too.......
wink
John
Re: 73CHALLENGER ON UHAUL TRALER [Re: SattyNoCar] #3188591
11/03/23 08:14 PM
11/03/23 08:14 PM
Planet Earth
Planet Earth
wink
Not to mention psychological and financial injury... work
Plymouth Makes It!
Re: 73CHALLENGER ON UHAUL TRALER [Re: poorboy] #3188732
11/04/23 01:24 PM
11/04/23 01:24 PM
Nort Cackalacky
rrbrucea Offline
Member known as the "Artist"
rrbrucea  Offline
Nort Cackalacky
The left-hand fender on a U-Haul trailer is hinged and can be lowered so the driver's door will clear with ease. Just remove the rubber hold-downs from their catches on that fender and utilize the hinge to push that fender out of the way. up And I've used a U-Haul Auto Transport to take both my '71 Road Runner and my '68 Barracuda to Carlisle. Both cars fit just fine, um, separately of course...
Re: 73CHALLENGER ON UHAUL TRALER [Re: rrbrucea] #3188735
11/04/23 02:15 PM
11/04/23 02:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I used a U haul to get my 51 Plymouth. A couple of tips. Check the tire pressures, mine were low. Check the lights, make sure they work. Grease the ball. Double check the tie downs after a few miles, things loosen up.
Re: 73CHALLENGER ON UHAUL TRALER [Re: Sniper] #3188742
11/04/23 02:34 PM
11/04/23 02:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For a fairly short distance, I'd consider hiring a rollback tow truck.
Re: 73CHALLENGER ON UHAUL TRALER [Re: topside] #3188759
11/04/23 04:56 PM
11/04/23 04:56 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
And for sure don't put a cover on it on an open trailer, even at the distance of 2-hours (at 60 mph that's 120 miles or so yes?). The cover can or might burnish the body lines and tops and corners of the fenders and quarters (fenders) flapping in the wind. DAMHIK. Too bad you can't rent an enclosed trailer with a WINCH and take a wench along with you for company wink grin
Re: 73CHALLENGER ON UHAUL TRALER [Re: A12] #3188866
11/05/23 10:19 AM
11/05/23 10:19 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
The u haul trailers i rented did not have the the fold down fender. Remember to roll down the window so you can get in and put it in park and hit the parking brake. Come a longs work fine but bring some chain to attach it. You could get a tow dolly also but you have to search for them because not all u hauls carry them.
Re: 73CHALLENGER ON UHAUL TRALER [Re: Moparite] #3188905
11/05/23 12:36 PM
11/05/23 12:36 PM
5thAve Offline
5thAve  Offline
The silver trailers are the same and should all have the fold down fender, the older ones are hit and miss.
