Top end oil restriction needed?
#3186123
10/24/23 09:40 AM
10/24/23 09:40 AM
Posts: 553 Kentucky
clovis
Kentucky
Getting close to putting the new 383 in the car. One thing I have noticed after running it on the stand is the tremendous amount of oil in the valve covers. I am push rod oiling and the holes in the push rods are .076. Actually, when I primed it, it was amazing how much oil came out of the push rod, as it appears they get oil all the time. I am also using EDM lifters and still oiling the rockers shafts as normal. I am using Crane Gold rocker arms, and I have plugged the oil hole going to the pushrod. I am external oiling with a 7 quart Milodon pan and their oil pump and plan to run 8 quarts. I do run a vacuum pump but a very conservative level, 6-8 range. I have bumped my spring pressure to over 400 on the nose because it may see 7200-7300 every pass. I pan to run Valvoline 20/50 Race (conventional oil).
Two questions/concerns 1) I am curious if the pushrods are allowing enough relief that it is compromising the oil pressure to the EDM lifters thus the cam (with an .018 hole I assume it needs some pressure to work)? 2) Will I see a drop in pressure due to the amount of oil going to top side of the engine at 7300 rpms?
My dad said that they use to put pipe cleaners in the push rods on the small block chevy stuff they stock car raced back in the day. I have read that the press pin seems to a consistent way of slowing things down, so I have ordered a set to look into putting into the pushrods. Just not sure how much they will restrict until I get them in my hands-assuming .040, so that would give .035 of oil feed.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Top end oil restriction needed?
[Re: AndyF]
#3186155
10/24/23 12:16 PM
10/24/23 12:16 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
You don't need both that's WAY to much oil. Pushrod restrictors really are not the right way to restrict the oil there but with a running engine about the only option. As for restriction size there you can go pretty small and not have eny issues. But start by loosing the stock oiling or pr and adjust from there. A crane gold rocker can oil through the pushrod properly??? Or is it just dumping oil out the adjuster with nothing going to the rocker body/bushing?
[Re: Al_Alguire]
#3186165
10/24/23 01:01 PM
10/24/23 01:01 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If the lifters being used are std AMC solids with an EDM hole in the face(like a Comp 2901-16) then the amount of oil being fed to the pushrod cups “should be” metered(restricted) internally.
However, the tool steel versions I’ve seen don’t seem to have any metering(oil thru the lifter is unrestricted) and will usually over oil the top end without some sort of restriction in place.
[Re: AndyF]
#3186180
10/24/23 02:49 PM
10/24/23 02:49 PM
Posts: 553 Kentucky
clovis
Kentucky
I should have mentioned that I am using cup adjusters on the Crane Gold rockers, so I am using ball on ball pushrods (that is why I plugged the pushrod oil hole on the rocker arm). The cup adjusters have a hole through the middle so I have oil coming out the top of the adjuster-when I primed the motor this is where most of the oil was coming. I would love to see this motor with a set of those clear valve covers on it to see just how much oil is coming out of the top of those adjusters ( I bet it would look like a car wash).
I am using the Comp EDM lifters (2901).
I have .003 clearance on the mains using a full grooved bearing and .003 on the rods (aluminum).
[Re: clovis]
#3186208
10/24/23 04:12 PM
10/24/23 04:12 PM
fast68plymouth
So. Burlington, Vt.
Sounds like the oil metering part of the lifters is allowing a pretty generous amount of oil to pass thru. Imo, the original top end oiling would have been adequate with the stock cup type pushrods and adjusters.
Now that you’ve converted the rockers as you have, I’d only want enough pushrod oiling to lube the pushrods and adjusters. That could be a very small hole.
To put in it perspective…… When using the full time oiling on Indy heads, one .050 hole per side is plenty to oil everything.
[Re: fast68plymouth]
#3186224
10/24/23 05:21 PM
10/24/23 05:21 PM
Posts: 553 Kentucky
clovis
Kentucky
I switched to the cup adjusters to help out the oil hole situation on the Crane rockers. The oil hole on the Crane rocker causes you to have to have quite a bit of adjuster showing just to get oil to the pushrod. This was causing me to lose quite a bit of cam lift because of the kick-out of the ball adjuster. I guess I have traded one problem for another with this problem looking a little worst than the first. I guess I can check into a small tap for the push rods and install some set screws and drill a small hole-or stuff three pipe cleaners into each push rod.
[Re: clovis]
#3186225
10/24/23 05:28 PM
10/24/23 05:28 PM
fast68plymouth
So. Burlington, Vt.
Of course, we don’t “know” if you’re getting “too much” oil up top. As long as the oil pump pickup doesn’t start sucking air during the run………you might be fine as is.
#3186254
10/24/23 07:34 PM
10/24/23 07:34 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
7300? Your rod bearings will tell you if it's too much.
A single .060" hole on each side will keep the top end happy enough.
[Re: CMcAllister]
#3186257
10/24/23 07:50 PM
10/24/23 07:50 PM
Al_Alguire
Las Vegas
You can go REALLY small on the restrictors and still have plenty of oil.
[Re: dvw]
#3186348
10/25/23 09:50 AM
10/25/23 09:50 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Maybe you guys can answer this, if you run a hollow pushrod on a Mopar solid roller lifter cam (conventional shaft oiling through the cam bearings) ...does any oil still "pump" up the pushrods to the rockers from the up and down motion of the lifters? i know oil feeds in the rocker studs feed it the other way (gravity), I just wondered if any pushes up. small blocks (especially aluminum heads) don't seem to have much in the way of drainback (that doesn't pool up and drain down the pushrod passages) and as we know it tends to all go to the back of the heads when racing)
I've been running a knurled bushing around the #2 and #4 rocker shaft hold down bolts (where the oil passages enter the rocker shaft to limit top end oil to "less but adequate" rocker oiling, and since I'm running Cup type rocker studs I can use standard thick wall comp pushrods that are rounded on both ends (like any SBF or SBC). The bushing probably has about .003 clearance all around.
I don't know if I've stumbled onto a cool solution to limit oil to the springs or not (my logic concluding I'm leaving more oil in the system to feed the mains and rods) but it has been working quite well.
[Re: Cab_Burge]
#3186581
10/26/23 07:16 AM
10/26/23 07:16 AM
Posts: 553 Kentucky
clovis
Kentucky
No mods made to the cam journal.
Got the roll pins yesterday. Just holding one up to the pushrod feels like the fit will be tight. I bought 5/64, so they are measuring .084 in the middle, my pushrod is .075-.076. It looks like it will leave about .040 oil clearance. There happened to be a paper clip on the table and just for kicks I slid it through the roll pin. The paper clip is .032. So if you really wanted to cut back, there may be a way to put in a 2nd restriction, in this case it would leave about .010.
Does it matter which end of the pushrod you put the pins in? Would putting one on each end slow it down more?
[Re: Stanton]
#3186609
10/26/23 10:44 AM
10/26/23 10:44 AM
Posts: 553 Kentucky
clovis
Kentucky
No, they had some shorter (I believe 1/4" and maybe 1/2"). Without getting too far into hydrodynamics, I thought the length would restrict more and plus maybe easier to install.
