90-91 Dakota V8 serpentine mount ?s
#3184235
10/15/23 07:35 PM
10/15/23 07:35 PM
Posts: 2,956 GA
roadrunninMark
GA
I saw in MA that Eberg was talking about a serpentine belt setup in a 90-91 LA 318 Dakotas. He wasn't sure if the heads have an extra mounting point or not. Well, I found a pic or two online and it the Daks do have a serp. system. The question is though do these heads have the additional mounting locations or is it a bracket that allows the system to mount to a standard LA head mount. I can't find pics that detailed so I was hoping a member here has one of these Daks. If you do, can you look at the side of the heads to see if there is more than one threaded hole that the system bolts to. Or, is the bracket mount there and provide another mounting point (or two) somewhere to secure the system? Any and all pics are greatly appreciated!
It might only be on specialty Daks as well, like Lil red express or Shelby Dak... here is a pic from a Lil red..
Re: 90-91 Dakota V8 serpentine mount ?s
[Re: volaredon]
#3184584
10/17/23 11:41 AM
10/17/23 11:41 AM
Posts: 2,956 GA
roadrunninMark
GA
Hi Don, I looked on rock auto and it looks like the tensioner and idler are available. I would assume the fan spins opposite of an earlier LA too. If you can check the heads you have from it and take a pic of the side that faces the front, I would appreciate it. If they have just the one hole, then the magic is all in the brackets. I am guessing here but with the parts listed on rockauto, it makes me think all Dakota V8s had the serpentine system. I also saw these had an electric fuel pump, so I am wondering about the front cover too.
Loooks like the 89 model year had it too.
[Re: poorboy]
#3185033
10/19/23 12:32 PM
10/19/23 12:32 PM
Posts: 2,956 GA
roadrunninMark
GA
Disregard.. just read the last part where v6 still had old pulley system.
If the early v8s still had the pump opening, then there is a real good chance that that serpentine system would work on an old LA then. A change of water pump that can handle reverse flow is necessary along with the mechanical fan, unless using electric fan.
